ls1 questions
Old 01-21-2007, 10:49 AM   #1
ls1 questions
im planing on swaping in a ls1 and i need to get some help from you guys. my truck is an 02 extended cab 4.3 auto and am swappin a 00 ls1 out of a z28. will my stock fuel pump flow enough for the new motor? will a ls2 oil pan work on a ls1 ( cause it looks to be shorter ) would it require less crossmember modifications? also, if i swapped my accesories brackets out for corvette ones would i still need to notch the frame for any componants?
thanks alot,
rob
Old 01-21-2007, 03:26 PM   #2
Re: ls1 questions
I believe with the ls2 pan you don't have to notch as much, but have to redo the drain plug. As for the corvette accessories, yes you should be able to get away without notching into the frame either since the a/c mounts high.
Old 01-21-2007, 05:09 PM   #3
Re: ls1 questions
thanks alot. does anyone know if my stock fuel pump is big enough?
Old 01-21-2007, 05:21 PM   #4
Re: ls1 questions
The stock 4.3L fuel pump should be fine, you use a corvette fuel filter to change the lines to the right size for the engine.
Old 01-21-2007, 05:36 PM   #5
jhankinson's Avatar
Re: ls1 questions
even with the corvette acces. if you plan on keeping the A/C compressor in the stock spot..you have to notch into the frame...it still doesnt fully clear. As for the LS2 pan...you dont have to notch the whol back of the xmember...just the top side of it...as far as the drain plug..its easy...drill a hole through the xmember and weld a pipe into it...it works like a funnel....and some people....have gotten away without any mods to be able to drain it still.
Old 01-21-2007, 07:14 PM   #6
Re: ls1 questions
thanks
Old 01-21-2007, 07:19 PM   #7
STPSYDR
BLACKZQ8stepside's Avatar
Re: ls1 questions
Quote: Originally Posted by XyellowX
thanks
As long as we're on the subject of Accessories, does anyone know if the PS pully will clear the steering box with this setup?,...(click the link)
http://www.marchperf.com/pg56.html
Old 01-21-2007, 07:21 PM   #8
Re: ls1 questions
That mounting looks like what black x has, you should pm him to get in here and answer questions
Old 01-21-2007, 07:31 PM   #9
9.38@153.6
Black X's Avatar
Re: ls1 questions
Some one say my name???
A/C for www.hotrodlane.cc no cutting required
Old 01-21-2007, 07:35 PM   #10
STPSYDR
Re: ls1 questions
I PMed you
Old 01-21-2007, 07:44 PM   #11
Re: ls1 questions
Black x, do you know if my stock 4L60e will bolt up to a 5.3L 2004 or do i need another one? Do you have the part numbers for all the accessories you ordered too...
Old 01-21-2007, 07:48 PM   #12
Re: ls1 questions
is that setup cheaper than converting to corvert acc. ? will it clear the stock hood?
Old 01-21-2007, 08:08 PM   #13
9.38@153.6
Black X's Avatar
Re: ls1 questions
Alternator (1)10246634 (production) 10316182 (service)
Alternator to bracket bolts (2) 24503609
Alt bracket to head bolts (3) 11516357
Alt bracket to head bolt (1) 11516356
P/S fluid reservoir bracket (1) 12555222
P/S fluid reservoir (1) 26046502
P/S reservoir hose (1) 26046910
P/S reservoir cap (1) 26022453
P/S pump (1) 26046503
P/S pump pulley (1) 12559890
P/S pump brace (1) 12555693 Same as f-body
P/S pump bolts (2) 14078896 Same as f-body
P/S pump bolts (2) 11515758 Same as f-body
Belt idler pulley (1) 12564401 Same as f-body
Harmonic balancer (1) 12560115
Belt tensioner assembly (1) 12559325
A/C belt tensioner assembly (1) 12560345 Same as f-body
A/C belt idler pulley (1) 12557334
A/C compressor bracket (1) 12556444
A/C compressor (1) 1137031
A/C bracket stud (1) 12556447
A/C bracket bolt (1) 11515768
A/C compressor bolt (1) 11516714
A/C compressor bolt (1) 12552922
A/C compressor bolt (1) 11509202
A/C compressor nut (1) 10255857
alt/ps pump bracket (1) 12555220
Old 01-21-2007, 08:11 PM   #14
9.38@153.6
Black X's Avatar
Re: ls1 questions
Yes it Will bolt up no problem you will need
(6) 12563533
(1) 12563532
As shown here:
http://jeepinpete.com/engine_trans_a...ans_adapt1.htm
Old 01-21-2007, 08:12 PM   #15
9.38@153.6
Black X's Avatar
Re: ls1 questions
My setup is all Corvette with the exception of the A/C setup
Old 01-21-2007, 08:22 PM   #16
Re: ls1 questions
The p/s hose and cap numbers aren't working. Thanks still!
So you only ordered the a/c from hotrodlane.cc? And then purchased the rest ahh...
Do any of the accessories overlap with the stock 5.3L accesories before i go crazy spending?
Old 01-21-2007, 08:30 PM   #17
9.38@153.6
Black X's Avatar
Re: ls1 questions
Some of the bolts might be the same length but that my friend is all....
Old 01-21-2007, 10:05 PM   #18
Re: ls1 questions
Black X are those gm part numbers or part numbers to the company you bought the brackets from
Old 01-21-2007, 10:07 PM   #19
Re: ls1 questions
GMpartsdirect i believe
Old 01-22-2007, 11:36 AM   #20
9.38@153.6
Black X's Avatar
Re: ls1 questions
GM part numbers.
I got mine from www.partszoneonline.com
Old 01-22-2007, 01:22 PM   #21
Re: ls1 questions
Does anyone know the LS2 oil pan parts numbers that i need? I think the gto pan, dipstick, dipstick tube? What else do i need?
Old 01-22-2007, 10:41 PM   #22
gumbys-10's Avatar
Re: ls1 questions
I used the corvette ls2 pan,I thought the gto pan was front sump,but here are all the numbers I got.
LS2 Part Numbers
LS2 bare block = 12568950
LS2 crate motor = 19156261 (formerly 12499750)
LS2 longblock assembly = 89017654
LS2 camshaft = 12574519
LS2 timing chain = 12586482
LSx lifter = 17122490
LS2 front cover = 12600325
LS2 rear cover (same as LS1/LS6) = 12572014
LS2 90mm throttle body with actuator (same as LS7) = 12570790
LS2 throttle body attachment fastener x4 = 11519971
LS2 throttle body attachment seal = 12576549
LS2 MAP sensor = 16212460
LS2 intake manifold = 89017648 or 12589181
LS2 intake to cylinder head gasket x8 = 12580833
LS2 intake manifold attachment bolt x10 = 12552344
LS2 intake manifold sight shield, LH = 12568998
LS2 intake manifold sight shield, RH = 12569246
LS2/LS7 valley cover = 12570471
LS2 fuel injector assembly x8 = 12569113
LS2 fuel injector o-rings (orange) = 89017587
LS2 fuel injector retainer clip x8 = 24503227
LS2 fuel rail = 12572174
LS2 fuel rail attachment bolt x4 = 12590276
LS2 front coolant tube = 12578838
LS2 rear coolant plugs x2 = 12563325
LS2 polished rear wheel = 9594349
LS2 valve springs (same as LS6) = 12586484
LS2 valve pushrod cover guide (lifter tray) = 12595365
LS2 cylinder heads (same as LS6) = 12564825
LS2 cylinder intake valve (same as LS1) = 12563063
LS2 water pump = 89017457
2005 Corvette C6 LS2 exhaust manifold, LH = 12569388
2005 Corvette C6 LS2 exhaust manifold, RH = 12576061
2004-05 GTO LS1/LS2 exhaust manifold, LH = 12563277
2004-05 GTO LS1/LS2 exhaust manifold, RH = 12563278
2003-05 SSR LH6/LS2 exhaust manifold, LH = 12567483
2003-05 SSR LH6/LS2 exhaust manifold, RH = 12567484
C6 LS2 oil pan (has shallow rear sump) (kit with bolts/gasket) = 12581810
C6 LS2 oil pick-up screen (same used on LS6) = 12558750
C6 LS2 oil deflector (same as used on LS6/LS1) = 12558189
C6 LS2 dipstick = 12570788
C6 LS2 dipstick tube = 12570787
SSR/Trailblazer 5.3L/LS2 oil pan (has front sump with hole for 4wd front axle) = 12579723
GTO LS1/LS2 oil pan (has front sump) = 12581209
2005 GTO LS2 PCM = 92180030
2005 GTO LS2 ECM = 12597883
LS2/LS7 spark plug wires = 89018058
LS2 flywheel = 12571611
Old 01-22-2007, 11:22 PM   #23
Re: ls1 questions
Yeah, the parts number thanks, but do what all do i need besides the ban, dipstick, and dipstick tube? Like what is the pickup screen and deflector?
Old 01-23-2007, 12:57 AM   #24
The creeper next 2 you...
gmax111's Avatar
Re: ls1 questions
call em and tell em you need to convert your f-body pan to a ls2 pan...
Old 01-23-2007, 01:29 AM   #25
Re: ls1 questions
I was hoping the guy that started the blazer conversion and used the ls2 pan would chime in since he said he didn't have to notch...
Old 01-23-2007, 03:58 AM   #26
gmax111's Avatar
Re: ls1 questions
dude i just finished the swap.. I had a huge thread about the whole swap before the forum went down... i know almost everything there is to know... the only way NOT to notch the frame is to cut the truck pan up to clear the frame and the ground..
OR... put spacers under the mounts and use the ls2 pan...
Old 01-23-2007, 09:36 AM   #27
Re: ls1 questions
The blazer engine mounts are higher up. Someone had just started a project of it and had pics and everything where it cleared because of this. The aspect of having a body lift and higher engine mounts is very nice.
Old 01-23-2007, 07:50 PM   #28
gmax111's Avatar
Re: ls1 questions
yes i know.. all blazers have higher frame isolator pads... if you want to be lazy or for some other reason you dont want to cut the crossmember your going to have to use the ls2 pan and make the motor sit like an inch or so higher... your going to have to work around the brake booster and the a/c box if you do that but thats the price you pay for not cutting the crossmember... Otherwise its not going to work out...
if your so worried just cut the truck pan up but that isn't the best idea either because once u cut/weld hardend aluminum its not going to be hardend anymore... and if you do this make sure you patch the parts of the pan you cut out back up with the pieces of spare pan you have... and use a tig... you dont want to go mixing metals up with the stock pan because it wont hold... and there isn't a metal that can compare to what gm casts their oil pans out of... measure 10 times before you cut because your going to need all the pieces of the pan you cut out...
Old 01-23-2007, 07:52 PM   #29
gmax111's Avatar
Re: ls1 questions
and until i did this swap not cutting the frame was unheard of... With what i've learned and what 99Bucket has done it was made possible... but before us it basically was not possible...
although i did end up cutting the crossmember...
Old 01-24-2007, 09:32 AM   #30
Strictly Domestic
PEKO's Avatar
Re: ls1 questions
Christobevii3 P/S hose part# 15907878 and the cap part# 10317982
Old 01-24-2007, 09:47 AM   #31
Strictly Domestic
PEKO's Avatar
Re: ls1 questions
Only thing that sucks is do I buy a engine new from GM (since I work for them) or get one at a junkyard. Id like to stroke it etc so atleast if I buy a new crate motor I could sell off the parts I dont use to pay for the new stuff.
Old 01-25-2007, 09:34 PM   #32
Re: ls1 questions
Blackx, what is the serpentine belt you used if i get the accessorries you have?
