LinkBack (18) | Thread Tools |
#301 |
Need LSx swap.....
Re: ******PARTS LIST AND SWAP INFO FROM BLACK X****** LSX Swap.
all you would need is the alternator bracket then, those are usually around $75 on ebay.
#302 |
![]() http://www.jegs.com/i/Aeromotive/027/15104/10002/-1 |
#303 |
For starters I would like to show some appreciation for the fellas who pioneered the installations of these motors in their trucks. What I want to know is what do people do for trucks with the vin 4 motor (pre mid 2000) do for their fuel system? That fuel pump doesn't produce much more than 40 psi and the fuel filter is totally different than the vin 5 motors.
#304 |
Location: abbotsford, british columbia User is: OffLine |
the walbro 255 in-tank pump and corvette filter/regulator is a popular and proven way to go
#305 |
i got one of the current performance ecm's i think its for ls motor, does the same apply?? |
#306 |
#307 |
im using a custom programmed ecu from current performance. does the same apply as far as the low pressure switch?
#308 |
do we need to get rid of that sensor or use it?? i like this setup better than on my 98 where the fuel lines thread in right behind the head. hopefully yall know what im talkin about??? ![]() i got 2 days to put the motor in and i need help asap Last edited by SweetS10V8 : 01-04-2009 at 11:16 AM. Reason: Took out unneeded quotation of the entire inital post |
#309 |
9.52@152.65
I removed my fuel compesition sensor. |
#310 |
you can tell im a noob at this forum stuff... I'm technologically illiterate i guess.hah
#311 |
so how much did the total swap cost..im looking to do one myself
#312 |
#313 |
anyone found a oil pan that fits with no notching in a 2nd gen 2wd blazer?
#314 |
Need LSx swap.....
H3 alpha pan...
#315 |
First off I would like to thank every one for all the information, really good reading. I purchased a 94' S15 the day they hit the lot for my first vehicle, put 276,000 miles down and had to get rid of it 7 years ago to make room in a vehicle for a car seat. Just picked up a 2003 ZQ9 and looking to join the fun. Again thank you all for taking the time.
#316 |
EDIT: ZQ8 darn laptop key boards
#317 |
is that something i have to add? by not having the ground wire on the filter, does that affect the fuel pump..cuz im havin probs with it Last edited by dstappity : 02-10-2009 at 12:03 AM. |
#318 |
What Now!!!
What would a reg cab short bed Xtreme run in the 1/4 with 4.10 gears and a stock ls1? and tires as well. and maybe some other small mods. I've been wanting to put an ls1 in any of my trucks and if i do it i would def use my Xtreme. It seems kinda pricey tho. Since i have no engine or anything.
#319 |
Need LSx swap.....
depends how much traction you get. 14's to 12's possibly, depends on a lot of things.
#320 |
What Now!!!
#321 |
i have a guestion someone may be able to help me out with. I got a 5.3 from an 02 and a ls1 intake from a 00 i need to know which intake gasket to use logic tells me to use the one matched to the intake i had a freind compare the part numbers and the 2 part numbers are different. sorry to ask it here but a lot of the people on the lsx thread get all pissy when a new thread is started asking a question I have searched and rand out of time have to order the part tommorrow so it will get here so i can get the intake on saturday
#322 |
9.52@152.65
Sorry to see no one responded to you sooner, You will want to use the intake gaskets for the LS1 intake. The Truck intake gaskets will not work. |
#323 |
yea i finaly found someone and got ananswer i called jared today and ordered my harness and headers and stuff hopefuly the harness will be here by the time my body drop is done. Anyone know where i can find a ls2 corvete oil pan only one i seen on ebay was lie 485 and 15 shipping 500 for a pan seems a lil steep also is anyone running an externaly fuel pump i have a fuel cell and cant run intank.
#324 |
NAVY
Nice. I think I might do a 2wd single cab instead of 4wd.
#325 |
how about using the t56 with a single cap that is manual
#326 |
i have a 04 gto ls1 with 98 camaro 4l60 do i need a spacer?(in my Sonoma) thanks Last edited by dstappity : 06-25-2009 at 05:25 AM. |
#327 |
Makin Sparks
If the transmission came from an LSx vehicle, then no spacer is needed.
If the trans is from an older SBC then an adapter is needed. So to answer your question directly, no, no spacer needed since the 98 Camaro V8 was an LS1. |
#328 |
What if my 4L60E was from my 2000 S10 and was bolted to my 4.3, still no spacer required? I did measure the distance from the block edge from each block to each flexplate and theyre exactly the same. |
#329 |
Need LSx swap.....
your 2000 tranny falls under the "older SBC" design if im not mistaken.
#330 |
Huh.....seemed to bolt up with no problems. TC bolt holes had to be elongated to fit the stock TC, also the TC did not slide any farther forward to the 4.8 flexplate than it did with the 4.3 flexplate. I will post results once its running.
#331 |
Not sure if anyone still looks at these pages but i have a 98 Chevy blazer that i am putting a 5.3L with a ls1 intake and corvette accessories. I was curious to know what part of the stock fuel system i could use. I was planning on running the corvette regulated fuel filter. Could i use my stock fuel pump? And would i have to get new fuel lines in order for everything to work, like evap?
Thanks |
#332 |
What Now!!!
I have been thinking about putting a ls1 with a t56 in my truck for sometime now (99 Xtreme 4.3 5spd) and i had some questions. Is 3500 a good price for a ls1 with a t56 (came out of a wrecked trans am) that includes the wiring and computer, front cross member with engine mounts, shifter, pedals, and the hydrolics for clutch? I've been looking around and i can't seem to find any others cheaper than that price. Also does anyone know if i will be able to use my stock console? and or will i have to cut the hole back farther for the shifter? I decided that im not gonna have a/c on it so i won't have to mess with any of that. Where can i find long tube headers? all the links that people have posted won't let me go to them. or is the shortys good enough? If anyone knows where i can find an engine cheaper please tell me. 3500 for an engine and trans kinda high. Any help would be greatly appreciated. Thanks
#333 |
fmylife.com
Anyone find a p/n on an LS2 engine acc. bracket or LS3 intake?
#334 |
did anyone have to make trans crossmember mods? if so can you post some pics? thanks!!
