s10 ls6 project
Old 09-12-2009, 09:50 PM   #51
On da bottle
zx9rgreen's Avatar
Re: s10 ls6 project
congrats man.....that first startup is the best
Old 09-12-2009, 10:05 PM   #52
Re: s10 ls6 project
i only know how to post pics if i knew how to post vids i could send one from my phone of it running i'm just glad it started up instead of blowed up
Old 09-12-2009, 11:26 PM   #53
Whats this for?
mr spree's Avatar
Re: s10 ls6 project
just send it to your email. download it and use photobucket to upload it
Old 09-13-2009, 12:25 PM   #54
NCRides's Avatar
Re: s10 ls6 project
it's running? good job and just over a month not bad...I've been on and off mine for almost 4 years and still not running.... oh well maybe this week soon as I figure out why my fuel pump won't power up
Old 09-18-2009, 09:30 PM   #55
Re: s10 ls6 project
looks like we may have a problem it started a load squeeling i took the belt off and it still does it any suggestions
Old 09-19-2009, 12:28 AM   #56
Under Construction
Re: s10 ls6 project
i def woulda went with a 228r camshaft as well as the ls6 ported oil pump and double roller timing chain. and as far as the fast intake goes. man honestly save your cash and port the tb and enjoy the ls6 intake. wiend has a street warrior coming out one day thats cheaper and outperforms fast "supposedly"
is this manual or auto?
i think the ls1 swap is the greatest thing ever. i just sold my 99 trans am with 463rwhp and i miss it dearly. but it was time to move on lol. anyhow if you have any questions hit me up.
as far a hp and track times. i would guesstimate at about 350hp and 12"S in 1/4
Old 09-19-2009, 01:27 PM   #57
Re: s10 ls6 project
ok i think the verdict is a spun cam bearing that sucks a$$ but it happens I will start the teardown tomorrow now i've lost all inspiration to finish but i'm stuck in the middle its not worth shit broke and i don't want to put any more money into it
Old 09-19-2009, 03:12 PM   #58
no more blazer
platour22's Avatar
Re: s10 ls6 project
how does this happen on a new motor?
Old 09-19-2009, 03:44 PM   #59
Re: s10 ls6 project
well I may not have broken it in properly or it could have been installed wrong from the factory the journal may not have been the right size hard to tell untill I get it apart but its no good to me broke just going to fix it and smile
Old 09-19-2009, 04:07 PM   #60
no more blazer
platour22's Avatar
Re: s10 ls6 project
were u get the motor from. Does it have warranty.
Old 09-19-2009, 06:37 PM   #61
Re: s10 ls6 project
no i built it
Old 09-19-2009, 06:47 PM   #62
no more blazer
platour22's Avatar
Re: s10 ls6 project
Well i hope its not too bad when you open it up. Good luck with it.
Old 09-19-2009, 08:01 PM   #63
Whats this for?
mr spree's Avatar
Re: s10 ls6 project
Did you purge the engine with oil????
Old 09-20-2009, 01:11 AM   #64
Re: s10 ls6 project
well some what i unpluged the fuel pump relay and turned it over it run fine for a little while then started this i got the engine out now gonna tear it down tomor
row see what the problem is
Old 09-20-2009, 09:04 PM   #65
Re: s10 ls6 project
well i have it apart its not a spun cam bearing there is a small something on the front bearing that may be causing it but not real sure going to take the front 2 main caps off and look to see how they look does anybody have any other suggestions
Old 10-01-2009, 11:45 AM   #66
no more blazer
platour22's Avatar
Re: s10 ls6 project
mknight what belt are you running. fixing to order my alternator bracket and wanna order it to. Also that pulley on the lower left of the bracket what is that. Is it included in the kit. looks like another idler pulley. Thanks man.
Old 10-01-2009, 05:46 PM   #67
Iroc-10's Avatar
Re: s10 ls6 project
Can you go into the squealing a little more? You said it was a load squealing? So it does not do it at idle? Did the sequel pitch change with engine rpm? And it did it with the belt off right? Is it like a metal on metal chirping/squeal? Did you try to locate it with a screw driver, by placing it on items on the engine when it was running and listening to the other end to get an idea of location? Anything to help narrow down the issue.
Old 10-02-2009, 02:17 AM   #68
Re: s10 ls6 project
PLATOUR its an idle pulley comes with the kit the belt i have is from autozone i will find the number and pm you
Old 10-02-2009, 02:20 AM   #69
Re: s10 ls6 project
OK update on the metal to metal squeeling engine tore all the way down to bare block and found no problems trans is at a freinds trans shop getting rebuilt < cause i bought it used just going to be safe> going to pick up a tci stall converter next week < new > going to thump up the engine some with a bigger cam while its apart i put 30 miles on it and now i'm back to 0 but oh well if it doesn't work this time we gonna push it to the back of the yard and watch it rust
Old 10-04-2009, 07:55 PM   #70
Re: s10 ls6 project
ok so i went ahead and ordered my new cam a patriot 225/229 .581 .591 gonna put a 2800 stall in also so i have my new ls6 cam springs and retainers on the chopping block in the classifieds will start assembly on the engine next week sometime can't decide wether to upgrade timing chain ,lifters & rod bolts
Old 10-04-2009, 08:11 PM   #71
HEY WAS UP S-DIMERS
conatus's Avatar
Re: s10 ls6 project
No U Didnt Liar They Stopped Making Ss In 98 And Never Made That Color
Old 10-04-2009, 08:25 PM   #72
Whats this for?
mr spree's Avatar
Re: s10 ls6 project
huh?^^
Old 10-04-2009, 08:43 PM   #73
Re: s10 ls6 project
what are you refering to ?
Old 10-04-2009, 11:31 PM   #74
no more blazer
platour22's Avatar
Re: s10 ls6 project
thats hillarious! This guy clearly found his way in the wrong thread.
Old 10-04-2009, 11:55 PM   #75
Need LSx swap.....
Kampz69's Avatar
Re: s10 ls6 project
lol
Old 10-05-2009, 12:21 AM   #76
Just turned 18
Re: s10 ls6 project
He was talking about post #2...but never cared to read further.
Old 10-06-2009, 05:04 PM   #77
Need LSx swap.....
Kampz69's Avatar
Re: s10 ls6 project
thank god for caps lock block...
try reading through the entire thread before calling people liars
Old 10-06-2009, 05:20 PM   #78
no more blazer
platour22's Avatar
Re: s10 ls6 project
Someone needs to teach him had to reply with quote.
Old 10-06-2009, 05:38 PM   #79
the brown turd
s10v8drew's Avatar
Re: s10 ls6 project
awesome 4th post moron
i like this build, well besides the problem you ran into, at least it gave you a reason to put a little bit healthier cam in there lol
Old 10-06-2009, 09:17 PM   #80
Need LSx swap.....
Kampz69's Avatar
Re: s10 ls6 project
lmao
Old 10-07-2009, 01:13 AM   #81
Molon Labe
BudRacing's Avatar
Re: s10 ls6 project
The swap is looking great so far. It's tough when you've got little midgets with hammers and lathes in your engine when it's brand new.
Also, I really like the way you've run your exhaust. It's simple, but done right; nice welds and hidden dumps. I probably would have gone a little quieter than flowmaster, but that's just because I'm tired of mine after 30k miles.
Good luck gettin it all back together!
Old 10-07-2009, 02:27 AM   #82
Re: s10 ls6 project
thanks flowmaster is all he had in stock I will start re-assembly this weekend my patriot performance top end kit arrived today and I ordered a 3200 stall from acc cconverters trans supposed to be back next week getting close I have my little boys 4-wheeler tore apart in the shop have to get it running first I hate a 2 stoke but oh well i will take some pics this weekend and post them up
Old 10-07-2009, 11:20 AM   #83
Need LSx swap.....
Kampz69's Avatar
Re: s10 ls6 project
lol, its been awhile since ive read a midget with hammers reference. i agree with your flowmaster comment, it sounded good when i first had mine installed but i got sick of it.
Old 10-07-2009, 08:18 PM   #84
wikd's Avatar
Re: s10 ls6 project
there is a good and a bad to the dumps... the good is... if ya get tired of the drone from flowmasters... you can always un cork that thing for a few miles...
the bad thing is... they get HOT... i had qtp electronic cutouts on my dime... was a lot of fun to have someone pull up next to my truck and rev on me... a press of the switch (did not even have to open em up all the way) usually made them stop the nonsense...
nice dime...
Old 10-08-2009, 08:53 PM   #85
Molon Labe
BudRacing's Avatar
Re: s10 ls6 project
nice dime...
When I mentioned dumps I was referring to the tailpipe exit dumped right under the roll pan/bumper rather than straight out the back. The pictures don't show cutouts on this setup.
What I really like about the dumps under the bumper is a good fall day when there's some leaves on the ground and they get blown away when you step on it to make for an elaborate take-off.
Old 10-09-2009, 08:05 PM   #86
wikd's Avatar
Re: s10 ls6 project
i thought bout that after i posted my reply... there is another one swap that shows cutouts and i was thinking to myself that i had the 2 mixed up...
Old 10-16-2009, 11:56 AM   #87
Re: s10 ls6 project
ok quick update I'm gonna try it again i put the shortblock together then i put the new cam in now the centerline is off by 1.5 degree so i ordered a trickflow adjustable timing set why does my luck always suck nothing ever goes right anybody else have the same feeling
Old 10-16-2009, 12:01 PM   #88
Re: s10 ls6 project
also the new acc 10in 3200 stall showed up and got trans rebuilt i got it back now he built it up to hold more i sure hope it works out this time also looking at sending heads off to get the p&p work done i may be able to get 500 at the crank with the combo
Old 10-23-2009, 09:27 PM   #89
Re: s10 ls6 project
oh little update its running again this time we are good but i think the stall is a little high for my likeing but we will see headed for the dyno next friday as long as i don't blow it up this weekend
Old 10-30-2009, 05:27 PM   #90
Re: s10 ls6 project
ok update on the dyno today 2nd pull working on af ratio has not adjusted timing yet 280rwhp driveshaft come apart he said that the stall is eating my numbers what do you think its a ls6 with shortie headers a 225/229 .580-.590 pp cam 3200 stall converter sure feels faster than 280hp
Old 10-30-2009, 05:47 PM   #91
the brown turd
s10v8drew's Avatar
Re: s10 ls6 project
^ wow, just twisted it right apart, i would say thats a little more than 280hp if it did that
Old 10-30-2009, 06:08 PM   #92
Petro's Avatar
Re: s10 ls6 project
MAN!!!Did it mess anything else up?? Like the gas tank???
Old 10-30-2009, 08:03 PM   #93
Re: s10 ls6 project
no i tore the guards off the fuel tank and squashed about 8in of exhaust pipe the dyno said 280 on the dynojet but a 50 kick will turn the tires over just seems like low numbers to me
Old 10-30-2009, 08:11 PM   #94
Petro's Avatar
Re: s10 ls6 project
Good thing it didn't mess anything else up...I've snapped a couple of shafts and pinions in my old Bronco and it ripped the underside up...I wouldn't worry about numbers see what it'll do at the track...
Old 10-30-2009, 08:25 PM   #95
Re: s10 ls6 project
yea your right there just numbers im gonna have to get some tires before i see the track it will just toast the stock 235 tires and it wants to act stupid when it goes into second with the stock tires
Old 11-07-2009, 05:48 PM   #96
Re: s10 ls6 project
ok looks like it got the trans also when the driveshaft come apart. Took the trans out yesterday it broke the taihousing and broke 3 ears off the bellhousing were it bolts to the engine. It put some pressure to it for sure looks like we may need a whole new one. This one had less than 100 miles on it. This will make the third trans for this build. I dont know if it will ever run this is getting real old.
Old 11-08-2009, 10:33 PM   #97
Re: s10 ls6 project
ok here is a pic
Old 11-09-2009, 01:46 AM   #98
FKNBMPN's Avatar
Re: s10 ls6 project
Damn. How did bust the ears off the bell housing? Was the trans x-member loose or something?
Also, back to your cam install. What made your centerline come out 1.5* off? Worn out timming set, or what?
Old 11-09-2009, 08:58 AM   #99
Re: s10 ls6 project
well nothing was loose when the driveshaft broke it just released all that energy at once something had to give it busted the trans mount also. Don't know what exactly made the centerline of the cam off. Some cams will be off you would probably never even notice that 1.5 deg. I just dialed mine in a little closer for personal preference i set it at a 110 deg centerline which made the open and closeing off about 1 deg
Old 11-14-2009, 09:07 AM   #100
Re: s10 ls6 project
ok my junk running again the tune is off still converter locks up in 2nd gear and i went back with a stock converter to try it and thats not going to cut it it doesn't come alive untill after 4k in 3rd gear 1&2 are ok but still a little slugish gonna get all the bugs worked out then swap stalls again
Page generated in 0.64904 seconds with 32 queries
[Output: 209.73 Kb. compressed to 190.79 Kb. by saving 18.93 Kb. (9.03%)]
