piston ?'s
Old 08-19-2008, 02:04 AM   #1
denali_on_26's is on a distinguished road
piston ?'s
What piston/cam do you recomend for a turbo app.
My goal is a low 10 high 9 ET s10 with a/c and overdrive IT WILL BE A DD!!
Last edited by SweetS10V8 : 08-19-2008 at 09:36 AM. Reason: Would have turned into a classified thread.....
Old 08-19-2008, 08:53 AM   #2
tiresmokinV8's Avatar
tiresmokinV8 is on a distinguished road
Re: piston ?'s
I dont have any answers for you but that future setup sounds absolutely wicked!!
Old 08-19-2008, 09:39 AM   #3
LSx and V8 Mod
SweetS10V8's Avatar
SweetS10V8 is on a distinguished road
Re: piston ?'s
You can sell your stuff in the classified section. Sell for a little less than you paid. Its just like anything else, people are going to try to pay a little as possible and your going to try to get as much as possible, then everyone meets in the middle.
I would shoot for 9.0-9.5:1 range of compression and call someone like Comp Cams for a recommendation, since most of us dont have much turbo experience.
Old 08-19-2008, 10:58 AM   #4
jnoehl's Avatar
jnoehl is on a distinguished road
Re: piston ?'s
diamond makes some really nice dish pistons. i would shoot for like a -15cc dish and use some 72cc heads that should net you around 9.0:1, if you stick to a stock stroke, if you go with a bigger stroke you'll need to get a bigger dished piston. i've been around some builds that used Speed Inc cams with their turbo with good results
Old 08-19-2008, 11:19 AM   #5
9.88@140.86
Black X's Avatar
Black X is on a distinguished road
Re: piston ?'s
I have had excellent results with Diamond pistons. The Shelf stock -15cc is a great piston for the power you will need. If you can spring for it I would have them skirt coated.
I like jnoehl's recommendation. -15cc piston and a 72cc head for right around the 9:1 range. Speed inc like he mentioned has a great turbo cam in the TU1 its a 225/225 .581/.581 113LSA. Smller then my cam but an excellent turbo cam for sure.
My current combo is the 15cc dished piston and a 64cc head putting me at 9.5:1 12psi no problem on pump gas.
Old 08-19-2008, 02:45 PM   #6
Re: piston ?'s
so what lsa on a cam is good on a turbo i thought higher the better?
i have nitrous cam now and it is almost the exact same as the specs you just mentioned but with a 112lsa
Old 08-19-2008, 02:59 PM   #7
9.88@140.86
Black X's Avatar
Re: piston ?'s
Im going to assume you have a TR224 by what you have mentioned. I wouldnt spend the money on a new cam for only a change of 1* In LSA for what its worth my current cam is on a 112
Old 08-19-2008, 03:00 PM   #8
Re: piston ?'s
man X you are a ton of help!!
Page generated in 0.10156 seconds with 12 queries
