Sleeper S10's LSX Swap - S-10 Forum
 1Likes
post #1 of 1301 Old 02-06-2010, 04:08 PM Thread Starter
Mr Cheech
Sleeper S10's Avatar
User is: Sleeper S10 is offline
So I am finally starting up a post to show what I've been up to and will start off with a few pics.
My S10 is a 1999 that I purchased from new. Like these trucks so much that when I purchased it I never sat in mine or any S10, test drove a S10, just a window peek and I made the purchase, however originally wanted a blazer but couldn't afford it.
It has yet to see rain and purely hobby! So I'm moving supper slowly not in any rush. Plus I've never even done an oil change before this lol.
So getting into this is crazy for me but I'm giving it a go!
LS2 402 STROKER SWAP:
http://www.s10forum.com/forum/f213/s...x-swap-430296/
S10 Sonoma Envoy Swap - NEW & 99% COMPLETE!
Best offer!
http://www.kijiji.ca/v-view-details....teLocale=en_CA
Hellwig Rear Sway Bar - New Other
Best offer!
http://www.kijiji.ca/v-view-details....dId=1124629793
post #2 of 1301 Old 02-06-2010, 04:10 PM Thread Starter
Mr Cheech
Re: Sleeper S10's LSX Swap
Best offer!
Best offer!
post #3 of 1301 Old 02-06-2010, 04:18 PM Thread Starter
Mr Cheech
So at first I purchased a 5.3 L33 on a crazy deal with low kms and then turned out not to be such a deal as I had to build it and then decided to change my plans.
So I ended up waisting $$$ and rebuilding the motor only to sell but I just wanted a 5.7l.
Best offer!
Best offer!
post #4 of 1301 Old 02-06-2010, 04:49 PM
User is: yzdirtbikes125 is offline
Not downin' ya at all man but...never turned a wrench and your starting out with an ls swap? Should be interesting for you and best of luck
post #5 of 1301 Old 02-06-2010, 04:51 PM Thread Starter
Mr Cheech
thanks!
just done little basic things like change plugs, alt where i could to save a buck and was able to.
Best offer!
Best offer!
post #6 of 1301 Old 02-06-2010, 04:56 PM
Ahh that's cool, just take your time and don't get in a hurry. I've never done a v8 swap personally but I've always wanted to. I think the biggest thing is, if you have trouble with anything or are unsure of something, ASK someone. Alot of people I know refuse to ask questions and they get in so much trouble/with a big ass mess on their hands because of it sometimes. I don't see why they have such a big problem with asking for help, it doesn't make anyone look stupid and most people enjoy helping out
post #7 of 1301 Old 02-06-2010, 05:13 PM Thread Starter
Mr Cheech
thanks man,
well i've been SUPER lucky to have CODE4LS1 and kampz69 no joke answer a trillion of my questions up to now.
i guess if i phuck up on this you all can put some blame on them aslo lol!
Best offer!
Best offer!
post #8 of 1301 Old 02-06-2010, 05:43 PM Thread Starter
Mr Cheech
this is what I have going in but will probably change things up along the way and already have...
LS6 5.7l block new from Ebay
#799 heads from my L33 5.3
all gaskets, fuel rail, sensors, etc
GM harmonic balancer for 2005 Vette
ARP harmonic balancer bolt
GM accessory drive kit
Corvette Z06 CTS-V water pump
Car Shop Inc LS based starter
JP Performance singe roller timing chain set
ARP Cam Bolts
Melling high pressure oil pump HP
LS2, LS7 lower rad hose
LS2, LS7 upper rad hose
JTR LS1 steam vent tee
LS2 pan
pick up tube
dipstick
dipstick tube
windage tray/oil deflector
4.3 S10/Sonoma throttle cable
LS1 throttle cable bracket w/o cruise
LS1 throttle cable bracket bolts
Comp Cams:
camshaft XR265HR
push rods
valve springs
383 STROKER/ ROTATING ASSEMBLY:
Callies Compstar crank - 5140 forged 1 piece c-series 4.00" - BALANCED
Callies Compstar connecting rods - forged H-Bbams
Clevite LS1/SBC rod bearings
ARP rod bolts
Wiseco pistons - Flow Dome Top 3cc, -3.903 bore, 1.110" CH
GFX metric piston ring set
Clevite LS1 H-series main bearings
FLT Transmission
4L65E Extreme Duty – Level 5
upgraded with billet output shaft
Yank Performance 3600 stall
Long Tru-Cool Max transmission cooler
rating: 40,000 GVW, 45,000 BTU's
Current Performance goods:
custom expansion tank
wiring harness
custom tuning
KWIK a/c bracket/Sanden compressor
radiator/fans/condenser
headers/ceramic coating
Street & Performance LS6 air cleaner/ filter adapter with plastic 5 pin/ 5 wire mass air low sensor
SLP 160 thermostat
K/N oil filter
all Royal Purple synthetics
Lucas 42LB/440CC High Impedance Injectors
MSD 8.5mm wires
NGK iridium spark plugs
PTM 92mm throttle body
FAST:
intake 92mm
intake seal kit
92mm throttle body seal
Best offer!
Best offer!
post #9 of 1301 Old 02-06-2010, 05:46 PM Thread Starter
Mr Cheech
starting the body teardown!
Best offer!
Best offer!
post #10 of 1301 Old 02-06-2010, 05:50 PM Thread Starter
Mr Cheech
4.3 with Powerdyne.
unlike others i had good luck with my s/c and couldn't imaging a 4.3 without!
Best offer!
Best offer!
post #11 of 1301 Old 02-06-2010, 05:55 PM
Need LSx swap.....
Kampz69's Avatar
User is: Kampz69 is offline
Send a message via AIM to Kampz69
finally!
glad to see the project! ill be watching for sure
Nick
Currently Blazerless...but looking
Graphite Double Din bezel for sale, PM me!
OEM new Maroon plastic air dam for sale, PM me!
Originally Posted by AVdime View Post
it was just an old factory with a bunch of whores
Kampz69 is offline
post #12 of 1301 Old 02-06-2010, 06:01 PM Thread Starter
Mr Cheech
thanks Nick!
Best offer!
Best offer!
post #13 of 1301 Old 02-06-2010, 06:15 PM Thread Starter
Mr Cheech
so i was happy to get this out ALL by myself!!! no help!
just had my brother in law and next door neighbour that we share our drive with help me pull the engine back and away from the truck and wife on the camera!
i almost forgot that one last ground wire that CODE4LS1 warned about that held the engine back and nearly pulled my truck off the stand. well not really.
it sucks to have to fork out cash for the engine stand and lift but that's life.
Best offer!
Best offer!
post #14 of 1301 Old 02-06-2010, 06:19 PM Thread Starter
Mr Cheech
right now i'm stuck with trying to remove my SLP y-pipe. the dam nuts are melted on there!
i don't wanna saw-sal it cause it's mint and i could sell it. also never used a torch.
Best offer!
Best offer!
post #15 of 1301 Old 02-06-2010, 06:33 PM Thread Starter
Mr Cheech
so on my down time i worked on the fueling.
before or stock.
now...
don't brake these clips, it will take forever to find a part number and aren't cheap lol.
let me know if you need part numbers for all this crap. this took forever to get all this togheter with finding part numbers and all.
not so much love on here getting help with this but i'd love to share and help out a brotha' in need! trust me lots of pc time on here will get you written up and work and near divorce at home lol. no joke.
Best offer!
Best offer!
post #16 of 1301 Old 02-06-2010, 07:00 PM Thread Starter
Mr Cheech
now onto the front core and installing Jared's rad and a/c condensor which are amazing like all his products! Jared you da man!
his goods he's cratin helped me to decide to go ahead with all this and he is VERY patient to help with any question and not screen my calls from Toronto lol.
i called him back seconds after the last call when confused about someting and he never lost it lol.
so here is my original core that i messed up on drilling to many holes for the ac lines for CPW's high mount ac kit.
i hate using a whole saw, kind of scarry for me! so i was pissed and purchased a new core support and made sure to do this one right!
i also had some rust on the old core support and thought of getting a new core anyhow.
new one with the Transcool oil cooler installed. (Thanks CODE4LS1 for help choosing that cooler and posting pics of yours installed.)
also thanks to SS94S10 for the hook up on part numbers to the rivets and misc crap clips that broke on me and go on the core.
new core:
Best offer!
Best offer!
post #17 of 1301 Old 02-06-2010, 07:06 PM Thread Starter
Mr Cheech
i forgot to add a pic with the trans cooler.
you can see the CPW rad / condensor fit like OJ's glove!
Best offer!
Best offer!
post #18 of 1301 Old 02-06-2010, 07:49 PM
NCRides's Avatar
User is: NCRides is offline
what a sweet truck I love the rims..it's looking good, take you're time like you are doing and it'll all come together
Prior vehicles too many to list
1998 Sonoma ext cab Sportside ZQ8-(traded)
2002 ZR2-(sold)
1991 S10 reg cab 5.3 LSX (sold)
91 build pix : http://s216.photobucket.com/user/bac...%20S10%20Build
2002 Xtreme (indigo) ext cab Sportside(future LS3 swap)
NCRides is offline
post #19 of 1301 Old 02-06-2010, 07:54 PM
takes 2 balls in our game
s10-den's Avatar
User is: s10-den is offline
Looking good....
s10-den is offline
post #20 of 1301 Old 02-06-2010, 07:54 PM
SS is getting a LS!
SS94S10's Avatar
User is: SS94S10 is offline
Looking Good. Clean Truck to man! I like it. Love the parts list. Truck is going to have no problem wrecking tires. Another Canadian LS Swap in the books.
Apple Red 94 SS. L33 5.3L w/ Patriot 59cc 243's, VRX Cam, 92mm FAST. FLT Lvl5 4L60E. 150 hit of n2o. 295/55R15 Drag Radial.
SS94S10 is offline
post #21 of 1301 Old 02-06-2010, 08:11 PM
Those crazy ass dogs!!!
01cherryreds10's Avatar
User is: 01cherryreds10 is offline
Wow that radiator core looks sexy. Have you gotten the LS6 block or any other parts yet?
01' Ext.Cab sold and dont miss it
79' Malibu LQ4/4L70e 11.23@118 1.50 60'
07' Silverado 1500 Classic
post #22 of 1301 Old 02-06-2010, 09:34 PM
1low86blazer's Avatar
User is: 1low86blazer is offline
what kind of trans cooler is that?
very well detailed keep it up.
post #23 of 1301 Old 02-06-2010, 11:42 PM
Need LSx swap.....
Kampz69's Avatar
i still cant believe how big that thing is...lol
Nick
Kampz69 is offline
post #24 of 1301 Old 02-07-2010, 12:01 AM
Two tones of terror
KJF95S-10's Avatar
User is: KJF95S-10 is offline
Badass, what a nice truck. Theres enough info here for anyone to get it done if they work hard enough at it. You will love having an LSX.
95' S10 ext cab:5/5 drop, 5.3-LS6/4L65E, Turbonetics TC78 rear mount
"Bags, low only when it's convenient"
Overkill is consistently more fun
post #25 of 1301 Old 02-07-2010, 01:16 AM
Blue-X
yz85608's Avatar
User is: yz85608 is offline
whats with all the canadian swappers? lol
truck is super clean.
Shawn
Blue Xtreme
Xtremely Stock
yz85608 is offline
post #26 of 1301 Old 02-07-2010, 03:50 AM Thread Starter
Mr Cheech
Thanks Lots!
Best offer!
Best offer!
post #27 of 1301 Old 02-07-2010, 03:52 AM Thread Starter
Mr Cheech
Thanks!
Hey you already purchase ALL bearings for your L33. let me know.
Best offer!
Best offer!
post #28 of 1301 Old 02-07-2010, 04:18 AM Thread Starter
Mr Cheech
here is some info on the core:
Long Tru-Cool Max:
transmission cooler - #LPD47391 (w/o external thermal)
size: 8.5" x 22" x 1.25"
inverted flare HEX fittings: 3/8"
i think i have everything i need. here is my Costco rack of parts that i keep inside my coat room.
CPW long tubes
383 rotating assembly just came in.
a BIG thanks to Fraser at Speedinc to work with me selecting a stroker kit at an amazing price.
you have to watch for "sales" on this STUFF cause vendors will give you a deal but on crap old stock.
my guard dog watching my parts! watch out shes vicious!
Best offer!
Best offer!
post #29 of 1301 Old 02-07-2010, 04:23 AM Thread Starter
Mr Cheech
my new LS6 block and #799 heads machined with Comp springs and gear put together and ready to go.
Best offer!
Best offer!
post #30 of 1301 Old 02-07-2010, 04:25 AM Thread Starter
Mr Cheech
Thanks LOTS!!!
Best offer!
Best offer!
post #31 of 1301 Old 02-07-2010, 04:30 AM Thread Starter
Mr Cheech
a few more of the cooler up close and personal.
some blood from the wholesaw, grinder and dremil trimming lol
Best offer!
Best offer!
post #32 of 1301 Old 02-07-2010, 04:31 AM
Dreaming of Turbos....
tiresmokinV8's Avatar
User is: tiresmokinV8 is offline
Looks great, Keep up the clean work!
2000 Sonoma Zq8 Extcab
'08 Ly6 6.0, Precision 7675cea TSP vvt-2 cam + more goodies, 4l80e, CircleD 3200 stall, HPTuners, Narrowed 8.8 swap: Moser axles, 3.73 gears, disc brakes, posi. Caltracs. Afco Coilovers
700whp 611wtq
10.78@125
99 Envoy front bumper cover for sale
post #33 of 1301 Old 02-07-2010, 04:36 AM Thread Starter
Mr Cheech
THANKS man!
and lastly for now a big thanks to LS2Sonoma or Frank for hooking me up with this lovely piece! the one i had looked like scum, all roted away.
he sent me one sand blasted and it looks new!
Best offer!
Best offer!
post #34 of 1301 Old 02-07-2010, 05:47 AM
Killing Time
Petro's Avatar
User is: Petro is offline
Great work man!!! Keep it up...^^^And I believe I'll be doing that to mine now.....
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!"
Petro is offline
post #35 of 1301 Old 02-07-2010, 11:38 AM
Need LSx swap.....
Kampz69's Avatar
yea, that ECM looks like new...did you put a clear coat on it or anything?
Nick
Kampz69 is offline
post #36 of 1301 Old 02-07-2010, 12:04 PM
Build them right....Mod
philntx's Avatar
User is: philntx is offline
Other swappers should take note of one of your skills! You appear to be very well organized! That is a huge plus when dismantling and reassembling a truck!
Very nice project!
"Red-light runners" should lose their license for 30 days.
Blazer was sold! Now in Michigan!
Sounds good! http://www.youtube.com/watch?v=aejtZxXyvA4
At the Track: https://www.youtube.com/watch?v=gs1Zs8TJJ_A
philntx is offline
post #37 of 1301 Old 02-07-2010, 12:30 PM
Jonce007's Avatar
User is: Jonce007 is offline
Very nice project!
x2 - You can't be too detail oriented when dismantling and labeling parts.
As others said, very nice project, parts list, and build thread.
1971 GMC - 2wd lowered, 330HP 5.7L w/TH350
Jonce007 is offline
post #38 of 1301 Old 02-07-2010, 12:32 PM Thread Starter
Mr Cheech
Thanks Petro!
Best offer!
Best offer!
post #39 of 1301 Old 02-07-2010, 12:33 PM Thread Starter
Mr Cheech
Thanks
Best offer!
Best offer!
post #40 of 1301 Old 02-07-2010, 12:39 PM Thread Starter
Mr Cheech
philntx and Jonce007,
yeah i have now 54 folders saved and maybe 50+++ pictures in each, all numbered and then i started a draft in my yahoo account with deatails as clear as possible for me to undersatnd what happened in each folder.
there won't be a single screw, nut, bolt i won't be able to replace.
i swear my pc was so slow my wife thought i was downloading porn, til i showed her. i just bought a memory card to switch it to.
and the craziest part is EVERY single nut, screw and part has been scrubbed to hell removing all rust proofing and ziplocked bag'd away. (not to keep fresh lol but to keep together and labelled)
Best offer!
Best offer!
post #41 of 1301 Old 02-07-2010, 12:45 PM Thread Starter
Mr Cheech
no yet. but yeah Frank did an amazing job for me.
not cleared or even painted at the time. i have some engine paint i will use on it. and then clear it.
that's very next on my list and then notching my frame for the LS2 pan. my newborn Ella gets all my time right now being wks old.
it's alwayds dark here and my igloo has no lighting, lol.
Best offer!
Best offer!
post #42 of 1301 Old 02-07-2010, 12:53 PM Thread Starter
Mr Cheech
i have another lsx s10 that i never mentioned and don't play with much. it was made by Chip Foose and Overhauling.
i keep it really mint. better than how it appears in these pictures.
Best offer!
Best offer!
post #43 of 1301 Old 02-07-2010, 01:15 PM
badnoma16's Avatar
User is: badnoma16 is offline
hey mann, i have the same 383 rotating assembly for mine.. except i have the forged diamond pistons.. mines still in the shop getting bored. balanced and installed., if yours gets done before mine let me know how it feels man. we got alot in common with our builds as far as parts
post #44 of 1301 Old 02-07-2010, 01:17 PM Thread Starter
Mr Cheech
will do! good luck with your build.
Best offer!
Best offer!
post #45 of 1301 Old 02-07-2010, 01:32 PM
philntx's Avatar
Ok, show us the pictures of the the real blown truck
philntx is offline
post #46 of 1301 Old 02-07-2010, 01:34 PM
wow thats a lot of parts cant wait to see this get put together, good luck with the build, i gotta wait till after tax time to start collecting parts for my blazer. great job with labeling parts.
post #47 of 1301 Old 02-07-2010, 02:04 PM
Need LSx swap.....
Kampz69's Avatar
LMAO
Nick
Kampz69 is offline
post #48 of 1301 Old 02-07-2010, 02:19 PM
CODE4LS1's Avatar
User is: CODE4LS1 is offline
Excellent work so far Sleeper.......one of the cleanest and well organized installs I have seen on here. Great work
CODE4LS1 is offline
post #49 of 1301 Old 02-07-2010, 02:35 PM
Killing Time
Petro's Avatar
hey couple quick questions about the radiator/condensor setup....Does the shroud have something like 1/4" or 1/2" buffer between it and the radiator??How is the shroud connected to the radiator?? Is it welded or bolted?? It's hard to tell from the pics...And how is the condensor secured to the radiator?? Oh and yours doesn't have the extra port like mine( under the top inlet) I wonder which one is Jared's newer design..( I forget) Thanks man... Sorry if I hijacked...
Petro is offline
post #50 of 1301 Old 02-07-2010, 02:42 PM
CODE4LS1's Avatar
The fan shroud is held on by screws. On mine there is hardly a gap between the shroud and the radiator. The condensor is held on by 4 button head allen bolts that screw into little brackets welded to the front of the radiator. I believe the newer design has the extra fitting under the upper hose port for the steam vent. Mine did not have this extra port so I used the drain fitting for my steam vent.
CODE4LS1 is offline
