Starting the swap of a 5.3 in my noma
Hi this winter i decide to swap my truck. we start 2 week a go. i will post some picture every time that will make some new thing.
for starting that is the patient: 00 sonoma, 4.3 manual ![]() the engine : come from a 04 silverado ![]() and now is time to work first day of work ![]() ![]() ![]() ![]() ![]() second ![]() ![]() third car carpet are good to work on the floor :P ![]() ![]() ![]() ![]() ![]() little test of the floor console ![]() today we remove the seat and interior of the truck i will post some pic later for finish i have a little question. what braket do you use to put the A/C on the top on the engine. because i don't want to notch the frame. |
he,he,he project over kil
Re: Starting the swap of a 5.3 in my noma
nice job man!!keep us posted becuase i am finally going to get working on my truck again once i get it moving to my friends garage!!
looks like things are going your way.keep it up.
its just greg
looks good
no body know what braket some people use to put the a/c over the engine ???
![]() http://www.currentperformance.com/Swap_Parts/AC.html |
thanks 01blzxtreme for the link
Zr2USA = B_Rich
Looks like a great start chapdou.
If you don't mind me asking, how much did you pay for the engine/all accessories and the wire harness? Feel free to send me a PM if you'd like. |
if i ever start this build ill expect the same when i get lost, btw post as many pics as possible and be detailed ![]() |
i work on the truck last weekend and i toke some picture.
this door are in front of the electric panel. it nice Gm powa :P ![]() and we remove all the interior ![]() ![]() ![]() |
little update i receive the headers and my engine mount 2d. I'm just missing the oil pan
FUCK MY TRUCK
i like those headers
AKA DavidAndSomeNumbers
Awesome! Clean truck. I'll be watching this one!
I play in the street
nice
Out of curiosity, what all usually needs to be moved around on a newer 5.7 for proper fitment with out cutting? Thanks J Last edited by SweetS10V8 : 12-24-2008 at 08:25 PM. Reason: Did you seriously have to leave every single pic in the quote??? |
it only makes the page longer, and for those with dial up takes alot longer to load all those pics that arent neccesary to view them 10 times while scrolling down |
Molon Labe
^^^ and it's just annoying.
I Need $
^^agreed^^
Any updates on the truck chapdou? |
i'm waiting the oil pan. the oil pan kit is b/o so I buy a h3 oil pan only. i supose to receive it monday. i will work more on it now because i finish the school 2d and i lost my girlfriend
little update, i got the pan
![]() ![]() ![]() and i need some help from you. i want some picture of a/c notch to know the size and the place to do it. Thanks |
update
-bolt the engine with the tranny -plated the floor -clean the frame and arm -buy new arm joint and sway bar link -notch the frame for te a/c plan for this week is to finish the notch, check all the wire, painting the frame and arms, put the engine in is new home some picture ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
did you make sure that the a/c will fit in there?
#24 |
not sure at 100% we look some picture take on the forum and we look to the engine :S do you have some real mesument ?
#25 |
Do yourself a favor and buy CPW harness and pcm thats programed for your truck.I think there is only a few guys on here that has attempted to spice into your old harness,me included and I failed and I'm an elevator mechanic,so I've seen a wire or two.So I bit the bullet and bought the harness from Jared.Nightmare solved.Just my 2cents.Good luck,Mike
#26 |
we want to try it :P and no body have some measure to check my notch
we look to this picture to make the notch ![]() ![]() |
#27 |
mine is just like that and still was hitting. so i mad it a tad bigger and going to grind own the arm some. and goo luck with the harness im doing the same thing....i dont wanna spend 1200 bux lol
#28 |
bigger on what direction ... ?
#29 |
front the a/c clutch was hitting the idler arm. but my motor mount also was not going forward all the way (makes the motor sit futher back) because it was hitting the a/c bracket that holds the compressor
#30 |
we try to put the engine tonight. we had a little probleme with the A/C but we will notch more and put the upper bolt a little bite lower to clear.
#31 |
its just greg
i'm glad I looked at this before I welded mine up, thanks for the info! good luck on the harness.
#32 |
little updaite
-finish a/c notch -paint the frame and arm ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#33 |
coming along good. and i told you that the a/c notch was to small. any pics with the new notch
#34 |
if you check the previous and the newer pic you can see that i modified the front of the notch
#35 |
Blah..........
waiting for pics
#36 |
i'm supose to work on the truck tomorow
#37 |
Modifying your own harness?
#38 |
yes we try that
#39 |
new update
the engine, the direction, tranny, and drive shaft ar in place. now it is the time to finish the harness to try the engine ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#40 |
Not so Avg
Were your able to use the stock driveshaft?
#41 |
yes it my stock drive shaft
#42 |
Blue-X
no notch on the crossmember with the h3 pan?
hell yeah |
#43 |
its just greg
how is the wiring going?
#44 |
alpha h3 pan fit without notching
![]() and for the wirring we will put all our time on in this weekend |
#45 |
its just greg
you have time?! where the hell do you find that shit?!
Share some!! ![]() |
#46 |
On da bottle
#47 |
mini update
my dad give me a little gift. he bought to me new inner fender ![]() ![]() ![]() |
#48 |
Molon Labe
Lol, nice. At first I just saw the cardboard box in the shape of an inner-fender and thought it was a joke.
#49 |
Not so Avg
What happened to the old one?
#50 |
they was a little bit rusty and i wanna to paint it but my dad think it was more easy to put new one lol
