Quick truck oil pan question
Old 04-06-2008, 07:18 PM   #1
s10 newb
horsepwraddict's Avatar
For those of you who have used a truck pan on your build, you obviously had to notch the cross member, but my question is how close does the pan sit from the top of the cross member, mine is pretty darn close, maybe 1/4" if not a little less. Its nothing that an engine limiter wont prevent from being a problem and im not to worried, just curious as to weather or not others have noticed this/done anything about it.
Old 04-29-2008, 02:44 PM   #2
s10 newb
Re: Quick truck oil pan question
nobody?
Old 04-29-2008, 03:05 PM   #3
Call me Mario, Princess
AceHaag's Avatar
mine was about that close too
Old 04-29-2008, 06:39 PM   #4
S-series Member
lilsonoma's Avatar
1/4" is a good call. I have a little more but I used spacer plates under the 2.8L mounts to push the motor up a hair. Now I have about 7/16" clearance. It doesn't matter really as long as you cut whatever you need out then box it back in with 1/4" plating and a strong welder. The boxed in portion will end up stronger than stock once you're done. Or at least it should be....
Old 04-29-2008, 07:23 PM   #5
AceHaag's Avatar
When i crashed mine the frame rail bent behind the cross member and the cross member was still straight so strength is not an issue
Old 04-30-2008, 09:43 AM   #6
s10 newb
thanks guys, good to hear.
Sorry about yourt truck ACE
Old 04-30-2008, 03:52 PM   #7
AceHaag's Avatar
No worries it is coming back with some improvements
Page generated in 0.56499 seconds with 31 queries
[Output: 59.93 Kb. compressed to 56.51 Kb. by saving 3.42 Kb. (5.71%)]
