#1
Build them right....Mod
LS engine oil pans - all of them
Hummer H3 5.3:
![]() ![]() LS2 Corvette: Pan - 12598186 Screen - 12558750 Gasket - 12580672 Tube - 12570787 Dipstick - 12570788 ![]() LS1 F-Body: ![]() Holden: ![]() GTO: ![]() Trailblazer SS and 5.3: ![]() Truck, Escalade, etc: 4.8, 5.3, 6.0 ![]() 2007 Truck with filter: ![]() Moroso: Gen 1 camaro ls1/6 ![]() Turbotime: ![]() Autokraft: ![]() Autokraft Gen 1 camaro ls1/2 swap pan: ![]() Canton LS1 swap pan: 5 -1/2" Deep, 8 -3/4" Long, 12 -1/12" Wide sump, For a 6 -1/2 quart sytem capacity. ![]() CTSV: ![]() Renegade Hybrids has a Steel pan for an S10 2WD LS engine: No pic yet. Last edited by philntx : 03-04-2009 at 04:43 PM. |
s10 newb
Re: LS engine oil pans - all of them
great post. Good info.
Bee-u-tee!!
LSX Swapper
These should be stickyed and locked for no whore posts.
9.52@152.65
Good job bro. And Thank you for your hard work.
Need LSx swap.....
great info. now we just need to find out which ones fit lol
RITALIN, IT LOVES ME!
I applaude you sir, very well played.
if anyone has their engine bay empty maybe they could make some measurements of where the block sits in relation to the crossmember with the mounts being used. it would give others an idea of how much would need to be cut, if any at all.
9.52@152.65
My engine will be out before long here guys. I can get some good measurments at that time
9.52@152.65
mad man!
Need LSx swap.....
thats awesome!!!
he,he,he project over kil
nice!!!
An ol Scott
Location: Greenville/Simpsonville SC User is: OffLine |
Oil pan fit is not good at all so it forces us to cut up the front cross member way to much. I hope one of these pans will atleast reduce the ammount of choping up the front crossmember we need to do.
I need to do the swap soon so this information is important. Thanks for the post. Now all we need is for someone to figure out which one is the best fit for our S10's. I expect I'll probably have a problem with the depth of the sump anyway because my truck sets 4in lower now. |
![]() Will |
An ol Scott
What to put here?
I happen to see a oil pan like this at a swap meet yesterday,...
![]() And was wandering it the wing part was far enough back? (It probably will not work but was just wandering.) Also how about some thing like this.....http://www.drysump.com/pan1a.htm It would probably cost more but was just wandering. Thanks guys! |
9.52@152.65
Thats a C5 Vette pan. It will not work in the s10 unfortunatly. It sure looks coool though. |
What to put here?
Well I thought that would be the case. O well. And yes it does look cool. Kind of like a space craft. ![]() |
Has Anyone Figured Out The Measurments Needed For Clearance Of The Crossmember? Will The H3 Pan Work? Which One Would Require The Least Amount Of Cutting?
#24 |
LSX Swapper
My h3 pan didn't require any cutting of the crossmember.
2.8 frame mounts s10v8.com block mounts |
#25 |
can you post the exact part numbers for the whole h3 pan set up,because I am ready to order it. |
#26 |
LSX Swapper
if you have a drop then this pan isn't for you. The pan hangs down past the x-member |
#27 |
any first gen pan ideas i gettin ready to buy the ls2 pan wahat do yall think for first gen blazers 2wd
#28 |
ɔıɹɔ&
Anybody try using that holden pan?
looks like it would work.... by the pics of course. anybodu got part numbers? |
#29 |
takes 2 balls in our game
I think the ls2 pan is the best fitment in my opinion....yea, you need to notch a little but I dont think its that bad.On the blazers,all you have to do is heat up the crossmember and "bang bang" it in a little...lol
#30 |
Thizz or Die u bezzy. . .
Location: Fresno, CA AKA The Central Valley User is: OffLine |
Saw these swap pans form www.t56kit.com and had to post them
LS7 Semi dry sump road race oil pan ![]() Fabricated road race LSX oil pan ![]() ![]() |
#31 |
#32 |
Good Bye SonomaST
im not sure how a escalade pan will work, ill draw up a little oilpan and my measurements here afterwhile. just for a reference. its different than the 07 silverado's. i was bored at work and had one on the lift so measured lol
#33 |
Strictly Domestic
here is a nice pic I found F body pan (Right) and H3 and V8 Canyon and Colorado pan (left) Pic is from brphotrods.com |
#34 |
SPRAYINLOW
i have a question on the canton swap pan: is that a gen 1 s10 or gen 2 s10 swap pan,if it is gen 2 what is the part number?
my boss/good friend is a canton dealer and i can get it for cheap thanks,chandler |
#35 |
The Buick and S10 nut...
#36 |
i know the new impalas have a 5.3 and wwd i wonder if any of those might be a possibility for swap pans the block architecture should be the same right
thanks george |
#37 |
Need LSx swap.....
![]() more LS4 info/images here: http://www.gmtuners.com/LS4/index.htm |
#38 |
So is there any oil pan i can run that will not hang down lower then the frame or crossmember?? i have a 2000 s-10 bagged and i couldn't have it hanging down. PLease help!!!!
#39 |
![]() Last edited by SweetS10V8 : 08-01-2008 at 05:54 PM. |
#40 |
Blue-X
I wonder if jared will ever fab up a lsx pan for the s10?
#41 |
Okay i have searched high and low and cannot find this ls2 pan anywere. the only ones i find for a vette have the wings. Can some one help me out this is the only hold up on my project. I have headers motor mounts and what not here just waiting to get a oil pan so i can begin notching.
#42 |
call any dealership and order it.......???
#43 |
What pan is that???
http://www.s10v8.com/store/product_i...657ca9c03d7acc never mind looks like the H3 pan Last edited by Dmarsh525 : 10-31-2008 at 10:11 PM. |
#44 |
http://carshop.carshopinc.com/produc...1227a48b2c3303
what pan is this? Last edited by s10-den : 11-01-2008 at 11:58 AM. |
#45 |
H3 Alpha 5.3
#46 |
oh, thanks Phil.I noticed it said little to no mods.But, isnt this the one that causes a pain to drop the tranny with the sump hitting the crossmeber?
#47 |
Need LSx swap.....
#48 |
morroso
#49 |
i thought i had a picture of my oil pan. i will take some pics tommorow.
#50 |
Crazy As Fuck
ok so looking over all of this I am still confused..... I'm looking at the 5.3 swap but will be bagged in the front..... which pan is for me?
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f213/ls-engine-oil-pans-all-of-them-324366/
| Oilpan Comparison and Part Numbers - LS1TECH | This thread | Refback | 11-30-2007 11:35 AM | |
| Untitled document | This thread | Refback | 11-30-2007 10:58 AM | |
| Oilpan Comparison and Part Numbers - LS1TECH | This thread | Refback | 11-27-2007 06:19 PM | |
| Hummer oil pan in ls1 camaro - Pro-Touring.com | This thread | Refback | 11-24-2007 06:55 PM | |
| Hummer oil pan in ls1 camaro - Pro-Touring.com | This thread | Refback | 11-23-2007 01:32 AM | |
