ls1 swap in under a week
Old 04-02-2008, 03:23 PM   #1
extremetoy is on a distinguished road
so thats the plan... heres a list of everything i think i need, if im missing anything please let me know, im talking about little odds and ends.. im trying to get everything before i start so it can actually happen.
it will be going in a 98+ ext cab s10 4 cyl 5 speed
ls1 and t56
motor mounts
2.8l motor mounts
sanderson headers
current performance wiring and re flash
corvette fuel filter/regulator
radiator hoses
intake
driveline
fuel lines
fuel pump
corvette accessories
elec fans
vette radiator
clutch line
hummer oil pan
Cruise Control Cable
Throttle cable
thanks, Gary
Old 04-02-2008, 03:57 PM   #2
Jonce007's Avatar
Jonce007 is on a distinguished road
Re: ls1 swap in under a week
Good start - did you order the harness or oil pan yet?
I'm doing the same thing as you, getting everything I need beforehand. I will be taking a good 2-3 weeks to do mine.
How about?
Throttle cable bracket
Air intake with filter
MAF/02 sensors
Exhaust collectors
Power steering/air conditioning hoses
Old 04-02-2008, 04:09 PM   #3
How about?
MAF/02 sensors
Exhaust collectors
i havnt ordered the harness or pan, if there is a shortage of h3 pans ive got a truck pan from a different swap ill use. id like to go w/ the h3 one so i dont have to cut apart the crossmember. if i have to its no big deal, id just rather not
im just going to make my own throttle cable bracket
intake stuff will be from intake hoses.com, they have everything and have had good experience w/ them.
im still shopping for the motor so if it doesnt have the maf and 02 then ill need to get those
good call on the exhaust collectors
im going to hold off on the ac until after summer ( im going to school and work summers) so im not so tight on cash
for p/s stuff there are a couple good shops nearby that make just about any hydro/brake/steering lines, and Ive got a bit of steel braided line left over from another project, i do need to add that to the list though,
thanks
Old 04-02-2008, 05:13 PM   #4
WHAAAh?
NateZQ8's Avatar
NateZQ8 is on a distinguished road
Be ready to wait on a harness for about a month or so. But Jerads work is well worth the wait!!!
Old 04-02-2008, 07:27 PM   #5
Phontain's Avatar
Phontain is on a distinguished road
I thought i read somewhere that its taking 5-7 weeks for the harness these days. :[
Old 04-02-2008, 08:23 PM   #6
slow and low
ssDimer's Avatar
ssDimer is on a distinguished road
you dont have to worry about doing new clutch lines. you can use your s10 slave and throwout bearing but you will need to get the throwout spring from a camaro. other than that all the hydralic hooks up the same.
Old 04-02-2008, 10:45 PM   #7
Jonce007's Avatar
If you are tight on cash, why not go for a 5.3L first and upgrade to the LS1 later? Unless you get a good deal...just a thought. I'm not trying to ruin your LS1 dream (since I have the same dream) but just trying to help you before you get too deep into it. I have close to $5k into parts and I haven't even loosened my first bolt You might have to buy tools as well for this project, I also end up buying some kind of tool for every big project I do.
This is how every project goes for me, I say "well if I do it, I might as well do it right." That phrase alone has cost me thousands of dollars. However, I want it to be reliable as possible.
Please post pics when you start your conversion.
Just for reference, here's my setup.
Here's what I have so far:
'02 Chev 5.3L with acc. minus alternator - $1000
4L65e - $900
alternator - $200 with lifetime warranty
Current Perf - wiring, tune, 02/MAF sensor, mounts, headers - $1532
corvette fuel filter/regulator, throttle/cruise cable - $100
fuel lines, fittings, fuel pressure gauge - $300
vette radiator with dual fan kit - $500
hummer oil pan and accessories - $302
Tools Purchased for project (in addition to what I already have)
Hobart Handler 140 welder - $650
Bandsaw - $100 (need to pick up still)
Still need:
Radiator hoses - $50-70
fuel pump and harness - $160
Coolant overflow tank that holds computer - $20 (junkyard)
throttle bracket - $5 (junkyard)
a/c lines and power steering lines - $20 (junkyard)
rear end - $400-500 (junkyard - with new brakes, etc.)
Misc supplies - $300-400 (bolts, parts, etc.)
Exhaust collectors - $20 (exhaust shop - temp exhaust to drive from house to exhaust shop)
Full exhaust - $400-500
Old 04-02-2008, 10:56 PM   #8
lt1s10onair's Avatar
lt1s10onair is on a distinguished road
i wish u all the luck, but a week is not gonna happen.... give urself time to do it right.... the first time.... cuz ur gonna be pissed when a month goes by, and ur truck aint done
Old 04-02-2008, 11:48 PM   #9
yea, i just finished a 4.8 swap into my crawler. when i bought it i had plans to swap it to an ls1 later but after taking it out i cant justify spending the money and time to pull it out for about 80-100 lbs and a little more power. this time I definetly want to do the ls1.
oh and it will get done in a week, and it will be clean... ill take a bunch of pics once i get all the stuff (prob wont be for a little while considering the harness looks like it will be a while, and depending how soon I find a good motor. Also, it'll be my daily driver so im kinda picky w/ what parts are going in it.)
thanks
Old 04-02-2008, 11:58 PM   #10
Still need:
dont forget about $ to recharge the a/c unless you already got the stuff and doing it yourself
Old 04-03-2008, 08:21 AM   #11
ls1 junkie
andrew69_04's Avatar
andrew69_04 is on a distinguished road
1 week is doable. I had mine in the truck and fired once within only a few days. I only worked on it in the evenings after work. I wouldnt try to rush it becuase thats when you will half ass something and wont be happy with the results. honestly, take your time and do it right, and do it once.
Old 04-03-2008, 08:34 AM   #12
[quote=andrew69_04;5108457] I wouldnt try to rush it becuase thats when you will half ass something and wont be happy with the results. honestly, take your time and do it right, and do it once.
my point exactly.... i had my lt1 t56 fired up in a couple days, but it wasnt "done".... im talking driving, running cool, everything works as it did b4
Old 04-03-2008, 09:04 AM   #13
Jonce007's Avatar
I hear ya on that one. I'm planning on notching the frame for the a/c regardless. I might wait on hooking up the a/c until later though. We'll see how the swap goes. It sounds like you have been through these swaps before.
Old 04-09-2008, 03:24 PM   #14
well, having an lq4 picked up this weekend. after I see what condition its in ill decide if im gonna use it or not. but by the sound of it, new plans are to use this. Its an older one w/ the iron heads but w/ really low miles. plans are to do a nice head and cam combo still w/ a t56.
Old 04-12-2008, 08:22 AM   #15
LSx and V8 Mod
SweetS10V8's Avatar
SweetS10V8 is on a distinguished road
Dont those have the crank thats different than all the others? Longer flange or something...
Old 04-13-2008, 02:19 AM   #16
yea they do, not quite sure what im going to do w/ it yet.. run an auto/ figure out a way to make it work w/ a t56... ?? not quite sure yet
im picking up an extra cab 99 s10 w/ 96k miles in good condition for 2k tommorow (bad motor)
next thing i need to find are corvette accessories and prob a motor trans combo (depending on what im gonna do with the lq4)
Old 04-13-2008, 06:08 PM   #17
S-series Member
lilsonoma's Avatar
lilsonoma is on a distinguished road
I believe up until 2001. Whenever 6.0L's started coming out with the aluminum heads is when the shorter cranks came out. The longer crankshaft is a desirable item on eBay for those wishing to use a 700R4/Turbo tranny and not use a spacer or a custom torque converter.
Old 04-13-2008, 10:42 PM   #18
wow scratch that, me and my friend just drove over three hours (6hrs rd trip) to get a truck. he knew we were coming since friday and when we were about 1/2 hr away the guy has his wife call me and say its soldso we argued forever and the guy says too bad i just sold it for my asking price (same amount I was paying)
Old 04-18-2008, 11:56 PM   #19
well i got the 6.0l and its just so clean and complete im going to use it. only 16,000 miles. I had it all of one day before I took the crank out and found a crank on ls1 tech out of an ls2 w/ only 1800 miles for $120
Old 04-19-2008, 11:42 AM   #20
Jonce007's Avatar
Are you kidding me? I would be a little bit peeved to say the least. I had a similar thing happen to me. I was looking at a truck and I told the guy I wanted it, just needed to get a loan. Well the truck was parked for sale right outside of the bank. My father and I had to run some errands and then we were planning on going to the bank to get a loan. I got to the bank and got the loan. As I'm coming out of the bank walking across the parking lot, the owner was letting someone else test drive it. When the owner and the test driver came back, he said it was sold. I was sitting there with $4000 cash in hand. I was bummed.
Old 04-19-2008, 04:09 PM   #21
its just greg
AmericanMuscle's Avatar
AmericanMuscle is on a distinguished road
hey jonce, what year vette radiator did you get? sorry to jack the thread but I'm trying to make sure I have everything.
Old 05-17-2008, 02:14 AM   #22
finally got a truck its a 2001 extra cab ls black 4cyl 5speed, all stock, from orig. owners... it has a few minor dents, needs a new hood, and could use new carpet. It doesnt run due to a bad alternator and bad bat. got it for 1500 im pretty stoked about it.
edit: also ordered the rad., arp rod bolts, new head and main bolts, throttle cable and cruse cable
Old 05-17-2008, 03:39 AM   #23
oh and it has 135,000 miles
Old 05-22-2008, 01:57 AM   #24
hooked it up to the charger and it fired right up. runs good . also found out its the zq8 edition.
Old 05-23-2008, 01:17 PM   #25
from what i understand, if the 8th # on the vin is a 5 its a flex fuel truck... if so, looks like i wont need to mess w/ a fuel pump since its a flex fuel
Old 05-23-2008, 05:01 PM   #26
the last pic is of a before and after, i didnt buff the hood since it needs a new one and i wanted to see a before and after(thats how the whole truck looked)
the grill is off since its all faded, needes a new one
Old 05-23-2008, 09:16 PM   #27
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
yea, if its got a 5 in the 8th digit, you got a good ls1 swapper...ha
Old 05-27-2008, 12:55 PM   #28
its just greg
that was a damn steal!!
Old 05-30-2008, 01:40 AM   #29
little update in whats going on...
-i found a built t56 on ls1 tech, should ship out mon of next week
-ordered up the harness and headers
-decided since the harness is going to take so long im not going to wait until all the parts are here to get started... so @ about 3:30 I started pulling the motor and trans and finished up around 8:00
as soon as the flywheel gets in, im sending the internals out to get balanced, then its all going in.
Old 05-30-2008, 05:32 PM   #30
Jonce007's Avatar
Sounds like you have nice project starting! The 6 speed makes me drool, too cool.
Old 05-30-2008, 08:16 PM   #31
all empty
motor and trans
I decided against the hummer pan so i didnt have to wait and because its cheaper this way.
before
Old 05-30-2008, 08:23 PM   #32
ls1 on the works!!
bitchin sonoma's Avatar
bitchin sonoma
i would of been pissed offf like hell, when me and mu dad look for cars i always tell them that i am coming, and they do wait,thank god!!some people are bitches!
Old 05-31-2008, 02:50 PM   #33 <
