Speedo not working after 5.3L swap
Old 07-23-2008, 09:15 AM   #1
Jonce007's Avatar
Jonce007 is on a distinguished road
Question Speedo not working after 5.3L swap
As some of you know, I'm finishing up my swap on the 1993 s10 with a 5.3L/4L65e. My speedo reads 0 mph at all times. I was asked to verify that I have two wires coming from the VSS to the white plug under the passenger side dash (purple/white and green/black wires). Both wires are there coming from the engine harness and mating up to the same wires in the dash harness.
Has anyone else ran into this issue? If so, what things did you check for and what ended up being the problem?
Two other issues I'm having:
1. Tachometer is reading low (verified its set to 8 cyl)
2. Windshield washer pump - what harness does this plug come from? Engine harness, headlights harness (didn't see it on there), or....other?
Old 07-23-2008, 10:09 PM   #2
LSX Swapper
sparkinak's Avatar
sparkinak is on a distinguished road
Re: Speedo not working after 5.3L swap
Should be going to your PCM first and then to your connector under the dash.
Washer pump should be on the headlight harness.
Not 100% but pretty sure.
Old 07-25-2008, 02:38 PM   #3
Jonce007's Avatar
I got the speedo working. Thanks to Jared for his help. When I removed the stock 4.3L computer, I didn't know about the VSS buffer that was attached to the computer (I didn't know what that extra electronic box was for). When I looked at the computer today as it was sitting on the bench, it was a simple fix - 2 screws and one nut to remove the speedo buffer. I plugged it back in and viola! Now I just need to set the computer for the correct gears
Thanks again for the suggestions guys.
Old 07-25-2008, 02:39 PM   #4
JJ's Automotive
SoLowXtreme's Avatar
SoLowXtreme is an unknown quantity at this point
when u wire in a after market tachometer you need to wire it for a 4cyl on LSX motors
Page generated in 0.07783 seconds with 11 queries
