Question On Aluminum 5.3's
Old 08-01-2008, 04:39 PM   #1
Sleeper S10's Avatar
Sleeper S10 is on a distinguished road
Today I called a few wreckers looking for Aluminum 5.3's from a 2003 Trailblazer/ Envoy.
One guy I spoke to suggested a 5.3 all aluminum LH6 Vin M engine from a 2007 Silverado 1500 that they had.
Said it's the LH6 is the newer improved version of the L4M aluminum 5.3's and has more hp and the price was $1200 Canadian over the 2003's $2500.
Would the newer engine bolt up to the 4.3's accessories as well? That's my question.
Thanks!!!
Old 08-01-2008, 05:19 PM   #2
Need LSx swap.....
Kampz69's Avatar
Kampz69 is on a distinguished road
Re: Question On Aluminum 5.3's
nope. Youd need vette or truck accessories.
Old 08-01-2008, 08:59 PM   #3
jnoehl's Avatar
jnoehl is on a distinguished road
i dont think that junkyard motor is worth 1200 with no accesories. and the lh6 has AFM so i'm pretty sure you would pretty much need the complete engine: go fast pedal, accessories would be a plus and definitly need the ecu for that engine
Old 08-01-2008, 09:04 PM   #4
thx. what do you mean by fast pedal?
Old 08-01-2008, 10:44 PM   #5
poconojoe is on a distinguished road
It's a drive wire motor and doesn't use a throttle cable, so you'd need all those parts to make it work
Old 08-01-2008, 10:48 PM   #6
tiresmokinV8's Avatar
tiresmokinV8 is on a distinguished road
I think he means it has the drive by wire TB so you would need the gas pedal to it also.
Old 08-02-2008, 12:09 AM   #7
More Go then Show
THEKING's Avatar
THEKING is on a distinguished road
Can't you convert it to a Cable TB ? I think i remember hearing there is issues going to cable tb but can't remember. Someone should chim in.
Old 08-02-2008, 12:30 AM   #8
Location: i live in huffman tx.on 2 acres north of houston
chevysten is on a distinguished road
YOU CAN!! IM DOING RIGHT NOW.BUT YOU ALSO NEED TO GET THE PCU RETUNED/REFLASHED..
Old 08-02-2008, 02:57 AM   #9
RazorS10's Avatar
RazorS10 is on a distinguished road
I really want a cast iron but i have to use an 2003/04 engine due to emissions.
Old 08-02-2008, 04:23 AM   #10
Just flash a newer VIN in to the PCM
Old 08-02-2008, 07:08 AM   #11
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
I had a aluminum 5.3 out of a 06 z71, But sold it back to the guy I bought it from because I'm on to bigger and better things...
If you are doing the swap, I would want an aluminum engine setting under my hood if you can get one versus an iron block.
$1200 bucks for an aluminum 5.3 is a steal if its got low miles!!!
Old 08-02-2008, 10:28 AM   #12
WHAAAh?
NateZQ8's Avatar
NateZQ8 is on a distinguished road
I know those newer engines, just like the LS2 have the 58 tooth reluctor wheel on the crank that might need E- throttle body to function or at the least the newer computer. Jerad @ Current Performance would be able to answer that question.
Still, 1200 for an all aluminum engine isn't bad if you get all the goodies to go with it
Nate
Old 08-02-2008, 11:19 AM   #13
jnoehl's Avatar
yeah, i was talking about the DBW gas pedal, if it has a 58x reluctor ring, it has to be DBW, otherwise you'll have to pull the crank and press a 24x onto it, to have a cable driven TB, plus if you want to keep the AFM feature from the LH6, then it has to be DBW, not too sure about what his goals are as far as if its a DD, strip only, or weekend warrior?
Old 08-02-2008, 12:33 PM   #14
[quote=NateZQ8;5463077]Still, 1200 for an all aluminum engine isn't bad if you get all the goodies to go with it
Nate[/QUOT
not sure what came with it but it had around 30,000 kms on it.
Page generated in 0.13350 seconds with 11 queries
