#351 |
Re: Project: 5.3 4l65e 4 door blazer
but i was just wondering bro, its a 5.3 then... |
#352 |
no more blazer
according to the vin it is. Good enough for me. This is a gen IV engine, they are a little different then what most people are using on here.
#353 |
no more blazer
Anyone got an idea of how much steelbraided line i need to order for the transmission and fuel. Probably mount the tranny cooler in front of the condenser.
#354 |
that steel braided hose is very high it took about 6 ft for my fuel but i used regular black hose with hose clamps for my transmission it took about 12ft for the trans
#355 |
Going off the CarFax this is what I have for the only 5.3's that where made with iron blocks and still being GenIV.. LMF 5.3 LITER E85 COMPATIBILITY USED IN CHEVY EXPRESS AND GMC SAVANA 301 HP 325FT-LBS LMG 5.3 LITER E85 AND REGULAR, ALSO ACTIVE FUEL MANAGEMENT USED IN FULL LINEUP OF SUV'S AND TRUCKS (EXCEPT CADILLAC) CHEVY AND GMC C/K TRUCKS RATED AT: 320HP 338FT-LBS AVALANCHE AND SUV'S RATED AT: 320HP 340FT-LBS 9.9:1 COMPRESSION LY5 5.3 LITER SAME AS ABOVE LMG JUST LESS THE E85 CAPABILITY. Note my books states that the LY5 has an oil level sensor, but does not show one for the LMG. Maybe that could be the sign of which of the two it is..Unless the book just didn't print one for the LMG.. Hope that helps clear somethings up. I think we all know it's not the LMF if using the CarFax as a guide. So I would say it's one of the 2 that are left. Maybe if it's the LMG you'll get bigger injectors for the E85 capability. That would be nice. Good luck.. Jay |
#356 |
no more blazer
Thanks for the info. I have LS6 intake and injectors. I wanted to keep the truck intake but wouldn't fit under my hood.
#357 |
no more blazer
Anyone know if the ls1 water pump will work with the truck accessories. Or if there is a truck water pump that has the top inlet facing forward instead of up like mine.
#358 |
I remember there being certain year truck water pumps that worked and something like 07+ that didn't for some reason...
See the difference: ![]() ![]() Last edited by Petro : 09-15-2009 at 09:43 PM. |
#359 |
no more blazer
Yeah that one will be more helpful for sure. Anyone know which part # this pump is please let me know.
#360 |
no more blazer
BTW that pic reminds me I have a idler pulley relocater bracket i bought that i no longer need that i will put in the classifieds. This is if you want to run a car intake a truck accessories.
#361 |
What did you do with the truck accessories???
#362 |
no more blazer
their on my motor
#363 |
no more blazer
except the power steering pump and alt.
#364 |
im using the truck accessories and the alt is hitting the hood. so i guess i have to a new hood or cut the brace on the underside of the hood.
#365 |
no more blazer
U have a truck or blazer comgtsom
#366 |
1 gen blazer.
#367 |
no more blazer
U got pics. mine wasn't even close, theres no way my hood would of shut.
#368 |
Need LSx swap.....
i dont think the 1st gen blazers had the frame pads like the 2nd gens
#369 |
no more blazer
yea that would of helped. I wish i would have cut mine off and welding them in to the frame.
#370 |
Need LSx swap.....
yup, probably would have made life easier for you. does help with the oil pan though...
#371 |
no more blazer
true
#372 |
dont have any pics yet.
#373 |
![]() ...there are some fiberglass hoods out there without the brace |
#374 |
no more blazer
is that where the alternator hit.
#375 |
no more blazer
Well placed an order from summit last night got all the fuel line and fittings, also ordered a filter off ebay. heres the list i ordered.
Earl's Performance 360165ERL - Earl's Performance Tube-Mate Auto-Fit Hose Ends View Image and Compare
Part Number: EAR-360165ERL Estimated Ship Date: 10/5/2009 Transaction
![]() Earl's Performance 360165ERL - Earl's Performance Tube-Mate Auto-Fit Hose Ends Dorman 800-155 - Dorman Double Bead Steel Tubing View Image and Compare
Part Number: RNB-800-155 Estimated Ship Date: 10/5/2009 Transaction
![]() Dorman 800-155 - Dorman Double Bead Steel Tubing Russell Performance 640850 - Russell Fuel Rail Fitting Adapters View Image and Compare
Part Number: RUS-640850 Estimated Ship Date: 10/5/2009 Transaction
![]() Russell Performance 640850 - Russell Fuel Rail Fitting Adapters Russell Performance 640860 - Russell Fuel Rail Fitting Adapters View Image and Compare
Part Number: RUS-640860 Estimated Ship Date: 10/5/2009 Transaction
![]() Russell Performance 640860 - Russell Fuel Rail Fitting Adapters Summit SUM-2200075 - Summit Racing® AN to Tube Adapter Fittings View Image and Compare
Part Number: SUM-2200075 Estimated Ship Date: 10/5/2009 Transaction
![]() Summit SUM-2200075 - Summit Racing® AN to Tube Adapter Fittings Summit SUM-2200077 - Summit Racing® AN to Tube Adapter Fittings View Image and Compare
Part Number: SUM-2200077 Estimated Ship Date: 10/5/2009 Transaction
![]() Summit SUM-2200077 - Summit Racing® AN to Tube Adapter Fittings Summit SUM-220686 - Summit Racing® Hose Ends View Image and Compare
Part Number: SUM-220686 Estimated Ship Date: 10/5/2009 Transaction
![]() Summit SUM-220686 - Summit Racing® Hose Ends Summit SUM-230610 - Summit Racing® Stainless Steel Hose View Image and Compare
Part Number: SUM-230610 Estimated Ship Date: 10/5/2009 Transaction
Iwas going to also order my alternator bracket from jared, but my girlfriends dog broke its leg and cost me $220 bux, so it'll have to wait until next payday. ![]() |
#376 |
Need LSx swap.....
why did it cost you 220? you said its her dog
#377 |
no more blazer
Yeah but i felt bad cause it was my fault. 3:00 am he starts licking me in the face so i push him off the bed, and now broke leg.
#378 |
Need LSx swap.....
LMAO, that sucks dude. im the same way with things in my bed, usually its one of my kids that gets the boot
#379 |
no more blazer
yeah not only do i feel bad for the dog. It all so sucks that i had to waste 200 bux on him for the second time.
#380 |
no more blazer
some of the fuel parts came in.
#381 |
Molon Labe
Gotta love summit's fast shipping.
#382 |
no more blazer
yea the rest will be here tomorrow. Filter is coming from ebay.
#383 |
should have ordered a new dog cheaper than fixin an old one...j/k
#384 |
#385 |
no more blazer
Some more parts came in this week.
![]() Cable bracket thanks to Mitch (mknight) ![]() And the filter ![]() Last edited by platour22 : 10-14-2009 at 01:58 AM. |
#386 |
good luck with the ss braided hose its a real pain
#387 |
no more blazer
Yeah i heard that. Hoping to get a little help on it.
#388 |
ok check this thread out it may help
http://www.s10forum.com/forum/f213/s...l-hose-413360/ |
#389 |
no more blazer
so the tape is what holds it on the line
#390 |
On da bottle
I had no problems with mine and will help you with it.
#391 |
no more blazer
okay
