LS2 Re - Build; Beware 56K!
Old 08-28-2009, 08:37 AM   #101
SPEEDY G's Avatar
Re: LS2 Tear down; Beware 56K!
Thanks for the info.
Old 08-28-2009, 10:12 AM   #102
LS2Sonoma's Avatar
np
i should've been more specific, it was on the zq8 and xtreme's
i wouldnt say it helped me for traction.. maybe with the 4.3 lol
Old 08-28-2009, 10:29 AM   #103
SPEEDY G's Avatar
I just called the chevy dealer and they said it didnt come out on there computer for a sanoma i didnt ask for a xtreme,what year do you think it would be on?
Old 08-28-2009, 12:38 PM   #104
Scoop
sonomaguy's Avatar
Quote: Originally Posted by LS2Sonoma
its an anti-hop shock, available on the 99/00 trucks
I have the bracket on my 03 but no shock, think there are times when I could use the shock though.
Old 08-28-2009, 12:46 PM   #105
SPEEDY G's Avatar
I just found the dampner at my chevy dealer the dampner is about $349, i am just going to get some traction bars from summit
Old 08-28-2009, 10:40 PM   #106
LS2Sonoma's Avatar
yea, they arent cheap. better off going the traction bar route. but to answer your question they came on the 1999 and 2000 trucks zq8's or xtreme's
i heard GM decided that it was too expensive to continue the shock afterwards, which is why youre missing parts, Steve
Old 08-29-2009, 12:47 AM   #107
SPEEDY G's Avatar
Yea i am going to put some $125 lakewood trac bars from summit, i had a ? about your pics on the threads you post, how do you get big pics like that on there i cant seem to post up any pics of my x, this is very new to me because i have never been on any fourm before or even posted up any pics before, any help would be appriciated.
Old 08-29-2009, 01:37 AM   #108
Scoop
sonomaguy's Avatar
Set up a photobucket account and link the pics from there. Photobucket is free too.
Old 08-31-2009, 09:39 PM   #109
damn Frank!! bout time you did some work on that piece!
btw, grinding....yes, it sucks the nuts..
Old 09-01-2009, 05:19 PM   #110
need to be lower
layinlowinthes10's Avatar
For the record, I have an 01' 4.3 5 speed extended cab LS model that came with the anti hop shock. Who knows what all they came on.
Old 09-01-2009, 08:33 PM   #111
LS2Sonoma's Avatar
lucky buga!
you know, i see things like that with GM. that 5.3 i posted is a 99 and has alum heads... but they werent supposed to be until 01. all my parts exchange at work show that as well
Old 09-07-2009, 05:27 PM   #112
LS2Sonoma's Avatar
so last week i was busy doing a cam swap and some tuning to Will's truck
now thats almost done, i did my first crossmember today. just test fitting at the moment
its a bit snug, which is ok. i need to lower it another 1/8" and then i can final weld, blast, and paint it... should be done by tuesday! more pix coming
Old 09-07-2009, 05:48 PM   #113
LS2Sonoma's Avatar
heres a quick idle vid of the new cammed truck
http://www.youtube.com/watch?v=u1tGY0UaStQ
Old 09-19-2009, 08:55 PM   #114
LS2Sonoma's Avatar
Re: LS2 Re - Build; Beware 56K!
well, this thread has been nice and quiet. so ive been slacking lately... again! started doing some final sanding and priming, got the crossmember in (not bolted yet) and worked on the ol' a/c notch. its almost done, i just need to load a mock block in and test fit where the mounting bolts sit
do not laugh at my welds! my breaker kept popping so i couldnt get a continuous bead
its just tacked in place for now, its going to be welded on the inside and outside since the welder i have is 110
Old 09-19-2009, 08:59 PM   #115
Scoop
sonomaguy's Avatar
Looks really good Frank, wish I had a place to work on my truck like that. We'll forgive you for the welds since the frame looks so good.
Old 09-20-2009, 01:32 AM   #116
My bed fell off???
NegativeSwitches's Avatar
how do you plan on welding inside the frame?
whats with the je pistons box?
Old 09-20-2009, 01:40 AM   #117
LS2Sonoma's Avatar
welding inside the frame is easy when youre awesome! unfortunately, im not that good... i cant get to the front of the notch very easily once its in. the welding im doing is on the backside of the "new" piece before its attached to the frame. once its welded in place, all i can do is make a nice valley and get some good pen
Steve, my frame looks great on cam.. its still pretty rough. id say i have a good two hours of sanding to go! wanna come help? LOL
JE box is my old piston box
Old 09-20-2009, 02:13 AM   #118
Scoop
sonomaguy's Avatar
Frank, if you need me , I'm there for ya, just call. (Hope you have a power sander and not doing it all by hand)
Old 09-20-2009, 02:36 PM   #119
got cones?
rentedmule's Avatar
X2! I like the look of the notch with the tubing - very clean
Old 09-20-2009, 07:46 PM   #120
LS2Sonoma's Avatar
i only have one sander... dont actually need much help either. its noisy and i have earplugs so its better if people stay away from it! (also get metal dust in EVERYTHING)
you guys are more than welcome to come by anytime though!
more pix comin, trying to finish the notch tonight cuz the welder has to go back to work!
Old 09-21-2009, 01:51 AM   #121
LS2Sonoma's Avatar
AAAAARG!! KAY! so im finished with the welder, i bring it back to work, come back home and start grinding.... i have a hole i need to weld again!!!
i took out my 6.0L block for a mock up and snapped a few pix for youz guyz
this is what my notch looks like now. still need to blend
some corners, but its pretty much done
heres how my compressor fits...
hopefully its not this low though!
Old 09-21-2009, 02:11 AM   #122
LS2Sonoma's Avatar
i thought this would be neat.....
heres a pic of my truck years ago when i first pulled my 4.3L. frame still intact without any notching!
next, this is a pic of my first notch.... oh man, i sucked at welding and then my notch didnt fit so i ground it out more so it would. then i ended up not having enough room behind the compressor for the lines - so i never did run ac
now i have tons of room in behind!
Old 09-21-2009, 05:02 PM   #123
dark side member
Looks good frank. I'll have to come over to check it out and drink you beer!
Old 09-21-2009, 07:27 PM   #124
Scoop
sonomaguy's Avatar
I'll come over but I'll drink your Coca Cola. what evening works best? I'm in Edmonton every Wednesday if that works.
Old 09-21-2009, 08:34 PM   #125
LS2Sonoma's Avatar
yea, wed night should work!
Old 09-21-2009, 08:40 PM   #126
Scoop
sonomaguy's Avatar
Okay, PM me your address again.
Old 09-22-2009, 02:24 AM   #127
big pimpin'
02dime's Avatar
hurry up frank, ill keep mine so we can cruise next summer
Old 09-22-2009, 02:30 AM   #128
LS2Sonoma's Avatar
dont you mean so you can try to keep up to me next summer?
Old 09-22-2009, 10:21 PM   #129
LS2Sonoma's Avatar
i can hear you guys yelling at your computer screen, "HURRY UP AND GET TO THE ENGINE WORK!!" lol
so ive got this 5.3 im slowly building. found a buyer for it the other day. turns out he may want some engine work done, so no sence in going any further...
i had the heads rebuild, call it a sunday afternoon special haha
thats all you get for motor right now
Old 09-22-2009, 11:56 PM   #130
LSxWannaBe's Avatar
top notch work frank, ill have to check it out when i get up there. you got a cam picked for that 5.3?
Old 09-23-2009, 08:49 PM   #131
LS2Sonoma's Avatar
no cam as of yet, not sure on all the details of the truck. im just glad i didnt bolt the heads on yet, the gaskets arent cheap!
on the ls2, lots of grinding and sanding to come... ill have some pix of the rear crossmember getting cut up soon. not sure when ill get the frame primed, but i can tell you this..... i have a really neat surprise coming up!
Old 09-23-2009, 09:34 PM   #132
5.3 LSx bitches
1sic03x's Avatar
great work on the A/C notch. thats exactly how i want to do mine.
Old 09-24-2009, 09:00 PM   #133
LS2Sonoma's Avatar
Andy, right? its A LOT of work to get that, but i have some 6" pipe left if you need it!
couple quick pix... started cutting the spare tire mount off. i dont carry a spare so i dont need it
Old 09-25-2009, 01:04 AM   #134
Scoop
sonomaguy's Avatar
Frank, you said not to notch my frame so it doesn't bottom out but we got caught up on something else and you never said why. I was thinking of putting in a 4 inch piece of pipe cut in half, so only 2 inches into the frame. Then weld a piece of flat bar over the frame to box it in.
Old 09-25-2009, 01:31 AM   #135
LS2Sonoma's Avatar
i said that cuz i thought you wouldnt want to cut your frame!
i think the pipe is a great idea mang
Old 09-25-2009, 11:54 AM   #136
5.3 LSx bitches
1sic03x's Avatar
Yes sir. When I swap that motor in mine, I'm going for the clean look like that so the amount of work doesn't bother me. How does that effect the strength of the frame though? Mig/Tig welder?
Old 09-25-2009, 01:16 PM   #137
dark side member
It' ahead of any mounting point so it's not a big deal. Marginal loss in torsioinal rigidity but some triangulation and solid core mounts could take care of that. In theory one should always tig a frame, but it really isn't a big deal. Localized hardening on a non stressed area won't hurt anything.
Thanks for the beer frank! Love the light weight welds too. Full of holes!
Old 09-25-2009, 08:43 PM   #138
LS2Sonoma's Avatar
how i wish i had a tig.... my welds arent that bad Ryer! esp since i have a crappy 110 that keeps popping the breaker after welding about an inch
and Andy, listen to him, hes the engineer.. id say its pretty solid though
Old 09-25-2009, 10:50 PM   #139
Scoop
sonomaguy's Avatar
Ya, thanks for the Pepsi Frank. (It wasn't Coke but it was OK). The car hole is cool.
Old 09-26-2009, 11:18 PM   #140
5.3 LSx bitches
1sic03x's Avatar
Good info bbcc... I always wondered about the strength of it after cutting it up, even if its boxed in... Looks like I'll be doing some convincing to the old man to notch the frame for my swap. Lol.
Old 09-28-2009, 06:21 PM   #141
this is probably a stupid question, but is the only reason you notch the frame is to mount a part of the ac right?
Old 09-28-2009, 09:27 PM   #142
LS2Sonoma's Avatar
yup, the compressor goes ther
Old 09-29-2009, 02:48 PM   #143
cool thanks, so taht notch is un necessary if im not gonna run ac? sorry for the q's im just trying to get my info together before i attempt this..
your frame looks sweet!
Old 09-29-2009, 03:31 PM   #144
5.3 LSx bitches
1sic03x's Avatar
yeah its not necessary, even if you want to run A/C... there is a bracket made that will relocate the compressor so you don't have to notch it.
Old 09-29-2009, 04:45 PM   #145
all i want is power steering, but thats for another thread..
Old 09-29-2009, 05:00 PM   #146
JJ's Automotive
SoLowXtreme's Avatar
is it done yet Frank ?
Old 09-30-2009, 12:15 AM   #147
LS2Sonoma's Avatar
not yet...it will be done before your truck is, Chris!!
not sure why i do it, but heres a few pix of another project ill never get my truck done at this pace!
heres buddy's 6.0L swap im doing. going to go into a 1991 4x4 S10 Baja. Brian, correct me if im wrong on the year
started takin it apart
little dirty?
i have started sanding the bottom of my frame. cut the gas tank crossmember out and will sandblast it at work soon. gonna bolt it back in (was originally riveted, factory) pix coming soon!
Old 09-30-2009, 11:05 AM   #148
Need LSx swap.....
Kampz69's Avatar
that 6.0l is filthy lol
Old 09-30-2009, 11:33 AM   #149
JJ's Automotive
blah blah blah...i'm assembling mine and your still tearing yours down..lol
i ditch the stock gas tank & carrier Cross Member for the SuicideDoors.com ones...i got the Motor in, but i had to run my tranny back down to my tranny guy, the Convertor wasn't spinning as freely as i think it should be
Old 09-30-2009, 08:25 PM   #150
LS2Sonoma's Avatar
yes... my poor floor!
all these excuses Chris... im almost done mine, hurry!!
Page generated in 0.95610 seconds with 31 queries
[Output: 210.18 Kb. compressed to 191.42 Kb. by saving 18.75 Kb. (8.92%)]
