name that sensor/vlave!
Old 10-26-2009, 11:40 PM   #1
madrodder913's Avatar
what valve/sensor is in that hole lol the tube coming off mine is chipped.
Old 10-27-2009, 12:29 AM   #2
CODE4LS1's Avatar
Re: name that sensor/vlave!
I think it's evaporative emissions......could be wrong though.
Old 10-27-2009, 12:33 AM   #3
Toy Fabricator
v8power's Avatar
Map
Old 10-27-2009, 01:59 AM   #4
turbobandit's Avatar
map is on the back of the LS1 intakes. so not sure on that one
Old 10-27-2009, 02:00 AM   #5
Return line of the pcv?
Old 10-27-2009, 02:10 AM   #6
Whats this for?
mr spree's Avatar
its for the EVAP
Old 10-27-2009, 02:16 AM   #7
Flux capacitor
Old 10-27-2009, 02:24 AM   #8
,EVAP!!!! that's what i meant!!!!!!!!!! haha thanks spree
Old 10-27-2009, 07:43 AM   #9
LSx and V8 Mod
SweetS10V8's Avatar
Its the purge solenoid/valve. It is an evaporative emmisions device. It is connected to a line that runs from your gas tank to your intake. The valve opens and allows gas fumes from your gas tank to be burnt in the engine.
Old 10-27-2009, 10:31 AM   #10
Toy Fabricator
v8power's Avatar
l76s maps are on the front same place as that hole..
Old 10-27-2009, 08:04 PM   #11
LSx and V8 Mod
SweetS10V8's Avatar
The pictured intake is an aftermarket factory replacement, that has a three bolt throttle body. Im 100% sure thats the Purge Valve/Solenoid on that intake.
Old 10-28-2009, 12:28 AM   #12
its just greg
AmericanMuscle's Avatar
wtf kind of intake is that??
Old 10-28-2009, 12:39 AM   #13
Whats this for?
mr spree's Avatar
its the truck intake...
can you buy a smaller Purge Valve/Solenoid so it doesnt stick up so much?
Old 10-28-2009, 02:10 AM   #14
is it neccessary? cuz i dont have that line that comes from the tank anymore, im using a fuel cell.
Old 10-28-2009, 03:57 AM   #15
Whats this for?
mr spree's Avatar
some people get rid of it...idk what a fuel cell does with the gas vapors though
Old 10-28-2009, 06:09 AM   #16
LSx and V8 Mod
SweetS10V8's Avatar
Holds them in, if you dont have a vent tube. Or releases them to atmospherse if you have a vent.
Old 10-28-2009, 11:33 PM   #17
id probably have to call jared but if i do eliminate it will it mess with my emmissions... will it throw a code?
Old 10-28-2009, 11:58 PM   #18
Whats this for?
mr spree's Avatar
it is for emissions but just ask jared to get rid of it and he will do what he does best to remove it and have it not throw codes
Old 10-29-2009, 12:48 AM   #19
yes it is part of emissions, if it's not on there it can also cause the tank pressure to be out of spec and then throw another code for that... and yes you do need it if you are in a emissions required area... you can always relocate it to another part of the intake, it does not have to be right there. just be sure where ever you put it it's sealed up good.
Old 10-29-2009, 01:17 AM   #20
Whats this for?
mr spree's Avatar
it has to have that Purge Valve/Solenoid on it doesn't it? or can it just be a hose from the canister to the the hole in the intake?
Old 10-29-2009, 01:47 AM   #21
Former S10 enthusiast
01cherryreds10's Avatar
That's probably what it is and the purge is located near or inside the cannister. You can take it all off depending on what your state's emission standards are.
Old 10-29-2009, 02:30 PM   #22
thanks for the input, much appreciated
Page generated in 0.58921 seconds with 31 queries
[Output: 107.39 Kb. compressed to 98.59 Kb. by saving 8.80 Kb. (8.20%)]
