#51 |
Need LSx swap.....
Re: LS engine oil pans - all of them
corvette LS2
#52 |
Crazy As Fuck
#53 |
Need LSx swap.....
no prob
#54 |
Crazy As Fuck
so... with the ls2 pan do I need to cut the crossmember? and it doesn't hang down at all?
I just want to be absolutely positive b4 I start spending money and it doesn't all work out.... |
#55 |
Build them right....Mod
You'll still have to trim and box the crossmember, but you'll have plenty of ground clearance.
#56 |
Crazy As Fuck
thanks
#57 |
any oil pans fit with no notching in a 2nd gen 2wd blazer?
#58 |
Need LSx swap.....
H3 alpha pan...
#59 |
stupid oil pans! shesh!
#60 |
Need LSx swap.....
lol agreed
#61 |
is the truck oil pan pick-up tube transferable to the H3 pan?
#62 |
H3 hummer oil pan fits 2WD without cutting Crossmember. However, several guys have trimmed and boxed the crossmember to allow for easier R&R of the motor.
LS2 Corvette oil pan fits 2WD with a mild cut and weld on the crossmember. This one provides the greatest ground clearance There is no un-modified factory pan that will fit a 4WD application. SYTY performance.com (ghettosled) is working on an LSx pan for the AWD Syclone/Typhoon (which is the same as the Gen1 Blazer/Truck) and probably close to the Gen2 fitment. Estimated cost: $500+ Delivery: Mid to late Feb 2009. |
#63 |
Brandon |
#64 |
what is the year application of the H3 oil pan?
or part numbers of the pan , pickup and windage tray(if requiired) |
#65 |
i have a complete kit from GM Performance with all the parts available
i was going to use it in a 1st gen camaro, going a different route. PM me if you are interested, i live in SE MI reply to 04Xtreme gm part # for H3 Alpha kit 19212593 Last edited by oldschool 69 : 02-02-2009 at 04:00 PM. |
#66 |
#67 |
boosted 2.2L
Has anyone seen the gm muscle car oil pan kit?
p/n 19212593 susposed to fit virtually all 55-95 front engine rwd v8 cars 5qt capacity. http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 112 of the pdf shows a pic. |
#68 |
#69 |
boosted 2.2L
curious of ground clearence |
#70 |
it sits above the crossmember on 2nd gen 2wd blazers, hangs 1/2" below the crossmember on 2nd gen pickups |
#71 |
#72 |
Need LSx swap.....
yea its almost like they were made for the 2wd blazer swaps...
#73 |
and a H3 Alpha pa in a 2wd 2nd gen truck
#74 |
will i need to get a new tube and dipstick when i go to the ls2 corvette pan or just a new dip stick. also for those that are looking for them and cant find them any where here they are for 250$ http://www.gmpartsdirect.com/
look up part number 12598186 its a helluva lot better than the 485 for the one i saw on ebay |
#75 |
i checked today at the local chevy dealership. looked under the colorado that had the v8 in it. and uses the the same oil pan part number as the h3 oil pan. some people already knew this. if you didnt. now you know. lol.
#76 |
5-Speed Blazin
#77 |
Need LSx swap.....
#78 |
5-Speed Blazin
Haha what an oversight, thanks! Guess im rollin a H3 alpha pan for sure.
#79 |
I'm wondering if you guys can help me a bit,I got a '94 body with an LS1 2000 and i need a custum oil pan,which one would be the best? and i got no room for my driver's side headers cause of the shaft that goes in the steering box some1 got answers plz? thanks agains lats
#80 |
Need LSx swap.....
read the stickies, you dont need a custom pan...read this thread and youll see what one you need
#81 |
#82 |
blabla
is there any difference in ls2 and ls3 oil pans, any difference in camaro(ls3) and vette(ls3) oil pans
#83 |
#84 |
Need LSx swap.....
havent seen a new camaro pan yet, but usually each vehicle has its own pan so there is bound to be some difference.
#85 |
Thanks for all the pictures and info, guys.
#86 |
Need LSx swap.....
#87 |
There seems to be quite a few 5.3 truck pans floating around my area for sale. I know that the H3 5.3 pan will fit without any cutting and that it hangs down a bit but will the 5.3 truck pan fit without any alterations? Sorry if it's posted and I didn't see it.
Thanks in advance. |
#88 |
Need LSx swap.....
youll need a notch with that one, or modify the pan itself.
#89 |
#90 |
Need LSx swap.....
no problem
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f213/ls-engine-oil-pans-all-of-them-324366/
| Oilpan Comparison and Part Numbers - LS1TECH | This thread | Refback | 11-30-2007 11:35 AM | |
| Untitled document | This thread | Refback | 11-30-2007 10:58 AM | |
| Oilpan Comparison and Part Numbers - LS1TECH | This thread | Refback | 11-27-2007 06:19 PM | |
| Hummer oil pan in ls1 camaro - Pro-Touring.com | This thread | Refback | 11-24-2007 06:55 PM | |
| Hummer oil pan in ls1 camaro - Pro-Touring.com | This thread | Refback | 11-23-2007 01:32 AM | |
