Need a crossmember picture from a LS1 swap
Old 08-03-2006, 11:52 AM   #1
Mainly looking for pictures of the LS1 swap period. Would like someone to show me a picture of the crossmember as towhere they had to notch it. Thanks
Old 08-03-2006, 02:15 PM   #2
jinusow's Avatar
Re: Need a crossmember picture from a LS1 swap
here you go. I've got pictures but only with the engine in using a ls2 oil pan not a 5.3 oil pan. I'm not sure which pan you are using so I made a quick picture showing what each notch cut looks like.
Old 08-03-2006, 03:59 PM   #3
TrailBlazin'
SuperSS27's Avatar
your picture is confussing.
Old 08-03-2006, 04:56 PM   #4
Call me Mario, Princess
AceHaag's Avatar
that looks like a top veiw if i already have mine notched for the truck pan the ls2 pan should fit right in, right?
Old 08-03-2006, 07:10 PM   #5
jinusow's Avatar
If you have the top of the crossmember notched then yes it will fit. If you only have the back of the crossmember notched then I don't think so. The ls2 oil pan only needs the top of the crossmember notched about .5" The 5.3 oil pan needs the back of the crossmember notched usually 2".
Old 08-04-2006, 01:55 AM   #6
JYD
was there not room to just install the motor .5" higher? if its that close, i would think you could get away without cutting at all. have you compared the fitment of the CTSV pan?
Old 08-04-2006, 05:23 AM   #7
AceHaag's Avatar
the engine can't be any higher because the transmisson would hit the cab. plus you want to keep the CG down.
Old 08-04-2006, 11:39 AM   #8
I haven't got mine all the way in but I had to cut WAY more than that with the ls2 pan(almost all the way accross the top.Hopefully I'll have pics next week. Heres a link from tech,this is about what mine looks like.You can see how its cut all the way accross the top.
http://www.ls1tech.com/forums/attach...chmentid=60284 and a link to the thread http://www.ls1tech.com/forums/showpo...&postcount=366
Old 08-04-2006, 02:40 PM   #9
More Go then Show
THEKING's Avatar
I've seen lots of people notch the frame different. On mine i notched to about the little hole in the middle of the crossmember. I'll have pictures this weekend once i get my digi back.
Old 08-13-2006, 12:24 PM   #10
Rigo
anyone else have any pics with the other oil pans????
Page generated in 0.57694 seconds with 31 queries
[Output: 70.01 Kb. compressed to 65.55 Kb. by saving 4.46 Kb. (6.37%)]
