Project: 1st Gen Six Speed
Old 10-14-2009, 11:35 PM   #51
Whats this for?
mr spree's Avatar
Re: Project: 1st Gen Six Speed
Quote: Originally Posted by llorracs93s10
x2 on that. I did take a small sheetmetal piece, siliconed the old shifter hole shut and than pop rivet'ed it shut.
yea i did the same thing with the old shifter hole. i wonder what i could do to fill around the shifter
Old 10-15-2009, 12:59 PM   #52
That looks a little too far back for me, im using split bench seats out of a newer extreme so i think the shifter might get in the way of those if i leave it like it is. I guess ill just have to use the shifter reloction kit i bought. Ill be using the stock rubber boot to with a kiesler shifter and custom throw arm. Im pretty sure if i move the shifter to the front inspection cover that i can use the stock hole so that should be nice. Thanks for pics!!
Old 10-15-2009, 06:05 PM   #53
turbobandit's Avatar
i know how to fix it...
THEN... throw some of these in.
My shifter only had to be moved back about 4-5 inches. It's a 2nd gen though
Old 10-15-2009, 06:06 PM   #54
Also... isn't there a differance between a GTO and an F body shifter? One farther forward than the other?
Old 10-15-2009, 06:21 PM   #55
Whats this for?
mr spree's Avatar
Yea the GTO shifter Is further back if i remember right.
How did you go about sealing around the floor and the shifter?
Old 10-15-2009, 09:39 PM   #56
Whats this for?
mr spree's Avatar
Here are the headers installed. The collector on the driver side will need to change though since it wont allow the Oil Filter to screw on.
Passenger Side:
Driver Side:
Old 10-15-2009, 09:57 PM   #57
chaospartners's Avatar
Damn this is going to be sweet!!
Old 10-16-2009, 03:20 PM   #58
Any new progress?
Old 10-16-2009, 03:24 PM   #59
Whats this for?
mr spree's Avatar
No pictures yet. ill be out there running fuel lines and installing the radiator into the core support
Old 10-16-2009, 03:31 PM   #60
Random question but what tire size are u running on ur factory wheels!
Old 10-16-2009, 03:37 PM   #61
Whats this for?
mr spree's Avatar
235/60/14
...yes im still rockin the 14's and i like them very much haha
Old 10-16-2009, 07:50 PM   #62
They done look to bad with the right size tire, im gon be taking my wheels off soon and need some new tire on my factory wheels and i think urs look good!!
Old 10-16-2009, 08:35 PM   #63
art
art's Avatar
what headers are you using? did you get brp headers along with the cross member?
Old 10-16-2009, 10:59 PM   #64
Whats this for?
mr spree's Avatar
no i got the headers from s10v8.com
Old 10-16-2009, 11:00 PM   #65
Any new pics?
Old 10-16-2009, 11:07 PM   #66
Whats this for?
mr spree's Avatar
nope! hooked the fuel lines up and trying to find the best way to go about installing the radiator. It doesnt go in as nicely unlike 2nd gens
Old 10-17-2009, 01:07 AM   #67
Same as you... i used that big foam donut from the stock shifter.
The forward section, i used some sheet metal, and tack welded around the edge. Then used Home Heater Ducting tape to seal it up. Then put some 1" thick insulation, then more ducting tape. so its pretty much water proofed.
Old 10-17-2009, 02:11 AM   #68
Whats this for?
mr spree's Avatar
i dont have that foam thing anymore so i havent sealed it yet
Old 10-18-2009, 04:08 PM   #69
llorracs93s10's Avatar
did you get the ''forward position'' mounts for the radiator from JTR? I dont remember seeing what u said u were using for a radiator, but i used their aftermarket late 80's vette radiator and than i just trimmed the bottom of the support than put a new hole in the top.
Old 10-18-2009, 09:01 PM   #70
Whats this for?
mr spree's Avatar
i have the radiator from CPW which sits inside the core support already and uses the stock stuff to keep it in
Old 10-18-2009, 09:13 PM   #71
gotcha. Well looks like your spending ur money right, so keep that going, dont skimp on things, or else u will regret it like i did with my PS pump, lol
Old 10-18-2009, 09:28 PM   #72
Whats this for?
mr spree's Avatar
what happened with your PS pump?
Old 10-18-2009, 11:15 PM   #73
i didnt replace it even thought it was making noise, and it just crapped out on me, so instead of swapping it out after the motor was pulled out to get rebuilt, i didnt so even though it wasnt like it was a big deal, its stuff like that you dont want to over look. If u need to replace it, do it now rather than wait til later
Old 10-18-2009, 11:29 PM   #74
So will it be a pain in the ass to take off?
Old 10-19-2009, 03:28 AM   #75
Whats this for?
mr spree's Avatar
ah i see! yea ive ran into a couple things along the line of that on this build. Like you said if there seems to be a problem....fix it before moving onto something that will only make fixing that harder or more time consuming
Old 10-19-2009, 03:37 PM   #76
its already done. I am just saying, it easier to replace a PS pump, water pump, egr valve, ect. with the motor out of the bay rather doing it in the engine bay. I am not saying replace everything and everything, but if u know something could or looks like its bad, doesnt hurt to do it now so u dont have to down the road. You know wat i mean
Old 10-22-2009, 06:25 PM   #77
Whats this for?
mr spree's Avatar
some updates. its almost done, just putting the front back together and hooking up hoses and such. hopefully it starts!
oh and anyone have a cowl hood that would like to give me? maybe sell me.....
Old 10-22-2009, 09:07 PM   #78
u can buy mine, so i can get a 4inch cowl hood, lol
Old 10-22-2009, 10:14 PM   #79
NCRides's Avatar
go fiberglass so you won't have to cut the inner frame to clear the alternator and throttle body...looking good
Old 10-22-2009, 10:48 PM   #80
Whats this for?
mr spree's Avatar
is it fiberglass? pm me
Old 10-22-2009, 10:55 PM   #81
Dude ur truck is awesome!! please make us a video of it running!! have u even had it started in the truck yet
Old 10-22-2009, 11:14 PM   #82
Whats this for?
mr spree's Avatar
no havent tried starting it yet
Old 10-23-2009, 05:39 PM   #83
On da bottle
zx9rgreen's Avatar
looking good man.....
Old 10-23-2009, 08:19 PM   #84
nope, not fiberglass, steel.
Old 10-27-2009, 02:47 AM   #85
Whats this for?
mr spree's Avatar
front end is pretty much done. its really hard to work on it when its RAINING outside...
Old 10-28-2009, 02:14 PM   #86
looks awesome
Old 10-28-2009, 03:16 PM   #87
coming along great man! Few more things, and you'll be ready for a joy ride!!!
I remember i had NO front end on, bed wasn't on, and battery wasnt even tied down... Soon as i got everything engine wise all done, i did a 100 foot burnout up my street! hahaha. Battery fell off, was draggnig on the ground, i found tools that fell out of somewhere all up and down my street... but dang, you have more patience than me! haha.
Old 10-28-2009, 09:58 PM   #88
that motor fits really nice in there to!!
Old 10-28-2009, 10:17 PM   #89
1993 S-10 EL 4.3L
dcoogan's Avatar
how about a youtube video of it in action ?
Old 10-28-2009, 11:53 PM   #90
Whats this for?
mr spree's Avatar
Well its all done! just need to hook up the computer and start her up. I cranked it with the ignition without the computer hooked up just to make sure she would crank haha. Intake should be here tomorrow and then off to the exhaust shop.
oh yea...truck accesories with the stock hood
Old 10-29-2009, 07:53 PM   #91
nice man, im going to go out on a limb and say ''sleeper'' by the looks of the truck, lol. And did you do all this outside in ur driveway? if so mad props.
Old 10-29-2009, 09:06 PM   #92
Whats this for?
mr spree's Avatar
sure did man, thanks!
Old 10-30-2009, 08:52 PM   #93
u gotta give us some kinda video come on man!!! ur killing me
Old 11-02-2009, 10:26 PM   #94
Petro's Avatar
Time to change your sig and post vids!!!!
Old 11-02-2009, 10:29 PM   #95
Whats this for?
mr spree's Avatar
i did thanks to you
hopefully i have a video this weekend. Just started and new job mon-fri.
Also check out my thread about no taillights!!! its killing me, i cant drive it at night
Old 11-03-2009, 12:48 AM   #96
so how does it run?
Old 11-03-2009, 01:09 AM   #97
its just greg
AmericanMuscle's Avatar
very clean, I like it alot.
Old 11-03-2009, 01:10 AM   #98
Dude, you're killing ALL OF US!!!!!!
I Love how stock it looks all around, so cleaaaaaan.
VIDEOS! Ripper vids!
Old 11-03-2009, 02:35 AM   #99
Whats this for?
mr spree's Avatar
she runs great! this clutch will take alot of getting used to though. Its the Spec 3 clutch and ive read its not a very street able clutch even though it says. You can't really slip this clutch very well.
Ill get some videos up as soon as possible. She does rip holly hell lol, alot different than my 2.8 i must say haha
Old 11-03-2009, 08:49 AM   #100
Did u even slitley keep track of ur cost? how much u think u got in it from start to finish
Page generated in 0.66965 seconds with 31 queries
[Output: 208.44 Kb. compressed to 189.58 Kb. by saving 18.86 Kb. (9.05%)]
