ls1 rear brake brackets needed!!!!
hey guys i got the calipers and rotors off a LS1 camero. I still however need the brackets that contain the ebrake still and im having a hard time finding them at the junkyard... The bracket bolts onto the rear axle with 4 bolts and also holds the calipers in place. If anybody knows where i can find them it would be a great help.
dealer, or junkyard.
At the dealer there 90 bucks a peice and i need 2....
I tried all the junk yards here and they all look at me like im crazy... not having good luck as of yet.. |
up to sumthing
if you find some for cheap I need a pair also.....
ZQ8 2001
Store bought ain't custom
check out ebay. I've seen a couple of them up there before.
DooR DraggeR
will the brakets from the ZR 2 blazers work?
I know where there's about 3 pair of brackets still on the axle housings..... the rotors & calipers were gone.... |
Hmm i dont think so this piece has the ebrake/drum built into it so i need that piece i think there diffrent.
Im having no luck
DooR DraggeR
well, the rearends I saw had this ebrake drum setup...it was new to me that's why I remember it....the drum from the 2000 ZR2 was still green & looked unused or barely used...
I posted something in the forsale about this a while ago cause I saw like 3 or so rears @ the local salvage yard that had the calipers & rotors removed...guesss they do that to most stuff that comes in cause they can turn them into a place that rebuilds them. anyway, hope that info helps...i could go back up there for the whole backing plates & brakets if you want them... just drop me an email or post something here....might be best to send me a pic of your setup or the one your looking for so I'd have a better idea of what to look for. later- |
10434796 and 10434797 are the part numbers here is a pic of it its the caliper bracket assembly with e brake stuff. I called this camero place today some hillbilly answered said 60 bucks plus 12 shipping.. but i forgot to ask him if that was 60 for both. I see on gmparts direct there about 70 a peice with shipping which i might do if i cant find the part no where else.
| Sponsored Links | |
Advertisement | |
