LS1 swap w/ donor car
I have a complete '99 camaro Z28 automatic & and a complete 2.2L M5 S10 (1995)
I can just move everything over but what engine mounts do I need? I can have a trans Xmember fabbed but need to know what to do for the engine kmember & mounts. Also, will the gauge cluster hook up to the LS1 wiring or will I need to swap over the Camaro Gauge cluster. thanks |
Good Bye SonomaST
Re: LS1 swap w/ donor car
it appears you need to do a little research. not being a dick, but spending some time searching this forum will answer ur questions and many many many more will have in the future, and provide useful information. no u cant swap the clusters, u need to integrate the 2 harnesses which is a real bitch or contact someone like our forum sponsor, Current Performance, for a harness. happy searchings good sir
I have searched, I could not find anything if the f-body (camaro) cluster will work or not.
From what i've read, I think 2.8 V6 mounts work for the LS1? I have been researching on a LSX site about swaps for awhile now, just not S10 specific |
Local Tech
yes, the 2.8 mounts will work.... i do agree with 91sonomast, cuz u do sound like ur in over ur head a little..... buying the current performance harness would be my first step..... its pricey, but thats what craftsmanship goes for nowadays...... prepare to spend a shitload of money on stuff you didnt anticipate, and dont get rid of the donor car until the truck is running, and all the bugs are worked out................ good luck
btw, how much did u get the donor car for? |
i've had the donor car for awhile, paid $1,500 and drove it for awhile (was fully functional, road worthy, etc), but its getting turned into a genI sbc race car.
I dont need a new wiring harness as I will have all the wiring. Anything extra I'll hide behind the glovebox ![]() so 2.8 mounts on the 4cyl kmember will line everything up ok? if so that is simple enough. I didnt want to spend $105 on a kit Last edited by FirebirdSE4banger : 07-18-2008 at 10:51 PM. |
never done any "hybrid" swaps but have done a few fbody engine swaps & am pretty comfortable w/ a wrench
Good Bye SonomaST
yeah man, u need at least 2k for random parts and shit, at LEAST 2k
Tell ya what....from Current Performance's website: http://www.currentperformance.com/s10wir.html and/or read this |
Why pay $105 for a kit when you can get 2.8 mounts for $9 each? Unless there is something I am missing (which was the point of me making this question in the first place
)Dont forget I have almost everything I need sitting in a Camaro i read only 99+ V6 s10's had the same rear end as the fbodys, so i need to find out what i need to do swap the fbody one into the s10 |
also the truck does not have abs, cruise, and im ditching the ac
thinking of a way to make the camaro inst cluster fit in the s10 dash, which would make things alot easier |
SPRAYINLOW
you do realize you have to make the s10 and the ls1 wiring harness into one integrated unit, you keep saying that you have done research but you need to do more or else this build will be severely unsuccessful... im not trying to be a dick but i am trying to save you money and time
DO IT RIGHT THE FIRST TIME or else you will be working out kinks constantly |
iam doing a lt1 swap very very soon into a 89 s10 and i can get what ever i need for the doner car wiring ac system motor computer anything. and i looking in to the 3000$ mark when iam done. v8 swaps are not cheap at all. you'd better start reading alot befor you even pick up a tool. i've been studying for months.
good luck |
Location: abbotsford, british columbia User is: OffLine ![]() |
Need LSx swap.....
No need to try and get the Camaro cluster to fit in the truck, the harness from Current Performance will allow your stock cluster to work just fine. Also, no need to use the rear end from the Camaro, its basically the same as the one you have, just setup for a different suspension. Just because it's in or from the donor car doesnt mean you have to use it, or will even work.
ls1 on the works!!
Location: Benton harbor, Michigan User is: OffLine ![]() |
yep thats true, if 105.00 is your limit, ten just stop and don't do the swap.I spent 900.00 plus on my wiring harness. can't wait to put it on !!
no need for a $1000 wiring harness. I have all the wires I need and diagrams to re-wire mine if needed.
all i need right now is information on the mounts, so I can make my own, it looks like all they are is plates that move the engine further away from the firewall? |
STROKED LS1 S10,520 HP
might as well try my plan first before even thinking about dropping that kind of cash for a harness.
WTF!!!!
i tried to do the same thing on mine just work around it and make it work. i took a look at my swap at the time and everything looked like crap and i just thought this isn't what i wanted for my swap. i wanted to be able to pop the hood and be proud of what was under there not have everyone self included thinking that it was a hackjob swap. thats why i'm still not done with mine i figured no sense doing it at all if i wasn't gonna do it right
ls1 junkie
I though this swap would be just a simple drop it in, hook up the battery and a few wires and its done.........WRONG. there are so many small things and you will SHIT when you sit down and actualy figure out what you spent to do this swap. I got my motor out of a donor WS6 and needless to say, all i used was the engine harness, ecm, and the stock long block. |
There will be no S10 harness...that would be removed completely, replacing it with the camaro harness. Fans will be "pusher" style, fuel system would be stock ls1 pump w/ modded bucket, fuse box, etc, everything camaro even lights (switch over to 99+ front headlights/grill/etc)
anything unused would be tucked under the dash (power windows/locks/etc) need to do more research on the air bags (camaro has 2 fronts, s10 has 1) & camaro has abs. yes, it will need a tune is there something wrong with this plan? the harness will not realize it is in the "wrong" vehicle. Yes it will be more work than a reworked harness and not a show car setup but this is a truck, doesnt need to be "pretty" Last edited by FirebirdSE4banger : 07-24-2008 at 06:30 PM. |
ls1 junkie
So your keeping all your s10 interior/stock dash and gauges, but your wanting to install the complete wiring harness from the donor car....like EVERYTHING. Honestly that seems like way to much work. If you knew how easy it was to mod the harness to fit your truck harness, i think you would go that route. Also, if u are keeping the stock gauges, im not sure they will work with the BCM from the camaro.
#24 |
WTF!!!!
its alright he's got his mind made up he's gonna do it his way. let him find out the hard way.. hope it all works out
