need help wiring up LS1painless harness
okay painless suports sucks, anyways im trying to figure out how to wire up the gear shift indicator on my 01 blazer, here is a link below showing what im trying to do please anyone help me!!!!!!!
http://www.painlessperformance.com/M...0520Manual.pdf go to page 6 and read paragraph D. im not sure how i would mount that switch they tell me to use, and i guess i could still just wire off the brake switch for the purpple wires please anyone help! thanks for anyones help in this! |
Makin Sparks
Re: need help wiring up LS1painless harness
The easiest way I could think of would be to swap the shifter shaft from the original transmission (where the shifter connects) to the LS1 trans. along with the park/neutral switch from the original trans. Then cut the larger gray connector from the old harness. Just use the wire in Pin A (If no wire, just move one of the others) and splice that wire to the orn/blk wire you have.
That switch would need to be mounted really weird on the side of the tranny in order to do what it needs to do. one easy redneck way would be to just put a toggle switch in the engine compartment and click it off when you put the truck in to drive. Use the 2 wires from the painless harness as they show. Last edited by 97 SS 350 : 08-03-2004 at 01:12 PM. |
what large gray connector are u talking about? is it located on the the 4.3 engine harness? if so i dont have that part of the wiring hanress cuase i sold it wiht the engine and the trans is gone as well, but i do have the switch that monted to the trans, also where is pin A located on the shift switch? there are 2 connectors on that shift switch, i want to do this the right way, i dont want to rig anything up, thanks for all your help Jared!!
okay i just got back from trying to take out that shift shaft and damn i just cant get it out, do you know how to go about taking it out, this sucks
Makin Sparks
The shaft comes out with a couple of screws, but you have to pull the pan off in order to get to them.
The gray plug was on the 4.3 harness, I was hoping you still had it. Might try a junkyward to get one, they are used on the full size trucks as well. Pin A on the shift switch is the top plug, outside upper most pin. I hate to say it, but if you didn't want to "rig" anything up, the painless harness was probably not the route to go with that new of a vehicle. |
okay dont u make harness's? how much to take care of my problem here? and how soon
Makin Sparks
Well, if all you are after is the connector and a wire to plug in to the switch and splice in to, I can send you one free of charge. I just need a mailing address.
send it to
Ryan White 808 Melody LN. Enigma, GA 31749 thanks a bunch you are the only person thats helped me out even painless support would not help me, now if i can only get this damn shaft out i have droped the pan and took a clip out and a bolt that held some kind of lock in place but still this damn thing want come out, |
Makin Sparks
I cut it off of another harness I had and stuck it in an envelope, it will be in the mail tomorrow, not sure how long it will take the USPS to get it to you.
Not sure what more to tell you about the shaft, I didn't think it was all that tough. |
cool thanks for all your help
