LSX Swap Installation Pics
Old 06-27-2009, 12:39 PM   #1
CODE4LS1's Avatar
I know it seems too little too late, but I finally found my camera so I thought I would take a few pics of the installed LSX/trans.
Enjoy!
The engine is sitting in its forward-most position, using LS6 accesories. This allowed no modifications to the trans x member or driveshaft shortening.
Looks factory doesn't it?
Another angle:
Not a great pic but if you look close you can see where the trans mount used to sit. NOw it sits 1/2" closer to the front!
X Member bolted in stock location:
Bad angle pic of power steering and gear box clearance:
My fuel setup. Using the return style fuel rail from my "98 Vette and Russell adapter fittings with factory feed/return lines at stock filter. The ss lines are 6' -6 line bought from www.summitracing.com. They are the PERFECT length!
Rail pics. I had to bend up both lines a little in order to clear the truck coils.
H3 oil pan and crossmember clearance:
Old 06-27-2009, 12:51 PM   #2
*INDEPENDENT*
So Low Roller's Avatar
Re: LSX Swap Installation Pics
awesome!
Old 06-27-2009, 01:05 PM   #3
Local Tech
ls1s10onair's Avatar
want fuel rail covers for that? nice setup!
Old 06-27-2009, 05:57 PM   #4
CODE4LS1's Avatar
No thanks.......I have the set off my C5 that I dont use anymore due to different intake on it. Besides I would have to swap truck coils for the ones on my C5 to make them work.
Old 06-27-2009, 08:25 PM   #5
XtremeRacer11's Avatar
hey do u have a part number from summit for the fuel lines???swap looks clean...great job...
Old 06-27-2009, 09:04 PM   #6
nevermind i found the part number,ss line is 658540 and it cost $41.39...fuel rail fittings 649850 costing 15.95 each...
Old 06-27-2009, 10:28 PM   #7
Killing Time
Petro's Avatar
FRCs work with truck coils...
Old 06-27-2009, 10:40 PM   #8
Local Tech
not to argue at all, but i had a thread on the frc's and black x stated that he had the frc's with truck coils with no problem.... not arguing, just sharing info
Old 06-27-2009, 10:58 PM   #9
Killing Time
Petro's Avatar
are you X2ing my statement or did you read it wrong???
Old 06-27-2009, 11:07 PM   #10
CODE4LS1's Avatar
I still prefer no covers......after all there is only one car in my garage they would look right on, and I dont even run FRC's on it
Old 06-27-2009, 11:56 PM   #11
I've been looking for those fuel rails, where'd u get them?
Old 06-28-2009, 12:12 AM   #12
CODE4LS1's Avatar
The FRC's or fuel rail itself?
Old 06-28-2009, 08:11 AM   #13
takes 2 balls in our game
s10-den's Avatar
LSX swaps are so ugly without the FRC's...
Old 06-28-2009, 02:44 PM   #14
Sleeper S10's Avatar
I guess your truck isn't lowered for you to select that oil pan?
Nice work, all looking great!
Old 06-28-2009, 03:34 PM   #15
The fuel rails themselves I know they are the 97-98 corvette rails, but I've searched and haven't found a decent priced set
Old 06-28-2009, 08:23 PM   #16
CODE4LS1's Avatar
This rail came off my '98 Vette. I converted it to work with a returnless fuel system when I installed a direct port nitrous kit so I had it sitting in a box for years.
Old 06-28-2009, 08:23 PM   #17
CODE4LS1's Avatar
Thanks! And no I'm lowered 2"/3".
Old 06-28-2009, 08:30 PM   #18
very nice work!!!! clean and simple
Old 06-28-2009, 08:35 PM   #19
CODE4LS1's Avatar
Thanks! I appreciate the kudos.
Old 06-29-2009, 09:15 AM   #20
Need LSx swap.....
Kampz69's Avatar
looks great man, it does look factory! good info on the fuel setup too, thanks.
Old 06-29-2009, 11:23 AM   #21
CODE4LS1's Avatar
No problem!
Old 06-30-2009, 12:22 AM   #22
Looks great in there!!
Old 07-01-2009, 02:12 PM   #23
JJ's Automotive
SoLowXtreme's Avatar
looks good man !
any mods done to the LSX ?
Old 07-01-2009, 02:14 PM   #24
Local Tech
oops lol
Old 07-01-2009, 02:48 PM   #25
CODE4LS1's Avatar
Quote: Originally Posted by SoLowXtreme
looks good man !
No its all stock, minus the LS6 intake if you want to call that a "mod"
Old 07-02-2009, 03:52 AM   #26
http://viewmorepics.myspa
I am thinking about doing this to a 2003 but using the L31 motor. How did you wire it in? I have been looking for a week to try to find how to do it right. I keep hitting roadblocks!!! can you help?
also is there any way to put fuel injection on a mid 80's short block. If I cant find a good L31 I have thought of doing that. I have an older 4bolt main with teh lowerend still built and good. Its just alll Carb and I want fuel injection. I am jsut wondering if I can change the heads and put an air plentium on or not.
Old 07-02-2009, 11:26 AM   #27
CODE4LS1's Avatar
It will prob cost just as much to convert your engine to EFI as it is to buy a used 4.8 or 5.3. I would do the latter.
Old 07-02-2009, 09:08 PM   #28
Whats this for?
mr spree's Avatar
i was just thinkink about it, but i recall your going with a t56? so if you put the engine all the way forward on the mounts, this would mean your shifter would be up further also. you would be able to have a smaller shifter unless you had really long arms
Old 07-02-2009, 09:13 PM   #29
Killing Time
Petro's Avatar
Code4Ls1 used his stock 4L60E I think...
Old 07-03-2009, 12:22 AM   #30
CODE4LS1's Avatar
Yes, I pulled the 4L60E out with the motor, had it built, and reinstalled it with the LS motor.
Old 07-03-2009, 08:14 AM   #31
I already have the block and lower end built. I was going to buy some aluminum heads and go from there. I want at least a 350 and not 327. I just want to run fuel injection
Old 07-03-2009, 12:23 PM   #32
CODE4LS1's Avatar
Do some research on EFI components including PCM, TCM, etc., I understand your point, but it costs a few dollars to convert anything to EFI, especially if you have no EFI parts to start with.
Old 07-04-2009, 07:32 PM   #33
Whats this for?
mr spree's Avatar
oh must have mistaken you for someone
Old 07-04-2009, 08:34 PM   #34
CODE4LS1's Avatar
No sweat Spree.......hows your swap going?
Old 07-05-2009, 03:33 PM   #35
Whats this for?
mr spree's Avatar
havent even started lol, waiting for my harness from jared and thats when ill start, trying to get most of the big stuff first, all i really need now are the radiator and fans from him
Old 07-05-2009, 06:10 PM   #36
CODE4LS1's Avatar
Waiting on a harness here too....
Old 07-06-2009, 02:33 AM   #37
Whats this for?
mr spree's Avatar
yea he said about six weeks i believe?
Old 07-06-2009, 11:53 AM   #38
CODE4LS1's Avatar
I am getting mine through a buddy that has a Corvette performance shop, RPM Motors Inc. I have done a LOT of business with this guy for my C5 and he has a contact that makes custom harnesses.
Old 07-08-2009, 11:47 PM   #39
CODE4LS1's Avatar
Ok, very minor update. I got bored tonight and decided to take a couple more pics of the more completed engine bay, nothing exciting, just like seeing a LSX instead of 3/4 SBC.
All cleaned up after sitting for 2 months
Old 07-08-2009, 11:52 PM   #40
CODE4LS1's Avatar
Whoops, forgot to paste the last one.
Old 07-08-2009, 11:54 PM   #41
looks good man... how long did it take you start to finish?
Old 07-09-2009, 12:21 AM   #42
CODE4LS1's Avatar
Just a hair under 2 months, working on it little by little in between carpet jobs and getting ready for our move to WA.
If I had all the parts, 2 weeks sounds about right to me, taking my time and not rushing.
Old 07-09-2009, 03:35 AM   #43
Whats this for?
mr spree's Avatar
where at in WA??
Old 07-09-2009, 11:44 AM   #44
CODE4LS1's Avatar
More than likely Issaquah/Bellevue/Newcastle area. My wife and I really like Issaquah area.
Old 07-09-2009, 10:13 PM   #45
Whats this for?
mr spree's Avatar
ahh other side of the state from me
Old 08-07-2009, 07:42 PM   #46
CODE4LS1's Avatar
FINALLY....... After 2 wiring harnesses later and deciding to just spend the money with Jared at CPW, I got it to fire early this afternoon. Had some trouble with Passkey, but finally got it going.
Here is a BAD quality video of it running, open headers (nothing after the Sandersons):
Old 08-09-2009, 11:37 PM   #47
CODE4LS1's Avatar
So is the video THAT bad or is there no love for the 4.8??
I'll be taking it to exhaust shop tomorrow and will try for better pics.
Old 08-10-2009, 01:46 AM   #48
Whats this for?
mr spree's Avatar
sounded pretty beastly to me lol i wanna hear it with the exhaust. How you gonna run the exhaust?
Old 08-10-2009, 03:13 AM   #49
CODE4LS1's Avatar
Gonna keep it simple and do 2.5" y-pipe from the Sandersons into 3" collector, a single pipe w/cat, Magnaflow muffler and factory exit location. Undecided if I want to go as far as chrome tip or anything. I'll post up pics and better video tomorrow.
Old 08-12-2009, 05:02 PM   #50
The Animal
V893S10's Avatar
what year alternator did you have to use for the C5 bracket?
