LinkBack (18) | Thread Tools |
#101
takes 2 balls in our game
Re: ******PARTS LIST AND SWAP INFO FROM BLACK X****** LSX Swap.
I heard that the 55 chevy swap pan fits a s10 chasis..........will look into it
#102 |
RITALIN, IT LOVES ME!
bump to the top for a friend
#103 |
whats the word on that pan?
#104 |
WHAAAh?
Location: IOWA, land of Corn and Pork User is: OffLine |
yeah the pan?
#105 |
I have heard on 2 other sites that the 55 swap pan fits in the s10 chasis,I sent S&P an email,havent heard from them
#106 |
#107 |
looks like the 55 swap pan is just a cut and modified stock pan,not worth it for the price in my opion.
#108 |
Everyone happy now?....
#109 |
9.52@152.65
I am
I made Sticky status ![]() |
#110 |
Werd
#111 |
Fo sho!!..now if we can just gather up all the parts and info scattered throughout....lol
#112 |
whore turned lurker
Yay Sticky :d
#113 |
Sdimess84
ill ad some parts when i get stuff thats not on the list
#114 |
Blackx, how did you connect into the stock fuel s10 fuel filter to connect to the vette fuel filter?
#115 |
9.52@152.65
my truck is flex fuel and already uses the same filter as the vette. I didnt have to change anything
#116 |
The 55 chevy swap pan ----You still have to notch the crossmember(very little,less than the ls2 pan he said) a little.S&P said if you cut it down anymore you would lose to much oil capacity,I asked them if they would make a swap pan for the s10 chasis,they said NO.
#117 |
ɔıɹɔ&
#118 |
Black X, I am using the same headers as you and was wondering where you put your o2 sensors.
#119 |
9.52@152.65
the O2 sensors are in the Y-pipe.
#120 |
Well,according to the pics in the ls1/s10 thread,The 55 chevy swap pan actually fits the s10 chasis,so add this to the parts list,just another option for sure.
#121 |
what did you guys use for a throttle cable bracket, stock ls1 or s10......who has had problems with the brake booster being to big. can you use the fbody booster. anybody had to lengthen a master cylinder line for the clutch. part number for the throttle cable please if anyone has it
#122 |
What tranny/year are you using?A stock s10 line will fit,like a 2000
#123 |
9.52@152.65
Part number for the throttle cable is on the first page, I used the F-bodt throtte bracket |
#124 |
tranny is from a 98 z28, i bought the ls1 master cylinder it is just to short it is mounted but does not reach so i thought maybe i could extend it
#125 |
guy on here used a 2000 s10 line on his ls1 6 speed.On the 98 slave,they say it is BEST to use the 2000 or 2001 slave,the older ones had alot of problems.Pics of the install?
#126 |
pics when i get done
#127 |
you say brake booster to big,you mean its hitting the coils?
#128 |
9.52@152.65
IMPORTANT AIR CONDITIONING INFORMATION
if you have a 4.3L truck this will not affect you it applies to the 2.2L guys only! The LS1 ECM will use a Low Pressure sensor as a saftey shut off for the A/C pump, The Stock 2.2L ECM uses a High Pressure sensor and the 2 are not compatable. If you order a harness from Current Performance Wiring you will need to install a low pressure switch. The way that I did this was to purchace 2 items from a 2003 4.3L Chevrolet Blazer. (1) Low Pressure switch the GM part number for the switch is: 52473139 (1) Accumulator, the Accumulator Part Number is: 89038598 You can see the Low pressure switch as shown here in this diagram As #1 The 2.2L will not have this. ![]() The GM part number for the switch is: 52473139 The Accumulator Part Number is: 89038598 Thanks to jhakinson for bringing this to my attention If you need any fittings to adapt the compressors here is where i purchaced my fittings. Rays Auto - #10, 1/2" Air Conditioning Fittings Last edited by Black X : 04-18-2007 at 02:57 PM. |
#129 |
sorry I never thought to metion this before either............
#130 |
yeah it is hitting the coils, what did you guys do to solve this problem, do they make a smaller one or do they modify ones from other cars.
#131 |
I used the round truck coils and brackets, they clear
#132 |
do like bucket did or you have to move the rear 2 coils(one on each side) to the firewall
#133 |
The creeper next 2 you...
Yeah i still haven't done this... I have the low pressure switch from a 4.3 but it wouldn't go on my 2.2 now that summer is comming i need to get AC going to prepare for the 120 degree days... |
#134 |
THE Original Donk!
Black X, I have a 2002 Camaro LS1 and want to swap on the corvette brackets to fit it in my 1st gen S10. I saw some things were compatable on your list but are the power steering pump and alternator compatable too? Also what do i have to do if I am not running A/C. Do I still get the AC brackets and just put a pulley in there?
#135 |
9.52@152.65
#136 |
THE Original Donk!
#137 |
there is a place right around the corner from me about 20 mins that is called corvette recyclers this guy has everything you can think of that has to do with corvettes. couyldnt i just go there and buy an ls1-2-6 with all theaccressory drives already on it and buy the harness from current performance and all the other stuff i need?
#138 |
More Go then Show
#139 |
Rise Above
are you guys running oil coolers on your LS1's?
#140 |
is the 4.3 throttle cable the same on all years for the ls1 swap. I have a 96 is that the same as the 2002 that black X mentioned. Also does anyone have the part number on the throttle cable bracket for the ls1?
#141 |
9.52@152.65
#142 |
Location: abbotsford, british columbia User is: OffLine |
Well boys and girls, the LS2 pan fits!! In 1st gen 2wd blazers. Maybe not all of them but it fit in mine with about 1/4" of gap between the corners of the pan and the cross member. Which in my books means no cutting
#143 |
9.52@152.65
Thats great to know. Thank you for sharing that info buddy!
#144 |
#145 |
yup roughly $300
LS2 Pan GM#12581810 Pick up Tube GM#12558750 Dipstick GM#12570788 Dipstick Tube GM#12570787 Windage Tray GM#12558189 |
#146 |
that is cool. i know the ls2 oil pan is like $147.00.
#147 |
Need LSx swap.....
comgtsom, where can you get it for $147? Thats cheap.... |
#148 |
i have a friend at chevy dealership that is his cost. he always charges me at his cost.
#149 |
WHAAAh?
Black X what did you do with your A I R solenoid and tubing to the TB. I just got my LS6 intake and I didn't know what I have to do with that little thing
#150 |
I made a .100 plate at work to block mine off with.
well mine has a new ac compressor. and a new 160 t-stat. now I have to get the ac crap charged, again. still working on getting a wideband. every time I turn around something pops up. |
