Security? Getting close to finishing...
I finally have gotten some time now that the semester for college is done to finish things up. I got almost everything hooked up to where I can crank it over, plug in the computer, hook up a battery, and upload the programmers computer program and...
Security! Won't turn over or anything, just says that when I try to turn the key to start it (cd player works that is in there?). Is the computer expecting an onstar radio or something, what gives? |
Re: Security? Getting close to finishing...
Also, this is the only connector i haven't found a home for, any clues?
unless you want to pay to advertise keep in in pms please
Good Bye SonomaST
you need a new edit to get rid of security, that appears to be a A.I.R. pump connector, the black and red is what u usually see with a AIR. where is it in the harness, what kinda harness is it? what kinda motor, that will help me figure out what it is
God damn it! So i guess I have to mail my computer back to current performance since he didn't take that out like he said? It is a 5.3L i started in march because I was suppose to get the damn wiring harness then but it didn't show up for another month and a half.
So now I'm going to have to mail the computer back off while I'm on break for christmas when I have time to do it before I'm back at college since I didn't get stuff in time last time. And I bet you are right on the smog pump, it would have been right there with my 4.3L Here's my original thread with all the other stuff if that matters... http://www.s10forum.com/forum/f213/beginning-of-5-3l-swap-277832/ Last edited by Christobevii3 : 12-20-2007 at 01:40 AM. |
gtfo now
That probably is the AIR connector, if it's up front at the core support on the passenger side then it's in the right place for it.
Makin Sparks
#1 security on those computers does not prevent the starter from turning over, it prevents the injectors from running.
#2. I looked at your file, and the security is shut off. Time to look elsewhere. |
Then what else could be causing a constant security light that never turns off?
ls1 junkie
i would think either a ground issue somewhere? or theres somthing that wasnt pluged in. security sucks, have problems with it on my DD, not quite sure whats causing it, but mine comes and goes. I would think how yours stays on constantly, you have something not hooked up or hooked up wrong etc, it should be something obvious when u actually find it.
Ok just paid for a tech 2 computer scan at the GM dealership. They are saying that the main computer and bcm are not talking at all and aren't compatible. They want to charge me $75 an hour to play around with different vehicles bcm programs and vin numbers to get them talking.
The is obviosly computer problem and this is what I believed I paid for with current performance. Is there something I'm missing here? Last edited by Christobevii3 : 12-27-2007 at 05:35 PM. |
Y would you wanna do that
there is a relearn procedure for the vats and passkey III or passlock2 i have a 2000 5.7l 3/4ton silverado that has something wrong with the bcm and the ecm not comucating some times and trips the system and as posted earlier when the security thing shuts it down most of the time the starter will turn it over but it wont even try to fire it shuts down the injectors but it may shut down the starter as well depending on what ecm and bcm you are using. oh and the relearn procedure suks it takes like 30 mins at least assuming you do it right. its better just to have it pulled out of the system (deleted) i asked the stealership here if they would delete that option on mine and they accused me of stealing my truck so im just gonna pay someone with a programmer to delete it for me. if you wanna try the relearn procedure just email me JonathanMaples@sbcglobal.net
as far as I know, dealerships can't delete it, they don't have the software. it will have to be reprogrammed with another software. |
update to my previous post i have found a deveice at pepboys that completly bypasses vats, passkey1, and passkey2. i bought it just to try it was 12 bucks it was orginaly made for remote starting systems but i found if you change where u put one wire it will bypass the security when u turn the key to start it. i will get the name ,model number ,and a few pics tomarrow the stuff is all in the truck i just installed today and its too dark to see right now.
Alright update guys.
I kicked it over today by manually jumpering the starter. Kicks over and runs fine. I'm not getting voltage at the purple wire on the transmission module but the fuses and relays are good under the hood. So somewhere (ignition?) it is probably stopping it. So i have a good idea where it is. The security light did drain my battery overnight to 11.2v so thats not good either. Bad news: Power steering pump my dad setup isn't working (brand new one, fuck) Also, the transmission hasn't taken more than 5 quarts. Is it suppose to pump the fluid when on or does it need to be in gear? I'm hoping it didn't get misaligned and eat itself up... Should be done in another couple weeks. Thanks |
LSX Swapper
Soon as you start it, it should be pumping fluid.
The bellhousing is longer, so long that it required me to hit my firewall more than i needed to, require me to pull my motor about 2 inches forward to get the transmission off, and is far enough forward that the input shaft isn't going in from the s10 transmission with the ls1 housing into the torque converter. Here we go again... |
LSX Swapper
no offense but tranny guy don't sound all that smart. Even on some of those 4x4 mags they state 1 bolt isn't the end of the world, your not putting down large enough numbers to need it. I'd put your old bell housing on and get the flex plate spacer and call it a day.
So in short, my wiring harness was incomplete and current performance gave me no help and said it must be all my fault. ![]() On the transmission, only a bearing in the torque converter was damaged from the bell housing mishap and all is good. Everything is fine now and runs great, starts on the first turn. I should have the exhaust on tomorrow and a/c along with power steering finished in a week or two. Thanks everyone else for helping me through this. Last edited by Christobevii3 : 04-22-2008 at 06:55 PM. |
Nitto1320 M O D
Gremlins are a bitch... Good to know you got everything worked out...
Makin Sparks
First off, I am very sorry for the trouble. Had we been able to trace down the wiring together on the phone, that may have saved a lot of headache.
Second, The option is always there to pull the harness off and send it back to check over if you feel it is something wrong on that end. Lastly, we have vastly improved our quality check procedures over the last year. Nothing goes out without being checked over thoroughly by the person that built it along with a second set of eyes at the same time to try and catch any possible errors. I hate to say no one is perfect because this is one field that can really be painful when mistakes are made. |
Good Bye SonomaST
i was thinking the same thing earlier when reading his latest response, it is painful and it does suck but no one is perfect, and he should have asked to have a wiring check either over the phone or sending back. i think one hitch isnt bad considering you took a drivetrain that was not intended to go be in the truck and still got it in, u came out pretty good.
ls1 junkie
starter relay wasn't grounded...doesnt the ground on the starter relay run from the fuse/relay panel to the radiator support?
From doing my swap the engine harness has nothing to do with the starter relay ground unless you got a relay center and junked the factory one. |
ls1 junkie
oh and post #9 FTMFW almost 4 months ago!!
#24 |
its just greg
good to hear things are getting completed.
and yes, gremlins are a bitch, and always cost stupid amounts of money to fix a simple $2 problem. |
#25 |
a.k.a Matt
Good to see everything coming together...looks like you have been at it for a while.
What are you running for exhaust? |
#26 |
I should get to test drive it this week without power steering and a/c (95 in texas already lol), so we'll see. And yup, you win on the ground! I've left it basically during winter while I've been at college and finally took it to my local guy to fix me up and glad I did. Perfect timing with graduating college and getting rid of the beater (96 sebring convertible lol, when people drive by they keep trying to check me out like i'm a chick). Might have to drive the lt1 roadmaster for a bit though... |
#27 |
Ok, having one other snag. When I start the engine up cold the idle is around 3000 rpm till it warms up. I'm also told it often backfires on the first fire too.
Any ideas of what to look for? I was suggested maybe a bad plug. |
#28 |
tune it.
#29 |
#30 |
Alright, got to drive it around and there is definitely something wrong with the tune!
Upon startup it revs to 4000rpm, goes to 3000rpm then for idle in neutral and park. In gear it idles at 2000rpm and goes to 45mph by itself! If i sit on the brakes for like 5 seconds at a stop it will idle at 1200rpm. So I guess I call current performance monday and hope they'll follow up with the tune I paid for. |
#31 |
Makin Sparks
Was that one of the old Predator tunes?? That's part of the reason we don't sell them anymore.
We had the same problem with everyone who changed from an electronic to cable TB and kept the DBW computer to run it all. Ask 99Bucket, his did the same thing. We can fix it since we switched to using HP Tuners. |
#32 |
Yes it is!
So what needs to happen to get it fixed? |
#33 |
Makin Sparks
I am still dealing with the aftermath of those stupid Predators...
We need to get the computer back and I can fix it and have it out usually the next day. The Predator will still work, but what we do is change the program with HP Tuners initially, then load that changed file in to the Predator after everything else is done. |
#34 |
Alright, so just ship it to the address on your site with cam specs again, computer/predator?
I'll probably wait till the power steering and a/c are finished. So probably will see it in two to three weeks |
#35 |
Makin Sparks
Yep, just send it to the address on the website when you can. Put in the box the computer, Predator, and any changes to the engine like cam specs, intake, injectors, etc... anything that has been changed from stock.
