Quuick Question: Tranny Cooler Lines
Does the OEM tranny cooler lines that go into the tranny require any thread sealant or pipe thread?
JJ's Automotive
Re: Quuick Question: Tranny Cooler Lines
you talking about a 4L60e ?
you don't NEED to but it doesn't hurt tho either |
Local Tech
arent they o-ring seats? you shouldnt need anything on there
Dont remember seeing any o-rings when I took them off. Now I am worried
If your swapping from a 5spd to a 4l60e how do you run your tranny cooling lines?
I have the OEM tranny lines and I cut them right about under the starter. I will then use 3/8" compression to -6 fitting and Push-lok hose to a B&M cooler mounted right behind the front license plate area. No front plates required in FL so I will make some cooling holes.
thats basically the same thing I did but I mounted my tranny cooler at an angle behind the license plate area. But cutt he stock lines about at the starter and used compression fittings
