Project: 5.3 4l65e 4 door blazer
Old 04-21-2009, 10:50 PM   #151
Petro's Avatar
Re: Project: 5.3 4l65e 4 door blazer
My bad the LS2s have two grooves on the same side..I'll take a pic..And the bottom ones in your pic have larger holes on the side with the groove..For the VVT I guess? On these all four are same size..
Old 04-21-2009, 10:53 PM   #152
no more blazer
platour22's Avatar
okay
Old 04-21-2009, 11:06 PM   #153
On da bottle
zx9rgreen's Avatar
Looking good Paul
Old 04-21-2009, 11:10 PM   #154
no more blazer
platour22's Avatar
Yea petro those should work no problem for me. Is that a part number on it, i can't make it out.
Thanks steve, does it look like it may be close to in time.
Old 04-21-2009, 11:23 PM   #155
Petro's Avatar
The number is 12569259 on the part
But I got this off another site: LS2 valve pushrod cover guide (lifter tray) = 12595365
Old 04-21-2009, 11:29 PM   #156
no more blazer
platour22's Avatar
Thanks man i'll try and get the right ones tomorrow.
Old 04-22-2009, 08:09 PM   #157
no more blazer
platour22's Avatar
Finally got my wiring harness in today, hopefully becoming togeather soon. Also my other lifter trays will be here tomorrow, so i should have the motor wrapped up. Heres some pics from today.
Oil pump back in.
New front seal installed.
Windage tray and pickup tube installed.
New H3 alpha pan on.
Timing cover on but not torque until harmonic balancer gets put on first.
Old 04-22-2009, 08:19 PM   #158
Petro's Avatar
Do you have a part number for that bracket on the timing cover? I'm going to need one of those...
Old 04-22-2009, 09:42 PM   #159
no more blazer
platour22's Avatar
you referring to the cam sensor bracket.
Old 04-22-2009, 10:01 PM   #160
Petro's Avatar
Yep...
Old 04-22-2009, 10:05 PM   #161
no more blazer
platour22's Avatar
i'll go check it.
Old 04-22-2009, 10:10 PM   #162
no more blazer
platour22's Avatar
Sorry no number on it, but i'll see if i run across it tonight.
Old 04-22-2009, 10:13 PM   #163
Petro's Avatar
Thanks...I can't find a number for it online..I'm keep getting the sensor part number...
Old 04-22-2009, 10:21 PM   #164
any more pics of your transmission?
Old 04-22-2009, 10:28 PM   #165
no more blazer
platour22's Avatar
what are you wanting to see on the transmission, and i'll try and take a pic of it.
Old 04-22-2009, 11:05 PM   #166
Need LSx swap.....
Kampz69's Avatar
how did you install the seals, with the tool or "manually"? and did you ever get an answer to your "timed in" question, were the marks in the right spots in those pics earlier?
Old 04-22-2009, 11:19 PM   #167
no more blazer
platour22's Avatar
No! no one said anything about the timing. As far as the front seal just knock the old one out with a flat head and hammer. Then I just cleaned it real good, took a little oil and lube the seal and the front cover, then just used a rubber hammer and gently tapped it in. Went it real easy. Thats what the book said to do.
Old 04-22-2009, 11:37 PM   #168
On da bottle
zx9rgreen's Avatar
^^^ Some people install the cover so that the seal is concentric with the crankshaft. This way you get a even sealing area and better wearing of the seal.
Old 04-22-2009, 11:47 PM   #169
no more blazer
platour22's Avatar
so did i do it wrong steve.
Old 04-23-2009, 12:15 AM   #170
On da bottle
zx9rgreen's Avatar
that's up to you, they actually make a tool to center it, some people use shim stock or feeler gages.
Old 04-23-2009, 12:21 AM   #171
no more blazer
platour22's Avatar
you talking about the timing cover or front seal.
Old 04-23-2009, 12:28 AM   #172
no more blazer
platour22's Avatar
Heres more pics of the tranny as requested.
Old 04-23-2009, 07:05 PM   #173
no more blazer
platour22's Avatar
no major update just some parts that i got today.
Old 04-23-2009, 07:22 PM   #174
no more blazer
platour22's Avatar
Anyone know if I can remove the oil pressure sensor out of my truck valley cover, and install in the LS3 one.
Old 04-23-2009, 08:19 PM   #175
sprayed99's Avatar
should be the same part....
Old 04-23-2009, 09:38 PM   #176
no more blazer
platour22's Avatar
well i tried to see if it would plug in to the harness it didn't.
Old 04-23-2009, 09:40 PM   #177
Petro's Avatar
Why wouldn't it? I thought they were all the same for the Gen IV...
Old 04-23-2009, 09:48 PM   #178
no more blazer
platour22's Avatar
Good question! I hope my harness is right.
Old 04-23-2009, 10:06 PM   #179
Petro's Avatar
How many pins does the sensor have? And I found the part # for that bracket on that keep and share site...It's right above the Crank sensor...haha..Evem though it says it's for the 5.3 the pinout should be the same I'd think..
Old 04-23-2009, 10:10 PM   #180
no more blazer
platour22's Avatar
Painted the valley cover, cause it looked like shit. Now it looks like shit with paint on it.
Primed
Painted one coat
All my sensor im trying to figue out which are which. Wiring harness plugged in to two of them.
cam or crank sensor?
Oil Pressure sensor. All so all painted on Valley cover.
Old 04-23-2009, 10:14 PM   #181
no more blazer
platour22's Avatar
Not sure on the pin out I'll have to check later. Glad you found that part you need. You help me track down a few part numbers, so was trying to return the favor.
Old 04-23-2009, 10:18 PM   #182
Petro's Avatar
Now I need to figure out what size bolt that is holding the bracket on the bottom....Or maybe they would know when I went to go buy it...
For the harness plugging into the knock sensors I believe they will go either side but the passenger side will also have the crank sensor plug near the knock sensor plug..
Yeah no problem and thanks...
Old 04-23-2009, 10:30 PM   #183
no more blazer
platour22's Avatar
seams like i have more plugs on the harness, than on the motor.
Old 04-23-2009, 10:42 PM   #184
On da bottle
zx9rgreen's Avatar
^^^Cam Sensor^^^^
^^^Crank Sensor^^^
^^^Knock Sensor^^^
Hope that helps ya
Old 04-23-2009, 10:46 PM   #185
no more blazer
platour22's Avatar
yea it does thats steve, but i worried about the harness now. Cause I'm pretty sure the knock sensor won't fit in there.
Old 04-23-2009, 10:49 PM   #186
Petro's Avatar
Oops I guess I could've been more specific...sorry...What's wrong with the plug for the knock sensor?
Old 04-23-2009, 10:51 PM   #187
no more blazer
platour22's Avatar
i pretty sure it won't fit there. i think i tried it there.
Old 04-23-2009, 11:00 PM   #188
Petro's Avatar
Crank Senor plug:
Knock sensor plug:
Any of your plugs look like that?
Old 04-23-2009, 11:03 PM   #189
no more blazer
platour22's Avatar
Let me go take some pics of em, back in a few with them.
Old 04-23-2009, 11:33 PM   #190
no more blazer
platour22's Avatar
Unlabled
unlabled
Old 04-23-2009, 11:52 PM   #191
Petro's Avatar
Yeah I'd say those Knock sensor plugs are wrong....
Old 04-23-2009, 11:57 PM   #192
no more blazer
platour22's Avatar
My cam sensor and crank sensor fit no problem.
If these are knock sensors on both sides of the block then these plugs are wrong or i need different knock sensors. All so my oil pressure sensor don't fit.
Old 04-23-2009, 11:58 PM   #193
no more blazer
platour22's Avatar
that was my conclusion also.
Old 04-24-2009, 12:17 AM   #194
Petro's Avatar
I know what it is remember how jared said to use the GEN III valley cover? Well those plugs are for GEN III knock sensors .
Old 04-24-2009, 12:20 AM   #195
no more blazer
platour22's Avatar
hope i can just change them out if thats the case
Old 04-24-2009, 12:27 AM   #196
no more blazer
platour22's Avatar
you may be right Petro look at that link we been looking at. On page 5 last pic.
http://www.keepandshare.com/doc/view.php?id=837831&da=y
Old 04-24-2009, 12:27 AM   #197
Petro's Avatar
The GEN IV have 2 wires to the plug whereas GEN III are 1 wire
Old 04-24-2009, 12:30 AM   #198
no more blazer
platour22's Avatar
yea mine are 1 wire.
Old 04-24-2009, 12:31 AM   #199
no more blazer
platour22's Avatar
but if i change them will a gen III fit on the block.
Old 04-24-2009, 12:38 AM   #200
Petro's Avatar
I read something the other day about this . I'll see if I can find it again . Otherwise I'd contact jared.
Page generated in 0.65607 seconds with 31 queries
[Output: 215.88 Kb. compressed to 197.03 Kb. by saving 18.85 Kb. (8.73%)]
