LS1Edit
Old 08-28-2004, 06:29 PM   #1
vortech03's Avatar
vortech03 is on a distinguished road
LS1Edit
Anyone out there used LS1 edit to reconfigure there computer for the supercharger. Whats it cost? Is it difficult?
Old 08-29-2004, 04:49 PM   #2
snowsurfer
Re: LS1Edit
I've been looking into it. I've got a 03 S10 Crew with Powerdyne sc. As it stands Carputing does not have the cable hook up for in truck programming so you have to get another cable for Spear tech another 130.00 or so. I actually ordered the LS1 but held off when they replied about the extra cable...I've been trying to find others with S10's that has edit but get little response.
I know a guy that had his edit done by Bill Mach and the truck flies!!! But it was a mail order tune...
I plan on doing more work and additions to my truck so I didn't want to get a mail order unless I was thru with mods...
E mail me direct seayahawaii@hawaii.rr.com maybe we can come uo with some ideas or group purchase...
Old 08-29-2004, 04:50 PM   #3
snowsurfer
Re: LS1Edit
By the way the cost is 550.00 less 100.00 discount...plus additional cable 130.00 for now....You can get mail orders for 2-300.00
Old 08-29-2004, 08:46 PM   #4
x01
x01
Re: LS1Edit
I;ve got it. Paid $450. It's not hard to make changes. Knowing why to change something takes some research and watching your sensors with autotap or something. If it doesn't sound too bad to you I would say you should get it especialy if your running boost.
Old 08-29-2004, 09:28 PM   #5
snowsurfer
Re: LS1Edit
Wow great!!! Did you have to get another cable from SpearTecH? By the way what year do you have? Has the performance increased??
Old 08-29-2004, 09:29 PM   #6
snowsurfer
Re: LS1Edit
01' sorry read it later.... Let me know about the cable....Now that I know another S10 has one I'll order it!!!
Old 08-29-2004, 10:31 PM   #7
vortech03's Avatar
Re: LS1Edit
Sounds like a lot to spend. I mean I realize it is adjustable. All my major mods will be in soon and then there will be nothing else to add. If I could get a mach reflash for 300 i think I may take that but I heard they were more expensive.
Old 08-29-2004, 10:56 PM   #8
x01
x01
Re: LS1Edit
For my 2001 it came with the cable that plugs into the obd2 port under the dash.I don't think $450 is so bad becaause the superchip I had was $300. If your running boost you need to be able to adjust youe timing. The big advantage will be when more 4.3l owners get it and start sharing like they do on the ls1 forums.
Old 08-30-2004, 06:22 AM   #9
snowsurfer
Re: LS1Edit
Mach reflash is more like 500.00 but others do a reflash for 250.00 and up...
Old 08-30-2004, 06:30 AM   #10
rasta8's Avatar
rasta8 is on a distinguished road
Re: LS1Edit
just remember ur options
Old 08-30-2004, 11:08 AM   #11
MKR
zippy
MKR's Avatar
MKR is on a distinguished road
Re: LS1Edit
LS1 edit is by far the way to go. if you guys give them enough requests, maybe hptuners will make one for the s10 also. as for the mach tune, good luck getting any adjustments if it isn't right.
Old 08-30-2004, 01:07 PM   #12
Never Finished
Xtreme03's Avatar
Xtreme03
Re: LS1Edit
That doesn't make sense...that's what they told me like 6 months ago...they told me it may or may not work, but whenever they updated it I would get it. But it ended up not being a problem, I can read and reflash without a problem. Now it lists it as working on 03 and 04 models. Just buy it, it'll work.
Old 08-30-2004, 02:03 PM   #13
Un-Blown Fake ZQ8
s10rz350's Avatar
s10rz350
Re: LS1Edit
Although it helps to get programming I'm running a completely stock ecu.
If you have an auto its almost a must to remove torque management and catlyst overtem protection, BUT decent times are possible without it.
Old 08-30-2004, 04:14 PM   #14
snowsurfer
Re: LS1Edit
Thanks guys, I will order it now that I know some of us S10 guys already have it and it works...
Old 08-30-2004, 06:47 PM   #15
vortech03's Avatar
Re: LS1Edit
I think maybe me and my buddy can share and that will help with the cost. He has a vette and he's gonna need a tune because he's doing heads and a cam like me. Perhaps will split it. I have an O3 so it's good to know it will work. Especially if mach reflash is 500 and I can get the LS1edit for 450.
Old 08-30-2004, 07:09 PM   #16
Road Race/Auto X S10
ZR1 S10's Avatar
ZR1 S10 is on a distinguished road
Re: LS1Edit
You know you can only use LS1 edit on one car???? You need to buy another cable if you want to tune two cars.
Old 08-30-2004, 08:13 PM   #17
vortech03's Avatar
Re: LS1Edit
I figured that much but it would help cut cost. I'll have to look into it a little more.
Old 08-30-2004, 08:39 PM   #18
Master's Apprentices
MINTSICK's Avatar
MINTSICK is on a distinguished road
Re: LS1Edit
How do they control that, aren't all obdII cables the same?
Old 08-30-2004, 10:10 PM   #19
x01
x01
Re: LS1Edit
The cable has a box in the center of it and I think that is what locks on your vin the first time you do a flash not a read. I read somewhere that you have to send them your cable and $150 to make so you can use it on another truck, like if you wanted to sell it.
Old 08-31-2004, 09:42 AM   #20
Never Finished
Xtreme03's Avatar
Xtreme03
Re: LS1Edit
I think what they do is they send you another box for $150
Old 08-31-2004, 10:12 AM   #21
MINTSICK's Avatar
Re: LS1Edit
That blows then, but I guess they have to do that so people aren't selling copies of LS1edit and ripping the company off.
Old 08-31-2004, 11:38 AM   #22
AKA: Blazed2k3
frontalbr549's Avatar
frontalbr549 is on a distinguished road
Re: LS1Edit
If I'm not mistaken, the trucks use a different version of LS1 Edit than the cars do, but not positive. I had asked a while back to see if I could get one version that would work for my 03 Blazer and my 02 Vette and they had said something to the effect of "You just need to purchase 2 stand alone set-ups".
HTH,
BR549
Old 08-31-2004, 07:47 PM   #23
vortech03's Avatar
Re: LS1Edit
Has anyone had their chip flashed by anyone other then mach? Prices?
Old 09-01-2004, 12:10 AM   #24
MKR
zippy
MKR's Avatar
Re: LS1Edit
i've had some pcm programming work done for me on work i've done. there are many companies to look into like westers garage, pcmforless, mti, fastchip, nelson performance, prescribed power, etc. personally i'd recomend ed wright at fastchip or bryan herter at pcmforless. both have done work for me and have done an excellent job.
Old 09-01-2004, 04:37 AM   #25
snowsurfer
Re: LS1Edit
I almost went with Bryan at pcmforless. he's really a nice guy and very helpful. I live in Hawaii so if something was wrong with the mail order tune my truck would be down for awhile so I decided to try my hand at programming. Even if I screw up I can put it back to what it was so I ordered it, probably be here in a few days. I probably will keep adding parts to my truck so I would have to wait till I'm al done to ge the best mail order tune. But the flip side is that some of these guys are real experienced in tuning so that's a big plus....
Old 09-01-2004, 12:13 PM   #26
MKR
zippy
MKR's Avatar
Re: LS1Edit
for you guys considering LS1 edit. since there isn't a place that i know of for it on this board, i'm also a moderator at silveradoss.com and we have a place for pcm tuning. if you have questions, stop on in and ask away. we have plenty of guys very familier with the software that can help you out.
Page generated in 0.42674 seconds with 11 queries
