#101 |
no more blazer
Re: Project: 5.3 4l65e 4 door blazer
Bump
#102 |
no more blazer
Well finally got it back on the ground 1st time in 2 months. Pretty much got the suspension wrapped up with the exception of the sway bar, still waiting on new linkage. It should be here in a day or 2.
Anyone know if I have the upper A arms on the right side. ![]() Here are the new Arp head and rod bolts that showed up today. ![]() ![]() ![]() Got it back on the stand for you steve when ever you have time to come over and help out with that cam and motor stuff. ![]() |
#103 |
Molon Labe
The A-Arms look on right to me.
#104 |
no more blazer
everything fit right, but they looked like they could go on either side. Just making sure.
#105 |
On da bottle
I'll be over there this weekend....Do you have a good 1/2" torque wrench? We will also need a 3 jaw puller for the dampner.
#106 |
no more blazer
I have a brand new torque wrench never used, no i don't have the puller, do you have one or do i need to get one.
#107 |
Rent it from autozone or oreillys
#108 |
On da bottle
The puller I have will not work with the stock dampner. You can loan one from autozone for around $15. Hell, I will just bring my torque wrenches just in case.
#109 |
no more blazer
thats cool. Is there a specific one i need to get.
#110 |
On da bottle
just a simple 3 jaw puller man......
#111 |
no more blazer
Okay i'll pick one up. What day did you want to do it.
#112 |
On da bottle
most likely Saturday
#113 |
no more blazer
okay thats cool. My dad wanted to be here to help also, he just wanted to know what day to take off. I'll pick that puller up tomorrow.
#114 |
no more blazer
Got my CPW radiator and condenser installed today. Fits in there pretty good, with a little triming.
![]() Heres the hood latch bracket, you have to cut and replace with another piece of metal included. ![]() You can see were i had to notch for the fittings on the condenser ![]() ![]() ![]() ![]() |
#115 |
looks like you are coming along great! cant wait to see it done.
#116 |
takes 2 balls in our game
Yea, making great progress
#117 |
no more blazer
Thanks guys trying to get as much done as i can until the motors ready.
I did get my sway bar linkage in today and got it installed. ![]() ![]() Just screwing around now (hoping). Just trying to see how much rome I have with the radiators and fans. ![]() ![]() ![]() ![]() ![]() Can ya'll tell i like taking pictures. |
#118 |
no more blazer
anyone know if this LS3 valley cover is the same as a LS2.
#119 |
Exact Match...
LS2 backside: LS2/LS7/LS3 have the same one. ![]() Last edited by Petro : 04-18-2009 at 12:10 AM. |
#120 |
no more blazer
I quess im getting it thanks
#121 |
It's looks similar just that the pcv system isn't on the ls2 version. Also don't forget the eight little o-rings that are needed for that valley cover. (I didn't see any in the picture but they may be included.)
#122 |
no more blazer
true i'll email him and see if he got them
#123 |
If the PCV system you are referring to is the tube on the front top of the cover not being on a LS2...Yes it is on all three LS2 , 3 , 7.... |
#124 |
no more blazer
I thought is was also. I thought LS1 was the only one without it.
#125 |
no more blazer
Well with the help of Steve (zx9rgreen) we tore down the motor today and installed the new valve springs (not pictured look the same as factory) and also got the arp rod bolts installed. Got to go pick up new lifter trays cause the other ones are set up for D.O.D.Heres some pics.
![]() Lost my torque bits so we couldn't install the cam today. ![]() Is it normal for the tops of the pistons to look black like this. ![]() ![]() ![]() New ARP rod bolts installed. Torqued to 45 ft.lbs incase someone wanted to know. ![]() Thanks for your help today Steve I learned alot. |
#126 |
Sucks that you lost the bits...Cool that you learned some stuff though..It would be nice if any of my buddies liked tech talk or even knew anything about engines...I've been reading so much about these motors that my brain is about to explode!!!
#127 |
On da bottle
and no problem with the hand man ![]() |
#128 |
Need LSx swap.....
nice man, looks good!
#129 |
For the pcv system, I was talking about the black box section under the valley cover, the valley cover I have is exactly like that, but without the black section. Sorry to clutter your thread with nonsense, so continue on with the good work.
#130 |
no more blazer
#131 |
Do you think those Spal fans will be quiet?
#132 |
no more blazer
probably quieter than the motor.
#133 |
I asked because I just noticed that those are straight blades and not curved. Let us know how quiet/loud they are...
#134 |
no more blazer
if i can figure out whats positive and negative on the fan plug i'll hook it up to a battery and do a video for ya.
#135 |
the elec fans i use to have from advance. hook one of them up to the + and the other to -. they might be puller fans that way. swap the wires. now they are pushers fans
#136 |
no more blazer
#137 |
Thanks man...Those fans move some major air...They don't seem to be too silent though...Oh well I still plan on using that setup..
#138 |
no more blazer
when the hoods closed it might be quieter
#139 |
True..Ls1s10onair has Jared's setup also..maybe he'll have some input since he got his running right today...
right now I'm trying to find out the best way to clean the intake and exhaust ports on the heads...I guess some carb cleaner and wiping it off will work..but I'm afraid of carbon chips falling into the cylinder... |
#140 |
no more blazer
yea that would suck. Are you upgrading any internal at all.
#141 |
I'd like to do a cam and head swap. But money wise for now it'll be easier to go stock. I've been reading about the L76 intake and L92 heads. They make some great bolt on power and the price isn't too bad...I guess we'll see how everything goes.
#142 |
no more blazer
remind me which one are the L92 heads. I have the 243's which one are those.
#143 |
On da bottle
#144 |
http://www.gmhightechperformance.com...ads/index.html |
#145 |
On da bottle
#146 |
Thanks for the tip... Yeah it'll be sitting for at least another 6 months...Just back them off far enough for the valves to close? Since it'll be sitting for a lil while and no oil being ran through it is there anything I should do? Or is just the same as a car sitting in storage and then starting it up?
Sorry to hijack you thread platour.... |
#147 |
no more blazer
no problem, good info to know.
#148 |
no more blazer
well me and my dad put the new cam in, also got my new lifter trays and come to find out they are the wrong fucking ones. I'm so tired of getting wrong parts. Can anyone tell which ones i have ( i suppose to have LS2), and which ones i need. Also what do i need to torque the ARP cam bolts to, summit said 26 ft. lbs.
I let my dad install it since he's the only one to ever do one. ![]() Heres the lifter trays, top ones are supposely LS2, and the bottom are the truck motor ones (notice the groove in the truck lifter tray). ![]() Here are the ARP bolts in the cam sprocket. Does everthing look like it suppose to. ![]() does this look in time to everyone, or does the marks have to line up perfect. ![]() and finally the new valve spring. ![]() Last edited by platour22 : 04-21-2009 at 10:34 PM. |
#149 |
Bottom ones are LS2 style..Just like mine..And that's cool building the motor with your dad..Wish I still lived back in Huntsville so I could do some of this with my dad...
#150 |
no more blazer
i knew they sold me the wrong ones. those bastards.
