LS2 Oil Pan
Old 05-13-2009, 04:47 PM   #1
Whats this for?
mr spree's Avatar
LS2 Oil Pan
I recently just got my LS2 Oil Pan using all these product numbers
LS2 Corvette:
Pan - 12598186
Screen - 12558750
Gasket - 12580672
Tube - 12570787
Dipstick - 12570788
Found out that that i didnt really need the Gasket because the Oil Pan itself came with a gasket...So i have two now....anyone else run into this?
Old 05-13-2009, 06:17 PM   #2
Local Tech
ls1s10onair's Avatar
Re: LS2 Oil Pan
lol yea, but i knew ahead of time when the guy at the dealer told me i needed one.... you definitely need to get the windage tray.... they call it a deflector at the dealer tho.... the pickup tube bolts to a different spot on an ls2, so you should get it. mine only cost me about 20 bucks
Old 05-13-2009, 08:08 PM   #3
Whats this for?
mr spree's Avatar
Re: LS2 Oil Pan
well i have a 6.0 and it bolted up fine for me?
Old 05-13-2009, 11:32 PM   #4
Local Tech
Re: LS2 Oil Pan
hmm..... maybe they have the same one.... my ls1 used a different stud, and the stud it uses didnt have a flat spot big enough for the pickup tube, and i didnt wanna take the chance of twisting the tube
Old 05-14-2009, 03:17 AM   #5
Whats this for?
mr spree's Avatar
Re: LS2 Oil Pan
yea i have a 2004 LQ4 6.0l and the stock windage tray and it works good, pick up tube bolts directly to the same place as one of the middle windage tray bolts so no problems there!
Old 05-17-2009, 04:29 AM   #6
Re: LS2 Oil Pan
Yeah the 5.3L windage tray was the same as the ls2's.
Old 10-16-2009, 11:18 PM   #7
Whats this for?
mr spree's Avatar
Re: LS2 Oil Pan
what filter are you guys using? i have two and both of them dont fit lol
Old 10-17-2009, 05:39 AM   #8
LSx and V8 Mod
SweetS10V8's Avatar
Re: LS2 Oil Pan
Whatever one is stock for an 05 Corvette
Old 10-17-2009, 07:42 AM   #9
On da bottle
zx9rgreen's Avatar
Re: LS2 Oil Pan
My C6 pan filter is a PF48 I think. Look up the filter for a h3 5.3 and its the same. The one called out for the vette wouldnt fit my pan either.
Old 10-17-2009, 09:18 AM   #10
Re: LS2 Oil Pan
the stock 6.0 filter is the pf48
Old 10-17-2009, 11:26 AM   #11
Build them right....Mod
philntx's Avatar
Re: LS2 Oil Pan
The 05/06 LS2 Vette use the PF46
The 07 LS2 uses the PF48
LS3's use the PF48
Old 10-17-2009, 11:12 PM   #12
Whats this for?
mr spree's Avatar
Re: LS2 Oil Pan
well i bought the one for the 2005 Corvette with the LS2 and it doesnt fit...The hole on the Oil Filter is to small... Its the same part number for the engine that i have too...kinda weird..
Old 10-18-2009, 12:01 AM   #13
Re: LS2 Oil Pan
I've been using whatever the wix 2004 5.3L is. I bought some fram extreme something at walmart since I was there for the last batch.
Old 11-19-2009, 09:11 PM   #14
cokehead
Dr. Pepper's Avatar
Re: LS2 Oil Pan
anyone have the part # for the ls2 windage tray? just got my pan and everything else and realized i forgot to order it. thanks.
Old 11-19-2009, 11:19 PM   #15
Petro's Avatar
Re: LS2 Oil Pan
C6 LS2 oil deflector (same as used on LS6/LS1) = 12558189
Old 11-19-2009, 11:54 PM   #16
cokehead
Dr. Pepper's Avatar
Re: LS2 Oil Pan
So my you're LS1 one will work? Why did ls1s10onair have to use the ls2 one then? Guess there's one way to find out
Old 11-19-2009, 11:56 PM   #17
Petro's Avatar
Re: LS2 Oil Pan
http://lsxconversion.net/cms/?p=81 It should be the same...
Old 11-20-2009, 12:14 AM   #18
cokehead
Dr. Pepper's Avatar
Re: LS2 Oil Pan
Awesome. You're the man.
Page generated in 0.59244 seconds with 31 queries
[Output: 95.19 Kb. compressed to 87.87 Kb. by saving 7.32 Kb. (7.69%)]
