LS6 intake?
Old 10-16-2009, 01:15 AM   #1
LS6 intake?
Well the time has come and I am getting ready to purchase a different intake and TB for my 05 5.3 The motor is not in the truck yet so now is the time. When goin to a LS6 intake I have heard there is clearance issues with the truck water pump and idler pulley, what can be done for this. Also what about coolant crossover tubes? Is there anything else I need to know when putting an LS6 intake on a 5.3? I will be getting a complete intake manifold assembly.(intake, fuel rails, injectors, 75mm TB, map sensor, and mounting hardware)
Old 10-16-2009, 02:12 PM   #2
Two tones of terror
KJF95S-10's Avatar
Re: LS6 intake?
http://www.ls1truck.com/forums/front...take-swap.html
That should be stickied on here. Also if you're keeping the truck accessories you would be wise to get the L92 water pump because it's a direct bolt on solution. The thought of sliding the pulley halfway forward on an LS1/LS2 pump is rerally half ass and nearly impossible to do.
Old 10-16-2009, 03:16 PM   #3
LSx and V8 Mod
SweetS10V8's Avatar
Re: LS6 intake?
Whats your budget? I love the FAST manifolds, Ive had the LSX 92mm and just got the 102mm LSXR LS3 manifold and it looks like thier 102mm Cathedral truck intake should be coming out soon too!
Old 10-16-2009, 05:27 PM   #4
Re: LS6 intake?
Man if only I didnt have a budget, that FAST intake would look good under my hood, maybe someday. Where is a good place to get that L92 water pump, I assume it is a lower profile pump that still uses the truck acc. belt alignment?
Old 10-16-2009, 07:12 PM   #5
LSx and V8 Mod
SweetS10V8's Avatar
Re: LS6 intake?
Whats the part number?
I would look at partstaxi.com or ebay
Old 10-16-2009, 09:43 PM   #6
Re: LS6 intake?
I havent found a part # yet I am trying.
Old 10-16-2009, 09:47 PM   #7
Re: LS6 intake?
L92 are the 07+ Escalade 6.2L correct, and I believe they were found in 08+ Tahoe and what not?
Old 10-16-2009, 10:57 PM   #8
LSx and V8 Mod
SweetS10V8's Avatar
Re: LS6 intake?
http://cgi.ebay.com/ebaymotors/07-09...fAc cessories
Old 10-16-2009, 11:29 PM   #9
Re: LS6 intake?
Good find everywhere I seen them there were around $180!!! Now with the LS6 intake is there a member on here that sells the relocating bracket for the idler pulley? Also what MAF sensor do you run with the LS6 intake and TB setup? Aftermarket or OEM? Also my goal is to have about 400HP when I am all said in done will this intake and 75mm TB be good for that? I plan to put a cam in it just need to do some research on which one is good with the 799 heads.
Old 10-17-2009, 05:37 AM   #10
LSx and V8 Mod
SweetS10V8's Avatar
Re: LS6 intake?
Run your stock MAF and stock 75mm Throttle body. Did your engine come with a MAF, PCM, and throttle body??
The truck MAFs are bigger than the F-body style, the LS6 takes a 75mm TB, and the stock 05 PCM &TB are drive by wire.
Old 10-17-2009, 12:27 PM   #11
Re: LS6 intake?
My engine has the DBW TB but no PCM or MAF. and when I go with the LS6 intake I will just run the 75mm Cable TB that comes with the intake. Now for the MAF I would need one from a 05 5.3 or a LS6 type from a Vette, I assume there are different in size? And for the PCM I will be having Jared do all my wiring and PCM programming so the DBW and all the other nonsense will be taking off whatever PCM I get which I assume I will just get one from an 05 5.3 correct?
Old 10-17-2009, 02:03 PM   #12
LSx and V8 Mod
SweetS10V8's Avatar
Re: LS6 intake?
As far as I understand the Vette and the Truck MAFs are the same, the F-bodies got the small MAFs.
I run drive by wire, its really not as bad as people make it out to be. People fear change, especially when there is no where to stick their screwdriver anymore.
Anyways, if you want to run a cable operated throttle body, you need a 2002 or earlier PCM that didnt run DBW. Youll also have to tell Jared what throttle body your running and he will make your harness accordingly(along with some information on sensors).
I think he has PCMs too and can hook you up with one with a nice tune installed already! He will need to know what MAF your running for the tune.
Old 10-17-2009, 09:45 PM   #13
man on a mission
Re: LS6 intake?
Here you go sir. http://dirtydingo.com/store/product_...oducts_id=1089
Old 10-17-2009, 10:31 PM   #14
Two tones of terror
KJF95S-10's Avatar
Re: LS6 intake?
I had the part # somewhere in build thread cuz someone asked me before, but it looks like you got it covered. I paid somewhere around $220 shipped for my l92 pump new from gm so thats a great deal.Im not sure who makes the reloctors now, but I got one of the last billet aluminum ones made by area 51 motorsports. Last time I check the classifieds platour22 was selling his. I would jump on that if I were you.
Old 10-17-2009, 11:22 PM   #15
man on a mission
Re: LS6 intake?
posted a link for a relocator, new is 39.99!!!
Page generated in 0.58580 seconds with 31 queries
[Output: 89.58 Kb. compressed to 83.33 Kb. by saving 6.25 Kb. (6.98%)]
