Project: 5.3 4l65e 4 door blazer
Old 03-07-2009, 03:58 PM   #1
no more blazer
platour22's Avatar
Well some of you probably seen me post a few times asking questions. So since the parts are starting to come in i'm starting a project thread. I recently bought a 07' 5.3 with a 4l65e with 6k miles on it. My goal is to have this thing completed by the end of summer, so stay posted. I will be updating as i go. I'm aslo new to the swap so, any advice as i go along will help. Thanks Paul. Now on with the parts.
The motor
The tranny
The Cam
Cam Sprocket gear, gaskets, and new cam bolts.
Cam specs.
New Pushrods and valve springs
New timing cover gasket
The LS6 intake I bought used with fuel rails, injectors, and throttlebody.
New intake bolts
And this is where im at. So far I just got the motor pulled, and will be cleaning the frame up while the parts are getting installed in the motor.
Old 03-07-2009, 06:18 PM   #2
Need LSx swap.....
Kampz69's Avatar
Re: Project: 5.3 4l65e 4 door blazer
nice man, good luck!
Old 03-07-2009, 06:52 PM   #3
Build them right....Mod
philntx's Avatar
Does your engine have D.O.D (displacement on demand)?
If it does, then, you'l also need a valley cover from a Gen IV, non-DOD engine.
All Gen IV engine blocks have the special oil ports that go from the valley
area down to the lifter bores. Non-DOD valley covers have no oil feed and of course, no solenoid valves.
Plus, they simply block off these lifter ports with O-rings.
A valley cover from an LS2 Corvette will work great.
I see you have new lifters, make sure you use the appropriate lifter guides as well.
Old 03-07-2009, 07:26 PM   #4
chevysten's Avatar
You have a good start!I noticed you know (zxr9green)Steve.Super nice guy.I'm sure if you have any probs he'll give you a hand.
Old 03-07-2009, 09:10 PM   #5
On da bottle
zx9rgreen's Avatar
Hey phil will the Gen III valley cover not work? Are the knock sensors different on that 5.3?
Paul If the 3rd gen valley will work I have one you can have!
Man thats a nice set of parts there. I need to get over there and check it out.
Old 03-07-2009, 10:38 PM   #6
philntx's Avatar
If this motor has DOD, he'll just need to swap the valley plate for one that didn't have it. Yes, a Gen 3 will do it.
Old 03-08-2009, 01:48 AM   #7
Former S10 enthusiast
01cherryreds10's Avatar
I beleive they in fact did start putting DOD on the 5.3's in 07. If it is a DOD, couldn't he just disable it by replacing the 4 DOD lifters with the same 4 non DOD lifters and use a valley cover from a pre- 07' engine?
Old 03-08-2009, 07:28 AM   #8
no more blazer
platour22's Avatar
Yea i believe the motor has D.O.D. Cause when I talked to jared he said change the lifters and valley cover. I also have the lifters but forgot to post them. They are LS7 lifters, i'll get a pic up today. Still waiting on a bunch of stuff from jared so I'll get pics of that stuff when it shows up.
My shop flooded the other day so i been trying to dig drainage and put up gutters on the front. I'm going to try and start cleaning the frame up today.
Steve if you aint got nothing to do this afternoon hit me up. I been working alot so i don't get much time at home. But I should be here today.
Old 03-08-2009, 10:33 AM   #9
takes 2 balls in our game
s10-den's Avatar
Yea, nice little project underway....
Old 03-08-2009, 11:06 AM   #10
On da bottle
zx9rgreen's Avatar
Yea, I will probably do that man....I dont have you # anymore so either give me a buzz or PM your cell #.
Old 03-08-2009, 02:44 PM   #11
no more blazer
platour22's Avatar
315-1102
Old 03-08-2009, 04:37 PM   #12
On da bottle
zx9rgreen's Avatar
315-1102
Hey Paul I have a honey do list about a mile long, so it's doubtful I can make it over this evening.
Old 03-08-2009, 05:31 PM   #13
no more blazer
platour22's Avatar
ok man thats cool. hit me up later.
Old 03-08-2009, 07:32 PM   #14
Sell those lifters on eBay I'm sure you'll get some good cash back from them
Old 03-08-2009, 09:33 PM   #15
no more blazer
platour22's Avatar
Well heres a small update. I stripe pretty much everything off the front, but didn't have time to clean it.
My new GM LS7 lifters
Heres the parts pile. I'll keep most of it.
I've asked once and didn't get a straight answer. What is the purpose of this thing. I was told it is for emissions, but what does it do. And do I need to keep it. We don't have emission checks in AL.
And my last pic for today is my shop, in case anyone cares to see it.
Old 03-08-2009, 10:19 PM   #16
Molon Labe
BudRacing's Avatar
Looks like the air pump. It pretty much injects air into the exhaust manifolds to cut down on emissions when the engine is cold. They fail often and are expensive to fix. Get rid of it.
Old 03-08-2009, 10:28 PM   #17
no more blazer
platour22's Avatar
ok its gone thanks
Old 03-08-2009, 10:52 PM   #18
Petro's Avatar
And that's why I can't wait to move back to BAMA...No emissions test and better yards to go picking around in for good finds..
Old 03-08-2009, 11:47 PM   #19
Piece of shit air pumps
Old 03-09-2009, 10:54 AM   #20
Molon Labe
BudRacing's Avatar
There are emissions tests in Savannah?
Old 03-09-2009, 08:42 PM   #21
Petro's Avatar
I was told that if I used the Ad Valorem Tax and got a GA license plate and registration...that I would have to do some sort of emissions...I have no idea what it would consist of..but I kept my AL plates...
Old 03-10-2009, 01:08 AM   #22
no more blazer
platour22's Avatar
Did a little bit of cleaning on the frame today. I still have a little left to do, but most of it is clean. I haven't decided if Im going to paint it or undercoat it again. I'm thinking the undercoating will hold up better. I should be getting parts in this week from jared. I'm waiting on the oil pan to start the motor.
Heres my dad helping me clean
Heres the results
Heres what I used
Old 03-10-2009, 11:31 AM   #23
Need LSx swap.....
Kampz69's Avatar
you going to keep the engine mount "pads" or get rid of them?
Old 03-10-2009, 12:59 PM   #24
no more blazer
platour22's Avatar
what is that. i don't know what you are refering to.
Old 03-10-2009, 01:14 PM   #25
customchevys's Avatar
Looking good you have more patience than I do I used wire wheel for couple minutes and decided just to sand blast the frame, but I am doing the whole frame.
Old 03-10-2009, 01:20 PM   #26
On da bottle
zx9rgreen's Avatar
He is probably refering to the pads where the stock motor mounts mount to the frame. They are raised compared to the trucks> I am at work but look at your mounting location and find the same from a truck. It would lower the engine for better handling.
Old 03-10-2009, 01:23 PM   #27
On da bottle
zx9rgreen's Avatar
Do you still have the driveshaft from that s-10 laying around?
Old 03-10-2009, 01:51 PM   #28
Need LSx swap.....
Kampz69's Avatar
zx9 just answered it for me. you can see them in your pics, they are the triangular looking pieces on the frame that the motor mounts attach too. as far as i know they dont have to be removed (they definitely help with oil pan clearance), though the motor will sit higher.
Old 03-10-2009, 04:27 PM   #29
no more blazer
platour22's Avatar
I think i'll leave them in there, since they are welded in. Plus like you said it helps with oil pan clearance. I just hope nothing hits the hood.
Steve, yeah i still have it you need it.
Old 03-10-2009, 06:05 PM   #30
On da bottle
zx9rgreen's Avatar
you have PM
Old 03-10-2009, 06:57 PM   #31
no more blazer
platour22's Avatar
Well pretty much finished up the cleaning of the frame today. Still needs a touch up here and there but I ran out of undercoating. I'm real pleased the way it came out. Looks a lot better in person. Now I need to figure out how to clean the damn shop floor lol.
After claening I prep the frame with this just to remove as much grease as possible.
Then I used 3M undercoating to spray the frame
also cleaned up the coils with some degeaser.
In the process of sandblasting the control arms. I plan on puting all new enegry suspension bushing in them and the sway bar.
Old 03-10-2009, 07:34 PM   #32
On da bottle
zx9rgreen's Avatar
looking good Paul, Do you have a press to replace all those bushings? I rebuilt my front end before my swap and I went out and bought a harbor frieght press. You are more than welcome to borrow it if you need it.
I will also trade you, your PM box was full.
Old 03-10-2009, 07:38 PM   #33
96S10BlazerGuy's Avatar
Excellent project, looking forward to seeing the finished product.
Old 03-11-2009, 12:30 AM   #34
no more blazer
platour22's Avatar
Yea i'm might take you up on that. Will it also press in new balljoints. Also where did you buy your new bushings. I found one place, but looking for some place cheaper if possible.
Anybody need a motor lol.
Old 03-11-2009, 12:49 AM   #35
On da bottle
zx9rgreen's Avatar
I dont remember the name but I have a catalog around here somewhere. I just bought a complete kit with everything including balljoints, bushings, sway bar stuff, steering stuff.
Yea I used it to press the old ones off, I think the new ones are bolt on somehow. It has been about 4~5 years ago so kinda hard to remember
Old 03-11-2009, 12:56 AM   #36
no more blazer
platour22's Avatar
no problem. heres the place im looking, just scroll down to see the bushings.
http://www.ultrarev.com/search.php?mode=search
Old 03-11-2009, 11:04 AM   #37
Petro's Avatar
Frame cleaned up nicely...Does that 3M Undercoating have a sticky/gooey feel after it had dried?
Old 03-11-2009, 11:09 AM   #38
Need LSx swap.....
Kampz69's Avatar
looks good man
Old 03-11-2009, 11:19 AM   #39
no more blazer
platour22's Avatar
No it don't. it feels solid.
Old 03-11-2009, 01:39 PM   #40
On da bottle
zx9rgreen's Avatar
Man I got some SEMS undercaoting free from my buddy and that crap still doesnt feel dry 2 years later. Also after I pulled the motor after my incident, that stuff attracts dirt like crazy and is very hard to clean.
Old 03-11-2009, 09:57 PM   #41
Petro's Avatar
it would be cool to coat the frame in Line-X or Rhino liner...
Old 03-12-2009, 12:35 AM   #42
no more blazer
platour22's Avatar
Sandblasting this shit is time consuming. It took me damn near 50lbs of sand to do one control arm. But anyway got it sprayed and bushing for control arms and sway bar are on the way. Also ordered new power performance upper and lower balljoints. As soon as they arrive, i'll get them pressed in and get a pic up, but heres one of the lowers.
Old 03-14-2009, 12:02 AM   #43
no more blazer
platour22's Avatar
got some parts in from Jared today. Not really impressed with the headers, but i guess they will work.
H3 Pan with dipstick and tube, and windage tray.
New high mount A/C compressor Kit. I really like this kit, comes with all aluminum brackets.
And heres some pics of the headers and motor mounts.
Are they suppose to be like this or did someone forget to grind them down. Or does it even really matter.
Doing a little test fitting, not permenant. Still need to paint them.
Still waiting on a few things but pretty much have most of the stuff for the motor. We will start putting everything on and in the motor maybe next week some time. I also recieved new bushing for my control arms but still waiting on the new balljoints. I'll keep ya'll posted.
Old 03-14-2009, 12:14 AM   #44
On da bottle
zx9rgreen's Avatar
That A/C set-up is nice....what did that cost ya? I know the hoses are $225
The sanderson headers leave some to be desired. Jared made some nice ones in house but the $$ is hard. I will temp to fab my own headers up in a year or two when I go FI.....
Old 03-14-2009, 12:23 AM   #45
no more blazer
platour22's Avatar
I think the A/C kit was 397.00
Old 03-14-2009, 01:19 AM   #46
On da bottle
zx9rgreen's Avatar
^^^ Boy my post has some bad english......That's what happens when your wife is nagging you!
Old 03-14-2009, 02:01 AM   #47
no more blazer
platour22's Avatar
Yea I got one of those! Technically she isn't my wife yet, but shes pregnant and she moody All the damn time.
Old 03-14-2009, 09:20 AM   #48
Petro's Avatar
I like the A/C kit too...That's the route I want to go when I do my swap..Other than the FRCs not clearing the truck coils...If you had the LS2/LS1 coils wouldn't the FRCs still fit with the high mount kit?
Old 03-29-2009, 07:39 PM   #49
On da bottle
zx9rgreen's Avatar
PAUL......any updates on this
Man I need to get over there and swap those parts out and pick up that dash.
Old 03-29-2009, 10:00 PM   #50
no more blazer
platour22's Avatar
Waiting to get my control arms back from the mechanic shop, hopefully tomorrow. They are pressing in the bushing and balljoints for me. Also still waiting on parts from jared, i figured they would be here by know. As soon as i get the control arms back i'll get it rolling again. Then begin on the motor.
Feel free to stop by anytime Steve, I haven't gone back to work yet so im pretty much home all day.
Page generated in 0.66643 seconds with 31 queries
[Output: 225.34 Kb. compressed to 206.45 Kb. by saving 18.89 Kb. (8.38%)]
