#101 |
Whats this for?
Re: Project: 1st Gen Six Speed
more than six grand, close to seven
#102 |
I was thinking 6 i guess i was close. So ur uploading a video right now right??
#103 |
I got an ACT 6 puck clutch, good for 925 ft/lbs of torque. First day i had it in, i got stuck in STOP AND GO bumper to bumper traffic... THAT SUCKED!!!!!!!!!!!!! but after 2-3 weeks of driving it, it has simmered down alot. Be patient, mine used to not slip for anything, it's pretty streetable now with a trained foot, and that it has broken in. it used to chatter so badly that the truck would shimmy like a 16 year old learning how to drive a standard for the first time. |
#104 |
by the way, you're still less invested than me!!!! (11k+) haha. You also don't have a rear end swap, and turbo.
Good job on keeping the swap price down. I even got my engine for free~ Last edited by turbobandit : 11-03-2009 at 10:46 PM. |
#105 |
Whats this for?
Yea im alot better at the clutch now haha took me a day of driving, but she does like to chatter alot right now. Also still trying to find out whats up with my rear taillights. Found out something new, when i turn my turn signal to turn left or right the hazards come on......idk what you even look for since we didnt change the wiring harness for that, maybe im missing a ground somewhere for the lights??
#106 |
i know we have very different trucks, but just a suggestion:
On the 2nd gens, there are two grounds for the lights on both sides of the radiator core. I know yours was out and you were painting it, so wouldn't hurt to check those grounds. There should also be one ground on the rear of your frame under the bed. Drivers side? Again, this is 2nd gen stuff, idk if it's the same for you. my brake lights were acting all funky as well until i fixed that junk |
#107 |
Whats this for?
yup! you were right, i checked the back one and it was tucked up in the bed from us taking the bed off, so she's fixed now!
#108 |
and my clutch leg thanks me ![]() |
#109 |
its always the most ovious thing!!
#110 |
Awesome truck man. I def wanna do this some day
#111 |
Whats this for?
yea and when i give it gas in second it seems to stutter then go then stutter then go...idk hard to explain.
also when im in neutral, off the clutch, it makes a weird scrapping sound sometimes but not always, until i push in on the clutch it goes away, could it be the throwout bearing? |
#112 |
Doesn't it have a hydralic throwout bearing?
#113 |
my throw out bearing is always against the clutch pressure plate~ and it's hard to shift at high RPM in 4th / 5th gears.
think i need a better master cylinder. The act clutch is good for 925 ft/lbs... think i need a stronger master cylinder |
#114 |
Whats this for?
mine try's to go into reverse when i go to 5th so i dont even have a 5th gear right now.
Yea my throw out bearing is always against the clutch pressure plate to but i was told thats normal. Not sure what master to look for though, what master you lookin for turbo? |
#115 |
Whats this for?
Couple more problems i think....
When i touch the gas and let off it starts to idle up real slow to about 1500rpm sometimes 2000, and then slowly goes back down? sometimes it will just stay up there where ever it decides to stop. Also i have a squeaky sound from the transmission, but as soon as i touch the clutch pedal it goes away? what could that be |
#116 |
On the high idle has the PCM been programmed for correc VE, injector sizes, etc.?
On the trans squeak it may be a dry throw-out bearing or maybe even a input shaft bearing a lil worn? |
#117 |
Whats this for?
What could i do for the squeak? sounds like i would have to take the transmission out? Also it gets faster and louder if i turn a corner. |
#118 |
Whats this for?
how about the IAC for the idling issue?
#119 |
Whats this for?
think i found the issue,
the constant squeak is from a pulley but it just disappeared.... and for some reason the hoses weren't tight enough so some of them were leaking cause it to get a little warm, so hopefully she will run better after she gets some new water in her. |
#120 |
why not post up some videos damnit!
#121 |
^^^Haha...I said the same thing over on Tech...He said he's trying to get his buddies camera....
#122 |
A) pics B) videos haha. He better get on it, fast! |
#123 |
Whats this for?
hey now take it easy on me, im still trying to fix another break in the road before a video.
When warmed up, as i lay on the gas i get to maybe 70% throttle and it starts to hold back. But if its cold it wont do this, any idea whats going on? |
#124 |
#125 |
I can fix all ur problems!! just give it to me..
#126 |
Whats this for?
http://www.racetronix.com/product/RX..._Pump_Kit.html When i had there harness hooked up the pump was getting power until i hooked it up like it was stock without there harness. Im wondering if its getting lean or something, but it doesnt do it when its cold. |
#127 |
Whats this for?
#128 |
#129 |
Whats this for?
After alot of people responses from here and over on ls1tech.com, it seems to be a vacuum leak.
Whats the best way to test for vacuum leaks and to figure out where its coming from. |
#130 |
My tried and true method is to spray all the vacuum connections with starting fluid or anything flammable while the motor is idling. A change in idle speed indicates a leak at the connection you just sprayed.
#131 |
Mr Spree... i hate you...
I give you advice to fix your brakes, AND NOW MINE ARE FUBAR!!!! Mine worked for months, just the other day something happened. my right rear tail light shuts off instead of blinking on... but only messes up when the headlights are on. And it switches w/ BOTH reverse lights.... Hmmmmmmm. Anyway, I'm not sure what clutch master cylinder i want to use, but the 2.2L s10 master isn't enough. Does anyone know if there's a diff between the 2.2L s10 and the 4.3L s10 clutch master cylinders?? And i had that same idle issue with Jared's PCM. once i got tuned, and put my bigger injectors in (60#'s,) the issue went away. The MAF's alot of the time are different voltage charts through LS1 years, and that was the issue i had. (said the tuner) |
#132 |
Can I Atleast Get A Video Of It At Idle???? Ur Fuking Killing Me....
#133 |
Whats this for?
So changing my MAF could fix the problem if there is no leak?
I tried using propane to see if the idle would change and it never did anywhere i put it Damn you people and videos! Send me your video camera and i will post a video haha ![]() |
#134 |
Here ya go the best money could buy...I want it back when you're done with it....
#135 |
Whats this for?
haha as long as it works
#136 |
Whats this for?
sprayed carb cleaner on all the vacuum hoses and what not and the idle didnt change.
Maybe i just need a tune? Would the IAC cause a problem like this? |
#137 |
It could.
#138 |
prob not a vaccuum leak, just need a tune
