ls1 brakes on an 82
Old 07-24-2006, 08:49 AM   #1
1syksdym's Avatar
ls1 brakes on an 82
are they basically a bolt on or is there anything special i need to know? i know about the washers behind the backing plate
Old 07-24-2006, 10:00 AM   #2
Draggin Moderator
98layinframe's Avatar
Re: ls1 brakes on an 82
well the backing plate on the first gens are different then the newer trucks.. so you might have to cut the backing plate off and drill some new holes to mount up the ls1 caliper mounting bracket. Reason is the newer rearends have a little square mounting plate on them, while the older rearends have a tall rectangle shaped mounting plate.
Page generated in 0.56444 seconds with 31 queries
[Output: 43.14 Kb. compressed to 41.52 Kb. by saving 1.63 Kb. (3.77%)]
