questions on how to swap a ls1 into a 2001 with a 4.3
Old 07-31-2006, 01:01 AM   #1
MeTaLfReEkS10's Avatar
i am thinking of swaping a ls1 into my 2001 4.3 s10 . i know i need diffrent motor mounts . will my transmision work with an ls1 . and will it be smog legal and will my accesories bolt onto it
Old 07-31-2006, 02:52 AM   #2
i dont have feelings
Cronos's Avatar
Re: questions on how to swap a ls1 into a 2001 with a 4.3
you trans can work. there are other posts on that topic as well. basically, if you use your stock tranny there is a possibility that it wont last. as for the bellhousing, it does bolt up. a few holes dont line up, but there are enough for it to work.
none of your accessories will not work at all.
Old 07-31-2006, 04:24 AM   #3
Tommy
what the **** does that mean.. The accessories are not going to work with the different generation blocks.. so what are you trying to say?
Old 07-31-2006, 11:18 AM   #4
jinusow's Avatar
All lsx based motors will not fit your accessories with stock brackets. At least you have a 4.3 and the radiator still may work, throttle and cruise cables work, fuel lines/ pump work. Hell I had the 2.2l and had to get lots of stuf you won't. Most people need to get a driveshaft cut I didn't need to my driveshaft fit prefect. One last thing is you should have posi and you may want to find a 8.5 rear with 3.42 or 3.73 cause 7 5/8 will work just how long?
Old 07-31-2006, 02:39 PM   #5
what about smog . i want to buy a crate motor but do ls1 crate motors come with smog pumps or do i need to buy that separatly. and what about the a/c and alternator
Old 07-31-2006, 03:20 PM   #6
jinusow's Avatar
First off look at this link the cheapest crate you can get is a LQ9 at 3,749
http://www.gmpartsdirect.com/results...ges=1&pkgid=22
Second you should goto this link and read alot about this engine swap
http://www.ls1tech.com/forums/showthread.php?t=424515
Since you are worried about smog my opinion is that you should buy an engine trans from a wreaked 2001 or newer lsx based vehicle with transmission which will be about the same price as a new crate. If you get a corvette engine you have to get different headers and a camaro throttle body. If you get a motor from anthing else you have to buy all the corvette accessories and headers. Also, when doing this swap you have to decide on a different oil pan. modified 5.3 truck pan is what most do. I did a ls2 corvette oil pan cause there are no clearance problems with a bagged or lowered truck.
Old 07-31-2006, 03:37 PM   #7
are ther any other v8's that will go in a little easier. maybe from a newer truck like a vortech 350 or anything else
Old 07-31-2006, 09:02 PM   #8
Cronos's Avatar
the accessories that will not work are alternator, power steering, a/c pump. tensioners and idler pulleys will not work either. i believe that is all there are for accessories... if you consider anything else an accessory, let me know...
Old 08-01-2006, 12:49 AM   #9
Tommy
i was drunk and just giving you shit because you used a double negative. none will not..
Old 08-01-2006, 02:52 AM   #10
Cronos's Avatar
LOL i dont make that mistake often! i just noticed it now >=Þ
Page generated in 1.26530 seconds with 31 queries
[Output: 71.99 Kb. compressed to 67.52 Kb. by saving 4.47 Kb. (6.21%)]
