Two tones of terror
Using LS6 intake with truck accsessories
I just got a flat floor LS6 intake for my 5.3, and im sure we all know about the idler pulley that parks it's ass right in front of the throttle opening when using the LS6 intake. I forgot the name of the company but isn't there someone out there who makes a kit to relocate the pulley?
Thanks |
Good Bye SonomaST
Re: Using LS6 intake with truck accsessories
why not use the vette accessories?
JJ's Automotive
http://www.speartech.com/
has the relocation pulley u need, they have a thread on performance trucks about it here is the link http://www.performancetrucks.net/for...k+accsessories Last edited by SoLowXtreme : 05-17-2008 at 11:50 AM. |
JJ's Automotive
also Search around on ls1tech i know i read a write up on some1 else doing it with minor modifications
the truck water pump wont work without modification and the steam vent lines need to be modded or changed
People are using the L92 water pump with this swap, it gets everything out of the way. Then you still need to move the idler, Speartech has stopped making the bracket last I had heard.
What to put here?
Sorry to intrude, but what about the injectors? You need the car type right? So the ECU will need to be reflashed right? Thanks!
goin broke but n style
that is what 02 sensor are for. There probably not much much of a diff if there is any.
JJ's Automotive
WTF!!!!
From my understanding you have to get it retuned. I talked to jared about my set up he said he had to change up the fuel maps or something and its not the same plug on the harness for the injectors. Thats just straight from jared but i dunno
this is from hot rod lane . the middle injectors are your ls1 and ls2 ls6 basiclly any car with a ls motor , the trucks are on the sides , youll also need a vette fuel rail
i have injectors and rail and manifold complete make me an offer i will not split them up ![]() Last edited by Bone_s10 : 05-17-2008 at 11:49 PM. |
Two tones of terror
Thanks for all the help so far. I do have the correct fuel rail but I still need injectors. Are all LS injectors the same or close #/hr rating or is there certain ones im looking for? I am running an LS6 cam as well and the ECU has already been flasshed for it. Can CP wiring make my harness with the car plugs instead of the truck style?
Two tones of terror
Ok so how close does the throttle spool come to the water neck when using the 5.3 pump and cable TB? I don't have a cable TB on hand, but from what you guys are saying it won't clear. Can you verify this?
its just greg
hey if you have any questions on the ls6 intake swap check out http://www.ls1truck.com/ there is a how too on the front page.
