Sleeper S10's LSX Swap - Page 20 - S-10 Forum
 1Likes
post #951 of 1301 Old 01-12-2013, 01:55 PM Thread Starter
Mr Cheech
Sleeper S10's Avatar
User is: Sleeper S10 is offline
Re: Sleeper S10's LSX Swap
Originally Posted by tiresmokinV8 View Post
Similar to mine up front. I have to drop it back to the ground in stages. Even with a low profile jack the low profile part isn't long enough to get to the cross member so the bumper still falls onto the jack if I don't drop the wheels onto 2x4s then drop each side from the frame rail to get it off the 2x4s
and with a low profile jack?
would you have an available pic of a close up you can post of your front tires to fenders?
any steering issues and top of tires hitting the inner fenders?
LS2 402 STROKER SWAP:
http://www.s10forum.com/forum/f213/s...x-swap-430296/
S10 Sonoma Envoy Swap - NEW & 99% COMPLETE!
Best offer!
http://www.kijiji.ca/v-view-details....teLocale=en_CA
Hellwig Rear Sway Bar - New Other
Best offer!
http://www.kijiji.ca/v-view-details....dId=1124629793
post #952 of 1301 Old 01-12-2013, 02:00 PM Thread Starter
Mr Cheech
Originally Posted by chargedextreme View Post
what qa1s did you get? i have qa1 r series on mine with 350lb springs
this is what i got:
QA1 Pro-Coil System, Drag Race "R" Series, 1701-1900 lbs front end weight
is your truck an extend cab?
how high do you have your bolts adlusted from bottom to top currenly? or the highest you had them?
what motor and how you like the ride? does it bottom out?
Best offer!
Best offer!
post #953 of 1301 Old 01-12-2013, 02:18 PM Thread Starter
Mr Cheech
Originally Posted by s-10ls1 View Post
I like the look of the drop and I wouldn't see a problem with it.
thanks boss! hope your right!
Originally Posted by Petro View Post
Looks good to me Jan and shouldn't be a issue driving it unless you have bad roads...May need to get a low profile jack though
you have an extra jack you can ship me lol. i'll take it!
:P
roads here are decent once patched up in the spring. winter not so much.
thing that worries me is that the QA1's will prob still settle and lower even more.
will just have to wait and see.
last night running out to get some colds ones i saw an Extreme at stock height and did a little hand measuring to my side and it was WAYS WAYS higer than mine when getting back to compare!
mine sits low as my '98 tercell with shot springs it's weird lol.
another thing is that it's been on stands forever and i got used to seeing it that way. that and i mainly drive an Escape that's ways higher.
sittng in my S10, the feel different.
have just a few before QA1 pics saved and also with 4.3 to after...
guess it's close?
Best offer!
Best offer!
post #954 of 1301 Old 01-12-2013, 02:24 PM
joey
chargedextreme's Avatar
User is: chargedextreme is offline
Send a message via AIM to chargedextreme
Originally Posted by Sleeper S10 View Post
this is what i got:
same coil overs i have and yes mine is a extended cab. my drivers side is about 2inches cranked up and passenger side is cranked up 1"7/8, i have not drove it with my new ls2 motor set up but i did with my 358sbc alum headed small block i had, the truck road amazing never had a problem with it bottoming out. i now have spohn upper and lower control arms
2004 ford f250 Harley-Davidson edition f-250 lifted 8'' on 38s,mbrp turbo back
2000 s10 xtreme 4.3 want to sell
1989 s10 ls2,tsp torquer v3 cam,fast 102 intake,fast 102 tb,built 4l65e 4k stall,cpw long tubes,one piece drive shaft swap,billet specilties street lite drag wheels,ford 9in rear. track times to come this spring
1994 ford f150 custom exhaust,bbk headers,k&n intake
post #955 of 1301 Old 01-12-2013, 02:38 PM
Dreaming of Turbos....
tiresmokinV8's Avatar
User is: tiresmokinV8 is offline
Sure thing, Its up in the air currently for the trans swap but heres from this summer after the afco coilover swap.
25" fender to ground height with 245/50r16 tires. Like 25.5" tall tires I think.
Orginal set height when I did the coilovers. Just 1/4" lower then the above pics.
2000 Sonoma Zq8 Extcab
'08 Ly6 6.0, Precision 7675cea TSP vvt-2 cam + more goodies, 4l80e, CircleD 3200 stall, HPTuners, Narrowed 8.8 swap: Moser axles, 3.73 gears, disc brakes, posi. Caltracs. Afco Coilovers
700whp 611wtq
10.78@125
99 Envoy front bumper cover for sale
post #956 of 1301 Old 01-12-2013, 02:42 PM Thread Starter
Mr Cheech
music to my ears. what i needed to hear!
THANKS!!!
Best offer!
Best offer!
post #957 of 1301 Old 01-12-2013, 02:55 PM Thread Starter
Mr Cheech
25" fender to ground height with 245/50r16 tires. Like 25.5" tall tires I thinnk.
mine looks to be exactly like yours. i will soon check to compare the fender to ground measurement on mine. that will give me an idea?
i have to ask... you have the 350 coil overs?
AND... how far up from the bottom are yours adjusted?
i miss my old ZQ8 rims. the older style are my fav.
truck is sharp!
my tire sizes:
front: 225/50/17
rear: 255/45/17
Best offer!
Best offer!
post #958 of 1301 Old 01-12-2013, 06:50 PM Thread Starter
Mr Cheech
Just measured the front and it's 24.5" up front, same on each side.
I forgot to check the back.
Pretty bad.
Plus I hear they will settle. Hope not.
Best offer!
Best offer!
post #959 of 1301 Old 01-12-2013, 09:51 PM
I ran 450# coils at first but they kept bottoming out and binding so I upped to 500# coils and my adjust screw is about halfway up the shock. Coils will definitely settle.
700whp 611wtq
10.78@125
post #960 of 1301 Old 01-12-2013, 09:55 PM Thread Starter
Mr Cheech
Hoping I won't be screwed with my 350 coils? Being that my block is aluminum.
Did loads of reading old posts and read so many mixed reviews and opinions on choosing the right spring rate, its making me dizzy.
So many mixed opinions lol. Maybe I'll have luck like chargedextreme.
Best offer!
Best offer!
post #961 of 1301 Old 01-13-2013, 12:12 AM
You lost me at carburetor
longboxdime's Avatar
User is: longboxdime is offline
Sleeper your truck looks niiiiiiiice! Low, lean, and mean! Run it for a few and see what happens. If it bottoms you can always change it later......
2002 Xtreme Blazer- Lq4, ls3 heads, 222/242 118+4, zl1 blower/lid, 2.4" upper, id1000s, e85, SW Longtubes, 4200#, no e.t. yet
LSX swap exact pinouts for a 411 and a 2002 truck OS http://www.s10forum.com/forum/f213/w...ys-out-446965/
<<<<Bottom of 1st post using the word files.>>>>
post #962 of 1301 Old 01-13-2013, 12:13 AM
art
( . Y . )
art's Avatar
User is: art is offline
Yeah, I read a lot about spring rates and everyone has different opinions. It's all going to depend on how you like your suspension. I have the exact same set up and can't wait to put it on. The springs are not too exspensive. You can change out the springs for 400# or 450#. I don't think you'll have any issues binding. Their kit consists of 10" springs. I think tiresmokin is was using 8" springs.
Part collecting for LSx swap...
Built "5.3"
My wife's mood depends on the size of the boxes UPS leaves at the door.
art is offline
post #963 of 1301 Old 01-13-2013, 12:25 AM
Ls1 Bagged
10Droped's Avatar
User is: 10Droped is offline
Yea looks killer hope it works out for you,that's the one nice thing with air little more psi and they will untuck lol!!
Jim
99 S-10 ext cab, bagged, 20&22's Bonspeed Sweeps, 40"x35" Legacy sliding rag top,99 LS1/4L60E,Circle D 278mm 3000 stall,243 heads,PAC 1218 springs, BTR trunion kit, 228r 112Lsa,Ls6 intake,Bosch 36lbs injectors, Eaton Tru Trac, Moser Axles,Tuned by Shane Hinds
10Droped is offline
post #964 of 1301 Old 01-13-2013, 12:21 PM Thread Starter
Mr Cheech
thx for the compliment!
installing the QA1's was the toughest for me so far and i got excited thinking about it.
also hate purchasing things twice. oh well.
will keep my fingers crossed it'll be good!
hope so on the binding.
the QA1 tech mentioned i can safely raise/ adjust the height to the very top thread as lowering it to the very bottom (SAFELY), we will see. good luck to both of us with the 350's!
lol that's cool!
truck looks show quality/ NEW!
Best offer!
Best offer!
post #965 of 1301 Old 01-13-2013, 01:11 PM
Independent
sonomaguy's Avatar
User is: sonomaguy is offline
It appears to have the same clearance as mine and I am running 235/45/18. I do not have any current side pics of mine right now and itis tucked away in storage so I cannot get any. I do bottom out occasionally. I have an 03 Noma with the ZQ8 suspension and I did 2 inch spindles and 2 inch blocks. I will try digging for some pics if you like. My tires are a 26.13 tall tire. I think I may have a pop can pic of the frame if you want to compare that.
AKA -Steve
post #966 of 1301 Old 01-13-2013, 02:01 PM
LS ONE
BLACKZQ8stepside's Avatar
User is: BLACKZQ8stepside is offline
I'm also running those springs, + I'm running an aluminum block as well, I had the same concerns about what spring to go with, I made my choice based on an estimate I made about how much weight I had up front, the coil overs were a bitch to install, not looking forward to a spring change.
LS1 Swap Project Thread: http://www.s10forum.com/forum/f213/b...ts-8ed-463034/
I'm crazy OCD!
post #967 of 1301 Old 01-13-2013, 05:34 PM Thread Starter
Mr Cheech
with the reg cab you will be better off than me.
can you buy the QA1 coils/springs alone?
i just see them selling with the shock.
a start will be me removing my 2 10" box. what's the average of those? 50lbs?
that has to help.
if i could start over i'd ditch the ac all together like Black X.
Best offer!
Best offer!
post #968 of 1301 Old 01-13-2013, 06:46 PM
art
( . Y . )
art's Avatar
You can get the springs. 10GBF350 for 350#, 400 for 400#, 450...up to 500 I think. Just type in that part number on summit and it should come up.
Built "5.3"
art is offline
post #969 of 1301 Old 01-13-2013, 07:00 PM Thread Starter
Mr Cheech
those numbers didn't work for me.
thanks for the help art!
Best offer!
Best offer!
post #970 of 1301 Old 01-13-2013, 07:56 PM
art
( . Y . )
art's Avatar
I edited the part #'s. I forgot a couple numbers but they should work now.
Built "5.3"
art is offline
post #971 of 1301 Old 01-13-2013, 07:59 PM
Search qa1 coils. Qa1 and afco sell all there coils seperately. Thought about getting longer coils when i went to higher rate ones for more stored energy but stuck with the 8" long ones in my afco swap.
700whp 611wtq
10.78@125
post #972 of 1301 Old 01-13-2013, 08:04 PM Thread Starter
Mr Cheech
Thanks lots everyone for the info/ help.
Best offer!
Best offer!
post #973 of 1301 Old 01-17-2013, 10:03 PM Thread Starter
Mr Cheech
so my truck continues to sink!!!
right now from the ground to the fender it measures 24". i don't care what anyone say's now it's not cool. not drivable.
doubt it'll even steer. LOOKS FUNNY!
like to share this with you members so you don't get busted like me and for a heads up for someone like BLACKZQ8stepside... who at this point can still switch up if needed/ decides to.
for me now it's work ahead!!!
been back/ forth with a QA1 tech who asked me to measure the compressed spring as my truck now sites.
with the weight it should measure 7 1/2" compressed (i have 10" srpings)
with the weight it measures 5.8" (it compressed 4.2"!!!) THAT's NOT GOOD!
so yes i need a stronger spring.
you don't see to much spring do you lol?
before the motor... nose up!
Best offer!
Best offer!
post #974 of 1301 Old 01-17-2013, 10:07 PM Thread Starter
Mr Cheech
so does anyone here have qa1's on your lsx?
what spring rate you have?
i would like to know what to go with next for my FINAL set?
450#
500#
550#
Thanks ahead for your help guy's!
Best offer!
Best offer!
post #975 of 1301 Old 01-17-2013, 10:44 PM
Call me Mario, Princess
AceHaag's Avatar
User is: AceHaag is offline
I have #550 on mine but it is awd so it probably isn't much help
Mike
my truck
New direction --->Time to get High
2001 s10 ext cab 6.0 243 heads, ls2 cam, nnbs truck intake, 87mm tb, 4l60e, 241c, dana 44's front and rear, 4.30 gears 35" m/t Baja claws.
AceHaag is offline
post #976 of 1301 Old 01-17-2013, 11:08 PM Thread Starter
Mr Cheech
Sure it is.
How you like the ride?
Thinking I may need 500#?
Still reasearching...
Best offer!
Best offer!
post #977 of 1301 Old 01-18-2013, 11:15 AM
500# here.
700whp 611wtq
10.78@125
post #978 of 1301 Old 01-18-2013, 11:27 AM
User is: Tomcat1983 is offline
Sure it is.
Hey Jan
So I did a little research online and talked with some of the guys here and the general consensus was that the #550 would feel like you welded the suspension. I had a couple guys here say that the 450's would be the way to go. But that was with a smaller engines, so i would say that your idea of the #500's would be a good choice. You could always adjust your ride hight with the ring.
I guess the one way to look at it would be, to get the 2.5" of spring compression that the techs said. You would need to get a good estimate of the weight on the front tires. Do you know anyone with a small pad scale?
the:
#400's = 2000lbs
#450's = 2250lbs
#500's = 2500lbs
post #979 of 1301 Old 01-18-2013, 02:14 PM Thread Starter
Mr Cheech
the:
#400's = 2000lbs
#450's = 2250lbs
#500's = 2500lbs
thanks tiresmokinV8 AND Tomcat1983.
i'm leaning toward the 500# spings.
my truck sunk bad and still may sink more. still have to add:
-cowl hood
-more gas
-exhaust
-front bumper/ grille
-me and passanger
tiresmokinV8...
how you like the ride of the 500# springs? would you suggest 550# springs?
like Tomcat1983 i heard the 550#'s could be to much?
don't have any scale in the area.
Best offer!
Best offer!
post #980 of 1301 Old 01-18-2013, 04:24 PM
I wouldnt go to 550's. The 500's arent bad but its definately doesnt ride like a caddy. But still soaks up most bumps with ease. If I have the compression too low to get a smooth ride it does still bottom out on larger bumps and potholes.
700whp 611wtq
10.78@125
post #981 of 1301 Old 01-18-2013, 04:32 PM Thread Starter
Mr Cheech
You da man!
500# springs it'll be! End of story!
Just ordered some intake stuff today.
Now have to get a new MAF cause mine is attached to the S&P intake.
Best offer!
Best offer!
post #982 of 1301 Old 01-24-2013, 01:42 PM Thread Starter
Mr Cheech
spoke to a second QA1 tech who owns/ owned:
2000+ extend cab zq8 with a 4.3l (has 450# springs)
2000+ blazer with a 4.3l (has 500# springs)
when mentioning my spring going from 10" to 5.75" compressed he was able to do some calculations to determine where the next level up springs would also compress to with the same weight of my s10.
450# to 6.75" compressed
500# to 7.13" compressed (plus me and a passanger it'll compress more)
so the verdict is 500# springs just ordered today!
with him having both spring rates to compare on his own s-series i didn't second guess his onpinion.
a heads up to anyone thinking of going with a QA1 set up and smilar optioned truck.
Best offer!
Best offer!
post #983 of 1301 Old 01-29-2013, 09:54 PM Thread Starter
Mr Cheech
a few parts finally came in the mail.
started out with this Street & Performance intake.
-didn't fit with core support on, hitting CPW fans
-would only take in hot air.
then purchased this costly kit cause i didn't want aluminum soaking any heat.
very costly considering i only needed 23 - 27" of pipe from this kit.
also needed another MAF, MAF extension, some couplers, straps and a K/N cone.
crummy camera, crummy night shots.
i wanted it to look very simple, clean and plain.
so i agreed with everyone and took the advice of another intake off to the side.
now for everyone to loose the oem hood trapping in heat with that thermal stuff beneath and attached under the hood. (trapping all heat).
get a cowl.
Best offer!
Best offer!
post #984 of 1301 Old 01-29-2013, 10:04 PM
Banned
User is: OrangyX is offline
Take headlight out & use a hole saw & drill some holes to let air in.
You will also need to make some sort of heat shield to block air from the rad & box the filter in the corner
You can kind of see on the left side of pic where I made mine from a foam diamond plate material,works great & easy to make.
OrangyX is offline
post #985 of 1301 Old 01-29-2013, 10:32 PM
You can see the shield I made in the pics I posted a while back.
700whp 611wtq
10.78@125
post #986 of 1301 Old 01-29-2013, 10:33 PM Thread Starter
Mr Cheech
ZQ8LS1
Thanks for posting that.
Looks like I have more work ahead.
Anyone in Totonto/area looking to buy some 4" tubing lol.
Best offer!
Best offer!
post #987 of 1301 Old 01-29-2013, 10:36 PM Thread Starter
Mr Cheech
Have your pics saved on my desk top which helped with my set up now.
Best offer!
Best offer!
post #988 of 1301 Old 02-04-2013, 05:01 PM Thread Starter
Mr Cheech
got the truck on stands again while waiting for the 500# QA1's.
a task with the low frame and not being able to fit a jack. (looking forward to correcting that).
in the mean time, installed this Fumoto Valve.
it will help big time when doing oil changes.
without it, the oil would just touch OR miss the notch area, but for sure would spill onto my brake line and harness unless holding them away.
F107S is the part number to the one i have.
has the short stem allowing the hose to connect.
Best offer!
Best offer!
post #989 of 1301 Old 02-04-2013, 07:18 PM
LS ONE
Change Car Oil Quick, Clean & Easy with Fumoto Valve - YouTube
I have got to get me one of those
I'm crazy OCD!
post #990 of 1301 Old 02-04-2013, 08:00 PM Thread Starter
Mr Cheech
You can't go wrong with one.
They also come with a longer stub/drain and without, if you don't plan on using the hose.
I chose the short stub/drain cause I was worried it wouldn't fit hitting the frame notch area.
While under there I removed the oil filter and filled it with oil.
Something I found you have to do for first start. Going over some pre-start tips from the LS1 Tech Forum.
I'd be totally lost without this forum and LS1 Tech.
Best offer!
Best offer!
post #991 of 1301 Old 02-04-2013, 08:04 PM
art
( . Y . )
art's Avatar
Always fill your oil filter when changing the oil
Built "5.3"
art is offline
post #992 of 1301 Old 02-04-2013, 08:11 PM
User is: frostystones is offline
looks like it'll take twice as long to drain with that small hole.
post #993 of 1301 Old 02-04-2013, 08:17 PM Thread Starter
Mr Cheech
Never did an oil change to date but something I won't forget when I do.
Best offer!
Best offer!
post #994 of 1301 Old 02-04-2013, 08:22 PM Thread Starter
Mr Cheech
It'll cut the time in half for me.
Not having to clean oil off from hitting and splashing on to the harness/brake line and frame/notch.
Best offer!
Best offer!
post #995 of 1301 Old 02-04-2013, 08:43 PM
LS ONE
Ditto
I'm crazy OCD!
post #996 of 1301 Old 02-04-2013, 10:08 PM
User is: 98moorenoma is offline
ive read this thing twice and love what your doin man wish i could do this to my truck but no money but keep up the good work man this is a great truck for the swap love the look of it and what you done to it!
post #997 of 1301 Old 02-04-2013, 10:46 PM Thread Starter
Mr Cheech
Thanks lots!
Best offer!
Best offer!
post #998 of 1301 Old 02-04-2013, 11:29 PM
Independent
sonomaguy's Avatar
I have seen those before and thought of buying one, just a little leary of the valve opening prematurely and draining your oil.
AKA -Steve
post #999 of 1301 Old 02-04-2013, 11:32 PM
Independent
sonomaguy's Avatar
Here is your low pro jack.
http://www.calcarcover.com/product/2...le_Billet_Jack
AKA -Steve
post #1000 of 1301 Old 02-05-2013, 08:54 AM Thread Starter
Mr Cheech
When having the thing in hand you'll see there's no way of that happening.
Thanks for the jack link!
Best offer!
Best offer!
