s10 ls6 project
Old 07-31-2009, 09:43 PM   #1
s10 ls6 project
Finally recieved all my parts and assembled the ls6 anyone running this same serpentine belt setup can you tell me the part # of the belt i need. Also just curious what you guys think the track time will be. I have a few freinds just itching to get a peice of it
2005 ls6 camshaft
2004 zo6 243 stock heads
new crate engine i used the short block sold the rest
sanderson short ceramic coated headers
cp wiring harness
cp radiator and cond & fan setup
fuel system undecided
2002 reg cab stepside s10
4l60e trans
Old 07-31-2009, 09:49 PM   #2
Re: s10 ls6 project
Thats a cool truck love to have that as a daily driver.Thats prolly my favorite color. Had an 2000 SS that color and those wheels are bad azz my fav. stockies for a s10 Couldnt guess on times but give them a run for tha $$$$
Old 07-31-2009, 10:02 PM   #3
Re: s10 ls6 project
Thanks its our extra truck for now those wheels will be going away to make room for some coy's c5 18x9.5 rear and 17x8 in the front
Old 07-31-2009, 10:10 PM   #4
S-Dime Swag
Redsdime's Avatar
Re: s10 ls6 project
i want to see this done thats what i would do if i had them money to do it
Old 08-03-2009, 10:04 AM   #5
Re: s10 ls6 project
ok in case anybody else is running that setup it ended up being a 98 in belt i will start takeing truck apart this next weekend up and will post more pics
Old 08-03-2009, 09:15 PM   #6
Re: s10 ls6 project
where did you get that serpentine set up and what did it cost you?
thanks
Old 08-03-2009, 09:20 PM   #7
Petro's Avatar
Re: s10 ls6 project
thanks
Check out Kwik Performance.com
Old 08-04-2009, 02:26 AM   #8
Re: s10 ls6 project
thanks
I purchased everything from jared at current performance <he is very helpful > I think I have around 700 in the brackets and the a/c comp the best i can remember
Old 08-04-2009, 09:47 AM   #9
vandejr's Avatar
Re: s10 ls6 project
what kind of waterpump is that ls1? and the alternator bracket looks somewhat like a c5 bracket. just wondering if everything lines up for the belt?
Old 08-04-2009, 10:25 AM   #10
Re: s10 ls6 project
yes its a ls1 waterpump it all lines up nice i hope it all works it was kinda expensive in my opinion
Old 08-04-2009, 01:34 PM   #11
Petro's Avatar
Re: s10 ls6 project
That's about how much it costs for a brand new accessories with A/C from GM and other sites...
Old 08-13-2009, 10:15 PM   #12
Re: s10 ls6 project
just an update finally started on the teardown this morning anybody need a good 4.3 engine trans and all acc going cheap
Old 08-14-2009, 01:48 AM   #13
B.K.'s Avatar
Re: s10 ls6 project
were ya located?
Old 08-14-2009, 01:54 AM   #14
Re: s10 ls6 project
albany ga
Old 08-14-2009, 02:17 AM   #15
Crazy As Fuck
leadsled2020's Avatar
Re: s10 ls6 project
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxx
Last edited by philntx : 08-27-2009 at 11:43 AM. Reason: Unnecessary inflammatory comments.
Old 08-14-2009, 08:43 AM   #16
Re: s10 ls6 project
xxxxxxxxxxxxx
could he be talking about a camaro ss not an s10
Old 08-14-2009, 12:59 PM   #17
CODE4LS1's Avatar
Re: s10 ls6 project
I think he means Camaro SS
Old 08-14-2009, 05:52 PM   #18
Re: s10 ls6 project
i would guestimate u have somewear between 350 and 375 to the wheels so i would say low 12s to high 11 with a good set of tires
Old 08-14-2009, 06:11 PM   #19
Re: s10 ls6 project
xxx
Old 08-15-2009, 03:30 AM   #20
Crazy As Fuck
Re: s10 ls6 project
CAMARO!!!!!
good cover....... it saved your ass.....lol
Old 08-23-2009, 08:23 PM   #21
Re: s10 ls6 project
ok were moving right on along got the a/c fiberglassed up after several hours < fiberglass sucks > looks good though everything seems to be fitting fairly well up to this point i had the transmount mount hole in the crossmember milled out so i was able to use it. The engine and trans bolted in for good i hope. I will be working some more on installing the cpw radiator in the core support in the next few days
Old 08-23-2009, 10:52 PM   #22
NCRides's Avatar
Re: s10 ls6 project
looking good...I see you have the sanderson shorties if thoses are the bolts that came with them do yourself a favor and replace them. Mine rusted just sitting in the garage so I replaced them with stainless bolts from Totally Stainless
Old 08-27-2009, 04:18 AM   #23
no more blazer
platour22's Avatar
Re: s10 ls6 project
I fixxing to buy that same alt/ps bracket. Can you tell if it sits higher than the intake, and if so how much. My truck bracket/w alt hit the hood.
Old 08-27-2009, 09:01 AM   #24
Re: s10 ls6 project
well i have the ls6 intake and the top of the alt is even with the top of the throttle body hope that helps
Old 08-27-2009, 04:01 PM   #25
no more blazer
platour22's Avatar
Re: s10 ls6 project
yea man makes me feel a little better. As of right now i have the ls6 intake also, but looking to sell and get fast. Don't want to whore your thread but heres pics with the factory truck bracket you can see how high it sits.
Old 08-27-2009, 09:19 PM   #26
Re: s10 ls6 project
big difference in the money going from a used ls6 intake to the fast my opinion would be to get it running before spending another 900 but its your money i know i have way more in mine than i was planning on
Old 08-28-2009, 01:10 AM   #27
no more blazer
platour22's Avatar
Re: s10 ls6 project
yeah i probably will. another thing, is there a reason you put you pulleys on the kwik a/c kit the opposite way than they do.
Old 08-28-2009, 08:48 AM   #28
Re: s10 ls6 project
well i put them on wrong i found that out when i tried to install the belt
Old 08-29-2009, 01:53 AM   #29
no more blazer
platour22's Avatar
Re: s10 ls6 project
Ok. Didn't wanna say you did it wrong. Thought they could be a reason behind.
Old 08-29-2009, 09:36 PM   #30
Re: s10 ls6 project
ok put a little more of it together ordered all the fuel fittings and hoses then modified the 4.3 throttle bracket to fit and looked at the exhaust. The exhaust looks like it is going to be tough to get it started really tight around the headers the driveshaft is going to have to be shortened and somehow fish the wiring harness in there + I posted a pic of the old dog
Old 08-29-2009, 11:51 PM   #31
no more blazer
platour22's Avatar
Re: s10 ls6 project
looking good man. Wish i was as far along as you
Old 09-01-2009, 02:11 PM   #32
Re: s10 ls6 project
ok a few more parts showed up for the fuel system then dropped the driveshaft off have to get it shortened by 1" then sent out the computer to jared we getting closer by the day
Old 09-01-2009, 02:13 PM   #33
Whats this for?
mr spree's Avatar
Re: s10 ls6 project
why do you have two filters? just curious
Old 09-01-2009, 02:27 PM   #34
Re: s10 ls6 project
i got the idear from someone else on here looked easy to hook up and you will never have to replace the one with the regulator in it
http://www.s10forum.com/forum/f213/f...-lines-411940/
Old 09-02-2009, 08:36 PM   #35
Iroc-10's Avatar
Re: s10 ls6 project
Is your alt really sitting that high, or is it just the angle of the pic? I thought the truck alternator normally fits and allows the hood to close. What did you spray on the a/c box after the fiberglass work? Looks like a nice project. I can't wait to get my harness and get started on my own.
Old 09-02-2009, 09:43 PM   #36
no more blazer
platour22's Avatar
Re: s10 ls6 project
I think you may be looking at my pic there iroc. Truck acc/w alternators usually fit in the trucks, but blazers motors sit a little higher.
Old 09-03-2009, 02:19 AM   #37
Re: s10 ls6 project
I sanded the high spots off of the fiberglass then shot it with a coat of that spray in truck bed lining then painted it with black engine paint it looks pretty good to me
Old 09-07-2009, 01:51 PM   #38
Re: s10 ls6 project
ok we headed off to the exhaust shop in the morning I think my little nissan has about all its gonna want
Old 09-07-2009, 01:55 PM   #39
Petro's Avatar
Re: s10 ls6 project
What's your plans for exhaust??? mufflers , routing...etc
Old 09-07-2009, 07:48 PM   #40
Re: s10 ls6 project
just going to let him do the best he can I want true 2-1/2 or 2-1/4 duals with the flowmasters
Old 09-07-2009, 08:17 PM   #41
LS2Sonoma's Avatar
Re: s10 ls6 project
lookin good so far... only one problem, we need more pictures!!
ps. nice shop you have
Old 09-07-2009, 09:11 PM   #42
Re: s10 ls6 project
thanks the shops a little small my wife thinks its a storage closet i'm not much of a picture taker but when it gets back i'll get some more posted up
Old 09-09-2009, 10:27 PM   #43
turbobandit's Avatar
Re: s10 ls6 project
Very TRUE!!!!!!!!!! mine were rusted sittin in the garage before my swap was even done!!!!!!
I got excited at first cuz they looked like ARP's or something. Not true though.
Old 09-11-2009, 01:37 PM   #44
I/W LSx swap 4 racetruck
Scrap's Avatar
Re: s10 ls6 project
Nice build, pulling all that with a Nissan p/u looks a little hairy!
-SS
Old 09-11-2009, 02:30 PM   #45
Re: s10 ls6 project
yea it had a load but it did ok just have to be carefull and try not to have to make any sudden stops its even a 4cyl but it has enough power just not enough weight to try and pull that all the time
Old 09-11-2009, 04:59 PM   #46
Re: s10 ls6 project
ok a few pics of the exhaust and fuel setup
Old 09-11-2009, 08:24 PM   #47
Whats this for?
mr spree's Avatar
Re: s10 ls6 project
whats the fitting size on the stock filter?
Old 09-11-2009, 09:01 PM   #48
Re: s10 ls6 project
its a 3/8 line
Old 09-12-2009, 09:12 PM   #49
Re: s10 ls6 project
ok pulled the relay turned it over a few times then installed relay and she fired right up its getting close to drive time its kinda loud with the flowmasters but maybe its cause its in my shop we will see here in a week or two i'll be ready to drive it out instead of pushing it around
Old 09-12-2009, 09:45 PM   #50
Whats this for?
mr spree's Avatar
Re: s10 ls6 project
can you get any videos of her runnin!?
Page generated in 0.66393 seconds with 32 queries
[Output: 210.75 Kb. compressed to 191.43 Kb. by saving 19.32 Kb. (9.17%)]
