Project: 5.3 4l65e 4 door blazer
Old 04-01-2009, 07:09 PM   #51
5.3 LSx bitches
1sic03x's Avatar
Re: Project: 5.3 4l65e 4 door blazer
Looking good. No notching with the Alpha pan and high mount A/C?
*Subscribed*
Old 04-01-2009, 11:24 PM   #52
no more blazer
platour22's Avatar
we will see i hope not.
Old 04-04-2009, 10:23 PM   #53
no more blazer
platour22's Avatar
Well got a couple of things done, not much. Still waiting on control arms. I also recieved a few parts.
Got the steering box sandblasted
Primed
Painted
Bolted back in, and also motor mounts in.
New Parts
Old 04-04-2009, 10:30 PM   #54
On da bottle
zx9rgreen's Avatar
Nice work man.....When are you going to start putting the engine in? I so need to get over there and check it out.
Old 04-04-2009, 10:45 PM   #55
no more blazer
platour22's Avatar
Putting the cam and shit in hopfully next week, and hopfully get it rolling again. Then we will drop it in. Home everyday come on over.
Old 04-09-2009, 01:36 AM   #56
no more blazer
platour22's Avatar
Well come to find out summit sent me the wrong bushings, so now im waiting on the new ones to come in so i can get it back on the ground. Also had bought new coil spring insulators from summit, and the guy said it came with a full set of 4, come to find out it was just 2 that cost almost 40 buxs, so i sent them back, no way i was paying 80 dollars for insulators. I just ordered factory ones. Also ordered new ARP head bolts, and rod bolts form texas speed, should be here in a few days then im going to start tearing in to the motor. Anyone have any good reading on cam, springs, and lifter installs. Its going to be my first time.
The insulators i sent back.
Used Gen III valley cover thanks to Steve (zx9rgreen)
Heres something on the old valley cover. Anyone know what these are and if I can elimenate them.
My lifter soaking in oil ready for install, thanks for the tip steve.
Heres the old oil filter i took of the truck pan that came with the motor. I bought a new one for the H3 alpha pan, but didn't fit. But this one also fit the H3 pan. Anyone know if its the same filter.
Old 04-09-2009, 02:35 AM   #57
Molon Labe
BudRacing's Avatar
I think you might have been a little confused about those isolators. The sleeves actually wrap around the base of the coil and the donuts sit on top of the coils. It's a pair of isolators for two coils. They're just a little bit different from the stock form.
Old 04-09-2009, 04:02 AM   #58
no more blazer
platour22's Avatar
REALLY! Well that stupid IMO. I'm glad i ordered the OEM's.
Old 04-09-2009, 09:31 AM   #59
The filter for a H3 6 cyl. is a PF61.....
The 6.0 should be the 48,
and the 5.3 in the alpha should be a 46...........\
I THINK!!!!!1
Old 04-09-2009, 10:46 PM   #60
On da bottle
zx9rgreen's Avatar
The tall round one is the oil pressure sensor....You need it. The small flat one is most likely the CPS (cam position sensor)
Old 04-09-2009, 11:59 PM   #61
no more blazer
platour22's Avatar
Where would i need to put new ones at. And steve what are those wires on the valley cover u gave me for.
Old 04-10-2009, 12:06 AM   #62
On da bottle
zx9rgreen's Avatar
Knock sensors that are located in the valley cover. Not sure how they are setup on that newer engine.?.?.?
Old 04-10-2009, 12:17 AM   #63
hr2impeach's Avatar
i am paying close attention to your install. i just haven't decide which way to go ls1/2. looks good so far. my 92 is a carbed '79 4 bolt 350/350 install
Old 04-10-2009, 12:25 AM   #64
no more blazer
platour22's Avatar
Well summit dissapoints me again and tells me my bushings were on back order, so i just got replacements from autozone. Also got the arms sprayed and should have it rolling tomorrow. heres a couple of pics.
The new replacement insulators from the dealer
Insulators part number
New CNC idler pulley relocator bracket.
Old 04-10-2009, 12:31 AM   #65
no more blazer
platour22's Avatar
Hopefully soon i will be getting some real work done. If i were you i would get a 6.0 for sure, i just ran across this motor and didn't take my time looking. But it all depends on what your looking to spend. But they are all expensive really. I have already over $6,000 in it at this point.
Old 04-10-2009, 12:33 AM   #66
Petro's Avatar
How much were the spring insulators from dealer? Are you cleaning the rest of frame and spraying it ? Oh yeah and have you thought about doing the flaming river steering u-joint mod while you have everything apart?
The guy I just my motor from said he plans on grabbing up some more wrecked GTOs..(according to him they are plentiful down in florida)
Old 04-10-2009, 12:40 AM   #67
hr2impeach's Avatar
i have access to a 99 camaro (complete car w/ LF damage)with the ls1 and t56 for $4000, good or bad? 100K on the motor and +/- 8k on the trans
Old 04-10-2009, 12:51 AM   #68
Petro's Avatar
I know where you could get the same setup with same miles for $1800...But in my opinion not a good deal...there a lots of good setups on ebay with lower miles for same or less. Also many LS2/T56 setups for that much with low miles.
Old 04-10-2009, 12:52 AM   #69
no more blazer
platour22's Avatar
Insulators were $40 for all of them. I'm not a 100% but they might be polyurethane. Not really familar with the flaming river steering u-joint mod. What exacally is that.
Old 04-10-2009, 12:55 AM   #70
hr2impeach's Avatar
thanks, you would think that living near mexico would be cheaper...not the case, they sell all their stuff to south of the border for more than what most stateside will pay. case in point
Old 04-10-2009, 12:57 AM   #71
Petro's Avatar
It gets rid of the rag joint coupling on the steering shaft and uses a billet
u-joint for greater durability/response... I plan on doing it...And if you hadn't already painted and sandblasted the steering box I'd say get a ZQ8 box..Sorry I tend to get out of hand with ideas...
http://www.s10forum.com/forum/f178/h...ng-mod-395639/
Old 04-10-2009, 01:05 AM   #72
no more blazer
platour22's Avatar
Damn that is pretty nice. If I can squeese out another $100 i might do it.
Old 04-10-2009, 01:09 AM   #73
Petro's Avatar
Come on money is nothing when you've already spent $6000.00 right... Though you may like it...
My wife is already tired of me buying stuff and I'm nowhere as deep into my pocket as you. She's probably going to end killing me in my sleep..
Old 04-10-2009, 01:19 AM   #74
no more blazer
platour22's Avatar
yea i been doing all this while layed off, and on unemplyment. Also with the help of my dad. He's been chipping in on it also cause he's always wanted to do something like this. If i go back to work then money won't be an issue anymore. But i might go ahead and do it. Where do you buy that steering knuckle.
Old 04-10-2009, 01:27 AM   #75
Petro's Avatar
just google flaming river and make sure you get this part #FR1746DD 1"DD X 3/4"-30 / when you order..If you do get it...I made sure to ask in the thread about the right part #.
Old 04-10-2009, 02:08 AM   #76
Molon Labe
BudRacing's Avatar
I believe Summit sells the joint. Just enter that part number in the search and it should come up.
Old 04-13-2009, 01:19 AM   #77
no more blazer
platour22's Avatar
I think im going to get this when i return to work if it will work. I think it will.
Its $6,300 though
http://images.stylintrucks.com/handl...0xJm09MTMmbz0w
Old 04-13-2009, 02:44 AM   #78
You're going to need the newer valley cover off of a 07' and newer truck without displacement on demand. I don't believe the one you have will work on that motor since its the older style, and has the holes for knock sensors, while your motor the knock sensors should be on the sides.
But i also thought all the newer motors had the front mount cam sensor so I'm not quite sure maybe some one else well chime in and shed some light on the situation.
Old 04-13-2009, 02:53 AM   #79
no more blazer
platour22's Avatar
my motor is an 07' and i still have the valley cover. That blower is for a newer motor i believe. I just saw it on a new silverado in the new Truckin mag. It could be a different one though.
Old 04-13-2009, 04:21 PM   #80
Yea the original cover you had was for a displacement on demand vechicle, you need the other cover that is for non displacement on demand, its smooth and will only have one plug (oil pressure). Yours has two plugs (oil pressure and displacement on demand). I hope this helps some, sorry if its confusing.
Old 04-13-2009, 06:46 PM   #81
no more blazer
platour22's Avatar
my gen III valley cover doesn't have any plug on it except for the knock sensor holes.
look at the second pic in post 56
Old 04-13-2009, 06:51 PM   #82
Petro's Avatar
So will the LS6 style valley cover not work? Why were you chaning them?
Old 04-13-2009, 08:27 PM   #83
no more blazer
platour22's Avatar
I was told i had to change from a Gen IV to a gen III valley cover to do my swap. Personally i don't know the reason behind it. But Jared and Phil both said I had to. But I quess if i upgrade to that blower i'll have to run the Gen ?IV valley cover. I'm also worried about the sensors on top of them. The Gen III does have the same ones as the Gen IV.
Old 04-13-2009, 08:38 PM   #84
Petro's Avatar
What to do with where the knock sensors go on the LS6 style cover? The LS2 style cover just has the oil pressure sensor on it...Does your timing chain cover have a sensor on it also?
Old 04-13-2009, 09:56 PM   #85
no more blazer
platour22's Avatar
maybe i need an ls2 style valley cover.
Anyone have a pic of one.
Old 04-13-2009, 10:04 PM   #86
Petro's Avatar
Here's the LS2 style...And I the one you have pictured in post #56 is the LS1...
Here is a pic of the differences in the LS1 and LS6
Old 04-13-2009, 10:37 PM   #87
no more blazer
platour22's Avatar
Yea i think i need the ls2 one. would i need a different timing cover for the crank sensor
Old 04-13-2009, 10:56 PM   #88
Petro's Avatar
Your timing chain cover look like this? I wonder why you can't use your original valley cover...????
Old 04-13-2009, 11:15 PM   #89
On da bottle
zx9rgreen's Avatar
he has some kind of sensor on the front cover
Old 04-13-2009, 11:20 PM   #90
Petro's Avatar
Like the sensor on this timing cover?
Old 04-13-2009, 11:33 PM   #91
On da bottle
zx9rgreen's Avatar
that's it
Old 04-13-2009, 11:38 PM   #92
Petro's Avatar
I don't know why he couldn't use his stock valley cover...But I'm still a newbie at these engines..Anyways I'd say the LS2 style valley cover would be what you were looking for if you can't use the stock one...
Old 04-13-2009, 11:45 PM   #93
no more blazer
platour22's Avatar
i'm waiting a response from jared to see if he knows
Old 04-14-2009, 12:58 AM   #94
no more blazer
platour22's Avatar
Petro:
Do you have a part number for that LS2 valley cover.
Old 04-14-2009, 09:39 AM   #95
Petro's Avatar
Not right now but I'll find out...
Old 04-14-2009, 12:40 PM   #96
Petro's Avatar
I just read that the LS1/LS6 style valley cover will not work with any GEN IV LS engine...
12570471= LS2/LS7 style vally cover
Old 04-14-2009, 10:29 PM   #97
no more blazer
platour22's Avatar
Well after fighting with my coil springs and trying to get them back in i decided to order lowering springs. Well i went with summit again cause i new they would be here in a 2 days. Well all they had in stock was a 1 inch from DJM. So they arrived today and had the same trouble. Since the motor wasn't in it, i didn't have enough weight. So I decided to go ahead and set the motor in the truck for extra weight plus it gave me an idea of how everything was going to fit up. Putting these coils back in has been a mother F**cker. But anyway heres a few pics.
DJM 1 inch coils
Motor test fit (Gives me motivation)
Coils installed
Old 04-14-2009, 10:39 PM   #98
Petro's Avatar
Any answers from Jared on that valley cover issue?
Old 04-14-2009, 10:40 PM   #99
On da bottle
zx9rgreen's Avatar
Looking good Paul, has your dad ordered the nos kit? HaHaHa...
Yall talked to the kid with the mustang about bringing it to the track
Old 04-14-2009, 10:48 PM   #100
no more blazer
platour22's Avatar
No he didn't answer it, I guess i'll have to call him. But he doesn't answer the phone half the time.
No NOS yet. I haven't seen that guy since i haven't been to work. But let me know in advance when your headed to the track and I'll give him a call. But he was rebuilding a motor for it, so it might be tore down.
Page generated in 0.66127 seconds with 31 queries
[Output: 218.10 Kb. compressed to 199.22 Kb. by saving 18.88 Kb. (8.65%)]
