My Ls1 Stroker Build 56k Beware
Old 06-10-2007, 12:49 PM   #1
STROKED LS1 S10,520 HP
http://i151.photobucket.com/albums/s...9_07_08102.jpg
http://i151.photobucket.com/albums/s...09_07_1849.jpg
http://i151.photobucket.com/albums/s...09_07_1848.jpg
http://i151.photobucket.com/albums/s...23_07_1717.jpg
http://i151.photobucket.com/albums/s...23_07_1716.jpg
http://i151.photobucket.com/albums/s...o_v8_s10/7.jpg
http://i151.photobucket.com/albums/s...o_v8_s10/6.jpg
http://i151.photobucket.com/albums/s...o_v8_s10/5.jpg
http://i151.photobucket.com/albums/s...o_v8_s10/4.jpg
http://i151.photobucket.com/albums/s...o_v8_s10/2.jpg
http://i151.photobucket.com/albums/s...o_v8_s10/1.jpg
http://i151.photobucket.com/albums/s...8_s10/68-2.jpg
Old 06-10-2007, 01:07 PM   #2
Needs a clutch... BAD!
EYEOPNR's Avatar
Re: My Ls1 Stroker Build 56k Beware
nice... should pound the pavement pretty nicely lol
Old 06-10-2007, 01:14 PM   #3
Some on the pics are when it was together with a plain ls1. Oil pump went out and started a knock in the bottom end. 1 +1 = stroker.
Old 06-10-2007, 01:14 PM   #4
Wire freak
lycan's Avatar
beautiful
Old 06-10-2007, 03:14 PM   #5
Looks good! Are you running A/C? What radiator is that?
Old 06-10-2007, 09:04 PM   #6
he,he,he project over kil
bitchin sonoma's Avatar
looks clean and what radiator are yo using?
Old 06-11-2007, 11:00 AM   #7
It's the one on summit s10 v8 swap, $300. I am running a/c. I notched the frame. I finally got the motor back in last night will have more pics later.
Old 06-11-2007, 06:07 PM   #8
nice!How good is summits radiator, has it been good for you?
Old 06-11-2007, 07:57 PM   #9
I have not had the truck running with the new rad yet will let you know!
Old 06-16-2007, 06:13 PM   #10
Old 06-16-2007, 06:25 PM   #11
Lifted Member
Rinkrat456's Avatar
Nice work, especially with the rear 8.5" idea. How thick of spacers did you use for the front wheels to fit?
Old 06-16-2007, 06:30 PM   #12
2-1/2 wheel spacers
Old 06-16-2007, 06:57 PM   #13
Lifted Member
Rinkrat456's Avatar
I thought so. With how much you've spent on rims/tires and spacers, you should get a wheel lock set to prevent theft.
Cheap $20 dollar insurrance, keep the wheel lock key in the glove box.
Old 06-16-2007, 07:05 PM   #14
Shiit, I would keep the whole truck locked away in a garage or something.
Looks badass, have you tried the radiator yet? Vette rims? What size are they?
Old 06-16-2007, 07:27 PM   #15
Lifted Member
Rinkrat456's Avatar
Looks like 19's, possibly an 18/19 combo considering the rears are so wide.
Old 06-16-2007, 07:49 PM   #16
19-20
Old 06-16-2007, 07:50 PM   #17
Quote: Originally Posted by turbo_v8_s10
19-20
9 wide front 10 wide rear
Old 06-16-2007, 07:52 PM   #18
I run 195-199 in traffic with 104*! out side
Old 06-16-2007, 10:09 PM   #19
Build them right....Mod
philntx's Avatar
Have you had it on a dyno yet? If so, post one of your graphs. I'd like to see what it does in the altitude.
Old 06-17-2007, 11:55 AM   #20
I not contacted jarred to help me with the new ecm tune. It's running a little ruff and not a huge power dif. Without larger injectors, 85 throttle body and ls6 intake, it should perk right up. I ran out of money right now, still breaking in the motor. Believe it or not there aren't many dyno's hear. There is one guy with one in the valley he dose not want to help me. The nearest is Colorado after that one.
Old 06-17-2007, 12:20 PM   #21
what a dick if he does not wan to help you
Old 06-17-2007, 01:02 PM   #22
NO NO NO NO NO! Jarred has bean a life saver!!!! I just have not got around to sending him an email.
Old 06-17-2007, 03:21 PM   #23
philntx's Avatar
It's ok, we knew you didn't mean Jared.
How far are you from Orem? Squires Turbo Systems are located there.
