#151 |
Re: LS2 Re - Build; Beware 56K!
probably not the best place to post this info, but Brian since i know youre watching this youll see it. i got the flex plate off tonight and its different than the flexp off the 5.3 i had (forgot to give it to the guy D: ) it has dual pattern bolt holes for the converter and also two crank locating pins
![]() also, its a different offset! ![]() theres more to it.... this engine came with a spacer! here she is ![]() ive never seen or heard of this before |
#152 |
Whats this for?
hmmm never seen it before either
#153 |
Killing Time
Some of the earlier blocks had a wider rear flange.( Specifically the 4.8s and 6.0s ) The difference had to do with the varying GM transmission dimensions. The short flange cranks are compatible with all transmissions...Whereas the wider flanges aren't....So you would to try and get one with a short flange since you can buy spacer kits if need be...
#154 |
Yeah its a 89 frank, sadly those pics make it look cleaner then i remember it lol looks like its a bit of a odd ball too. should make things interesting
#155 |
89?
Petro, i know all about the cranks and the flanges... ive just never seen one come with a spacer, nor with a flywheel that isnt offset. for my swap, it goes crank > flexp > spacer, this engine is crank > spacer > flex. thats what is weird to me ![]() Last edited by LS2Sonoma : 10-02-2009 at 07:42 PM. Reason: added image |
#156 |
Registered Pimp
Re: LS2 Tear down; Beware 56K!
And my 98 has a hop shock. |
#157 |
due to the lack of posts, ive decided that im not going to update my thread anymore
just kidding, heres a few pix from this weekend started priming the bottom of the frame ![]() put some braces in the back for the shock mounts... its not pretty, but its not about cosmetics at the moment. right now, i need to focus on getting this beast together and drivable for the spring! i also finally ripped out my rear left spring bushings... had to drill the rubber out, what a pain ![]() and for fun, i tore my buddy's 6.0L apart all the way, everything looks real nice inside... not so much on the outside ![]() off to the machine shop she goes! |
#158 |
man that frame looks sweet, going to be a shame to hide it under the body. you dont know how stoked i am seeing my 6.0 apart, just got to get the truck up there so we can start tearing into it now.
#159 |
#160 |
dark side member
Missed a spot......
#161 |
nice work frank! cant wait till you can do mine...jklooks super clean, i had no idea this quality of work was going into it...props brotha- Carter
#162 |
he,he,he project over kil
awesome!!!
#163 |
#164 |
Drag-N-Fly Customs
Lookin good Frank, it's starting to come together now.
#165 |
I turn.
Looks great man
#166 |
Need LSx swap.....
purdy
#167 |
thanks guys. that was the first coat, did the second one today. give it a few hours to dry and its flip time. i have already started planning some lines for the transmission and brake lines
http://www.russellperformance.com/mc...ic/intro.shtml going to see slipknot tonight!! ![]() |
#168 |
Need LSx swap.....
those black fittings/lines look nice
#169 |
yup
and theyre not cheap lol its ok cuz i dont need much still not sure what brake lines i want. its between two kinds. polyvinyl fluoride coated lines or cupro nickel.. leanin more towards nickel lines the nickel lines are pretty much the best you can buy. wont rust, guaranteed for life... but the poly lines are black lol anybody use either of those? |
#170 |
takes 2 balls in our game
AGAIN???LMAO
coming right along Frank..... |
#171 |
Frank...i never saw the pic of your new wheels fitted up...those look sooo nice on your truck...makes me want new wheels now haha
lookin good...as usual. We'll make many trips to the mountains this winter if you promise me you'll have it done by spring ![]() |
#172 |
i havent really fit them in yet... i have some old pix, sort of a sample...
![]() ![]() of course, it wont sit that high in the back. should be about 1.5" between the tire and fender were going to the mountains anyway, carter!! ![]() |
#173 |
Not so Avg
Those wheels look amazing. What size are they?
#174 |
LSx Bitches!
looking damn good Frank!
#175 |
theyre C5 vette rims, 17x8.5 and 18x9.5
tires are 255 45 and 305 45 not sure yet if i like the gloss black on them, might go with gunmetal later on top of the frame has its first coat of paint... time to go buy some lines and start plumbing! also gonna be getting my control arms together and i gotta call the guy who is shortening my diff..... |
#176 |
Whats this for?
2nd gen and 1st gen s10's have the same wheel base dont they?
im lookin to do something with those wheels, i really like them and they look awesome on your truck |
#177 |
first coat on top... ran out of paint
![]() ![]() ![]() finished the first coat tonight, started the crossmembers |
#178 |
well, im still trying to organize the lines and get my hardware ordered for the suspension... so im getting all my pieces together and trying to figure out what i need. going to replace most of the ugly rusty bolts. got busy at work today and didnt get around to getting anything.
![]() ![]() heres a few pix of the lines im going to be running. theyre nylon and so far me likey! assembled ![]() disassembled with different bulkheads ![]() Last edited by LS2Sonoma : 10-26-2009 at 09:53 PM. |
#179 |
dark side member
Lookin good frank! Now's the time to do that vette brake swap! I have watchya need. Front and rear....
#180 |
I turn.
Looking good man. You should check into the SC&C stage 2 kit for G-bodies before you replace anything on your front suspension. It's a good deal and it corrects the crappy geometry of the stock setup.
#181 |
dark side member
Oh, I've been tryin to convince frank to go with that for a while. But he decided the money was better spent on a billet t.body
#182 |
throttle body? there are no cheap 90mm tbs... unless i want a stock dbw
id rather have the ls6 intake on there but how could i go wrong with a $50 LS2 intake? lemme see those brakes, ry |
#183 |
its just greg
![]() that is very well done! |
#184 |
thanks! i hope it works, i had a tough time measuring the square notches lol
we will soon find out got some pieces back from sandblasting its a bit blurry, but its not an important pix ha ![]() started painting! ![]() |
#185 |
dark side member
Sure, I'll send you a couple pics when i can.
Are you using the stock rubbers for all the cab mounts? |
#186 |
manual>automatic
are they going to be black? or is that primer on the frame
#187 |
Drag-N-Fly Customs
I thought Frank had some urethane body mounts last time I was over there.
#188 |
theyre energy bushes
#189 |
got some new hardware today
![]() bolted some parts on... my shock mount doesnt match for some reason!! gonna have to take it off and redo it lol ![]() |
#190 |
dark side member
Ah frank. You got the wrong bolts man.
They arn't black! |
#191 |
I turn.
Sweet tape-deck - Bassxpander FTW!
#192 |
Drag-N-Fly Customs
Lucky Lager part of the "New Hardware" too?
#193 |
ya, i knoE!!1 black nuts are grade 2 or something like that!! ill have to paint these!
#194 |
#195 |
JJ's Automotive
is it done yet ?
#196 |
alright, so this just in.... i guess ill start by stating that ive had my a/c equipment since i started my swap in 05. i had bought an ls1 pump, which didnt fit. then i bought an ls6 pump which was broken during shipping. by the time i got the replacement my engine was already in and half the front end together, so when my notch was too small, i just left it without a/c.
now that my notch is awesome, guess what............. the pulleys dont line up!!!!!!! oh my god, now what!!?!¿! i cant shim the pump forward at all... maybe the balancer is falling off? lol its TWO TEETH out so WTF aftermarket balancer might be the problem but how do i find out? order a new one? ugh so whats the deal, should i figure out this a/c problem or go another year without my beloved a/c??? anyway, away from the boring part and onward with ENGINE PIX!! ![]() ![]() ![]() just test fitting for now, wanna make sure my trans lines are made right so ill have the trans in there in a few days ps. my exhaust is huge, i cant put my passenger side upper control arm in with the header there lol |
#197 |
Need LSx swap.....
i like how (most) everything is black, looks sweet. you built those long tubes right?
#198 |
Drag-N-Fly Customs
That's lookin really good Frank, sorry to hear about the AC problems. You've got it all apart now. Fix it now.
#199 |
#200 |
LSx Bitches!
ahhh, your making me jealous Frank! Motor looks damn good sitting in there.
