Manual 2 Auto
Old 08-20-2009, 11:30 AM   #1
Manual 2 Auto
I am gathering parts for my 03 2.2 5spd to swap in a 5.3 and 4l60e. Will I need to get a master cylinder from a automatic s10? What else would I have to swap/switch/modify?
I am going to be using a cpw wiring harness as well.
Old 08-20-2009, 01:03 PM   #2
CODE4LS1's Avatar
Re: Manual 2 Auto
Auto trans x member
Old 08-20-2009, 05:17 PM   #3
Two tones of terror
KJF95S-10's Avatar
Re: Manual 2 Auto
Nothing really. Just make a plate to cover the hole in the floor for the shifter, auto trans crossmember, make a blockoff plate for where the slave cylinder attached to the firewall, and remove the clutch pedal, and that is it really.
Old 08-20-2009, 05:26 PM   #4
scriptedmind's Avatar
Re: Manual 2 Auto
Just curious, but what is the difference between the auto and manual crossmember? I tried a 4.3 auto crossmember and it was farther from fitting than my 2.2 5 speed crossmember.
Old 08-20-2009, 05:43 PM   #5
ROLL TIDE!!!!!!
draggindime072010's Avatar
Re: Manual 2 Auto
i would like to know this also i am putting a 700r4 in my truck that used to be a 5 spd 2.2. i was thinking of just buying the universal crossmember from sd.com its only 50$
Old 08-20-2009, 05:45 PM   #6
Two tones of terror
KJF95S-10's Avatar
Re: Manual 2 Auto
They made so many different types of crossmembers for these truck. You just have to find one that works. I bought one for an 02 s10 4.3 auto and it worked fine on my 95. It had the lower exhaust notch
Old 08-20-2009, 07:07 PM   #7
Customz
C-DUB's Avatar
Re: Manual 2 Auto
You interested in selling the master cylinder/clutch pedal assembly??
Old 08-20-2009, 07:26 PM   #8
Petro's Avatar
Re: Manual 2 Auto
The gauge cluster will also need to be changed unless you do the floor shift console...Since the manual's cluster doesn't display the gear selection...But of course this is just a option since the truck will still work without displaying the gear...It will look more factory like this way though..So either floor shift console conversion and keep the 2.2 cluster...or on the column with a different auto cluster...The cool thing about the 2.2 cluster is that it has a 7K Tach...
Old 08-20-2009, 11:21 PM   #9
Re: Manual 2 Auto
I am doing the floor shift. Thanks for all the responses. So I need a auto trans crossmember from a 4.3?
Old 10-19-2009, 02:03 PM   #10
Re: Manual 2 Auto
sry to bump an old thread
but i cant find info on removnig the clutch pedal
do i have to pull the dash to get the clutch pedal out ?
Old 10-19-2009, 02:19 PM   #11
Whats this for?
mr spree's Avatar
Re: Manual 2 Auto
no you should be able to get it from underneath the dash,
pain in the butt but thats how you would do it
Old 10-19-2009, 05:10 PM   #12
chapdou's Avatar
Re: Manual 2 Auto
me i try under but i wasn't able to remove it so i pull the dash and after that it was easy to do it
Old 10-19-2009, 06:26 PM   #13
ROLL TIDE!!!!!!
Re: Manual 2 Auto
yea my dash just happened to be out when i got my pedal out
it was still a pain in the ass but it wasnt too bad. if you asked me how i did it i wouldnt have a clue i guess i just yanked and twisted on it after removing the bolts until it slid out
Old 10-19-2009, 09:23 PM   #14
Re: Manual 2 Auto
I haven't tried yet, when I am swapping the engine I am pulling out all the interior and was going to tackle it yet.
Old 10-19-2009, 09:52 PM   #15
Re: Manual 2 Auto
Quote: Originally Posted by CODE4LS1
Auto trans x member
I just put a 4.3 in my formerly 2.2 truck. Its a 98 I went and got a 4.3 crossmember and there is no differance in the tranny mounting point between a 2.2 and 4.3 crossmember. the automatics and the stick crossmembers seem to be the same. as far as tranny mount location. The big differances b etween them is where they mount on the passenger side of the frame and where the exhaust passes by them. On a 2.2 the exhaust goes under the crossmember and on a 4.3 it goes over it. I ended up putting the 2.2 crossmember back in the truck, since it gave the exhaust more room to pass
Old 10-25-2009, 02:20 AM   #16
Re: Manual 2 Auto
how the heck am i suppose to do it this way
i see no bolts no nothing
if i have a freaking plasma cutter i'll just f'ing cut the damn thing off
so annoying
Old 10-27-2009, 12:01 AM   #17
Re: Manual 2 Auto
1 more question
can i use the auto shifter in the manual center console ?
i found a manual console for sale local for a decent price
Old 10-29-2009, 08:21 PM   #18
Re: Manual 2 Auto
So I got a center console with shifter out of a bravada today. I got the full console, shifter, and the cable running to the transmission. I also grabbed the small wire harness that runs from it to behind the plastic tray under the dash, is there the hookup behind my dash? What does it control? There were two plugs going to the shifter, I figured one was the lights, and the other was a park/neutral safety?
Old 10-29-2009, 09:36 PM   #19
Need LSx swap.....
Kampz69's Avatar
Re: Manual 2 Auto
i dont think youll have the plug under the dash, that was only found in some blazers. i was lucky, it was in mine when i swapped in my floor shift console so the wiring was easy, though i did have to repin the plug/connector. if you dont have the plug under the dash youll have to wire it yourself.
Page generated in 0.58695 seconds with 31 queries
[Output: 99.60 Kb. compressed to 91.99 Kb. by saving 7.62 Kb. (7.65%)]
