Russel adapter fitting question
Old 10-29-2009, 11:30 AM   #1
s10 newb
horsepwraddict's Avatar
Will these fittings also connect to the sending unit on top of the tank? Are they the same quick connect that the filter uses? Im using the flex fuel filter/regulator for a returnless fuel rail. My lines are junk and want to replace them all with -6 braided straight from the pump.
How about the EVAP line too? Has anyone used the black line with the fittings already on the end from Dorman?
Thanks in advance guys.
Old 10-29-2009, 10:13 PM   #2
04Xtreme's Avatar
Re: Russel adapter fitting question
yes
Old 10-30-2009, 01:22 AM   #3
ouch that will cost some $ they real proud of that braided ss hose
Old 10-30-2009, 08:01 AM   #4
s10 newb
eh, its nothing compared to plumbing a race car. Wait untill you start running -10 and -12 line everywhere.
Old 10-30-2009, 10:59 PM   #5
82LS10's Avatar
I am trying to figure out a way to run those lines on my truck but the adapter fittings won't work but my truck is a 95 i looked at a sending unit for a newer model and they have the quick connects on it. not sure if ur sending unit is like mine though
Old 10-31-2009, 02:26 AM   #6
04Xtreme's Avatar
which fittings your sender have? the screw/oring kind? if so, they sell those, make and female
Old 10-31-2009, 07:58 AM   #7
82LS10's Avatar
Yeah i haven't seen those i want to go from that to a 6an have u got a part number or can u tell me what kind of fitting it is called?Thanks
Old 10-31-2009, 10:20 AM   #8
04Xtreme's Avatar
do you need and male ones or the female ones?
Old 10-31-2009, 10:28 AM   #9
Local Tech
ls1s10onair's Avatar
if that were the case, youd be better off welding the fittings on ur old sender
Old 10-31-2009, 10:32 AM   #10
04Xtreme's Avatar
female http://www.jegs.com/p/Earls/Earls-Fu...56078/10002/-1
male http://www.jegs.com/p/Earls/Earls-AN...54064/10002/-1
pressure is 16mm, return is 14mm
Old 10-31-2009, 06:06 PM   #11
82LS10's Avatar
Thanks alot i been wondering a few weeks about that i ordered them should be here next week.
Thanks again
Page generated in 0.56794 seconds with 31 queries
[Output: 75.66 Kb. compressed to 70.77 Kb. by saving 4.89 Kb. (6.46%)]
