Long's Tru-Cool 40K GVWR Trans Cooler Install - S-10 Forum
post #1 of 22 Old 01-26-2010, 06:27 PM Thread Starter
CODE4LS1's Avatar
User is: CODE4LS1 is offline
I sent these pics to SleeperS10 already per his request, but I wanted to post them up here as well in case someone out there wants to know what a 40K GVWR cooler looks like installed in front of CW's radiator and condensor.
Some may question wether it's too big or that there's too much media in front of the fans to cool, but I can attest that in 110+ degree days in SoCal last summer, these fans kept my coolant temps UNDER 200 degrees, regardless of the condensor and huge cooler. Anyway, enjoy!
CODE4LS1 is offline
post #2 of 22 Old 01-26-2010, 08:58 PM
97ls1s10's Avatar
User is: 97ls1s10 is offline
Re: Long's Tru-Cool 40K GVWR Trans Cooler Install
damn that thing is huge
97 extcab s10 with a stock 04 lq4 with shortys and intake,8.8 3.73 posi,blazer front end,rear mount t70,water to air intercooler,60lb injectors,and home made piping !!!!
97ls1s10 is offline
post #3 of 22 Old 01-26-2010, 10:22 PM
Mr Cheech
Sleeper S10's Avatar
User is: Sleeper S10 is offline
Thanks again for posting those!!! That and the info on it to purchase one.
I just had mine come in today.
It will go great with my FLT Level 5.
FLT said the bigger the cooler the better.
LS2 402 STROKER SWAP:
http://www.s10forum.com/forum/f213/s...x-swap-430296/
S10 Sonoma Envoy Swap - NEW & 99% COMPLETE!
Best offer!
http://www.kijiji.ca/v-view-details....teLocale=en_CA
Hellwig Rear Sway Bar - New Other
Best offer!
http://www.kijiji.ca/v-view-details....dId=1124629793
post #4 of 22 Old 01-26-2010, 10:57 PM Thread Starter
CODE4LS1's Avatar
I didn't go as far as installing a trans temp gauge, but in those hot summer days in SoCal I removed the grille after a lenghty drive and the cooler was only luke warm
CODE4LS1 is offline
post #5 of 22 Old 01-26-2010, 11:09 PM
Need LSx swap.....
Kampz69's Avatar
User is: Kampz69 is offline
Send a message via AIM to Kampz69
i cant disagree with that
glad to see the cooling package worked well with all the parts installed like that, i wonder what the trans temps were? u thinking about installing a temp guage in the future?
Nick
Currently Blazerless...but looking
Graphite Double Din bezel for sale, PM me!
OEM new Maroon plastic air dam for sale, PM me!
Originally Posted by AVdime View Post
it was just an old factory with a bunch of whores
Kampz69 is offline
post #6 of 22 Old 01-26-2010, 11:16 PM
Need LSx swap.....
Kampz69's Avatar
also what cooler is that? 4739? do you plan on driving the truck when its below freezing out?
Nick
Kampz69 is offline
post #7 of 22 Old 01-26-2010, 11:22 PM
Mr Cheech
Long Tru-Cool Max:
transmission cooler - #LPD47391 (w/o external thermal)
rating: 40,000 GVW, 45,000 BTU's
size: 8.5" x 22" x 1.25"
inverted flare HEX fittings: 3/8"
Best offer!
Best offer!
post #8 of 22 Old 01-26-2010, 11:25 PM Thread Starter
CODE4LS1's Avatar
I have thought about it, but I will prob never do anything that would facilitate the need of a gauge. I heard lots of good things about them though, and the full size guys have had great results with high stall converters.
CODE4LS1 is offline
post #9 of 22 Old 01-26-2010, 11:26 PM
Need LSx swap.....
Kampz69's Avatar
i guess my only concern with this is the required thermal bypass for areas that see below freezing...im assuming it operates like a thermostat somewhat and "opens" at a certain temp?
Nick
Kampz69 is offline
post #10 of 22 Old 01-26-2010, 11:27 PM Thread Starter
CODE4LS1's Avatar
I can't remember if mine is 4739 or 47391....mine is the one without the thermal bypass and no, teperatures here are too temperate to worry about one.
CODE4LS1 is offline
post #11 of 22 Old 01-26-2010, 11:28 PM
Need LSx swap.....
Kampz69's Avatar
thanks for the info
Nick
Kampz69 is offline
post #12 of 22 Old 01-26-2010, 11:29 PM Thread Starter
CODE4LS1's Avatar
I have also heard about those thermal bypass deals failing, more than I think is allowable. I don't have all the proof to back that up though.
CODE4LS1 is offline
post #13 of 22 Old 01-26-2010, 11:30 PM
Mr Cheech
mine is also without the bypass. i don't winter drive mine.
Best offer!
Best offer!
post #14 of 22 Old 09-29-2010, 09:26 PM
xxcov3rxx's Avatar
User is: xxcov3rxx is offline
Send a message via Yahoo to xxcov3rxx
I would like to order this tranny cooler but i will be driving my blazer all season long. What do you have to do different with the cold weather bypass?
Also, what fittings and lines did you guys end up using?
Did you use new line from the tranny use whats already there?
-Michael-
[project] Murphy's Law
If you can't stand behind our troops then try standing in front of them.
post #15 of 22 Old 09-30-2010, 01:22 PM
Iroc-10's Avatar
User is: Iroc-10 is offline
Since this thread was resurrected I was wondering if you can tell me do you plumb the pressure side on top or bottom like a radiator?
Maybe Fall of '16 Turbonetics TC78
Currently Running:
6.0 / Ported 799 heads/ LJMS Stg2 cam
Yank SS3600
1994 SS S-10 Project CorectionSS LS swap-Running!
http://www.s10forum.com/forum/f213/p...tionss-495456/
1988 S-10 W/ Iroc Package, Screamin' Yellow -SOLD!
Iroc-10 is offline
post #16 of 22 Old 10-02-2010, 04:31 AM Thread Starter
CODE4LS1's Avatar
The Long's cooler I have has both inlet and outlet on the bottom of the cooler. I just ran the lines.
CODE4LS1 is offline
post #17 of 22 Old 06-02-2015, 01:56 PM
Clapps1775's Avatar
User is: Clapps1775 is offline
Has anyone install this in a daily driver who drives in the winter? I live in Iowa. I need to do something about my tranny being cooler then engine temp. I am getting a small leak at the top tranny line to the radiator. Wonder if having a brush guard hinders cooling?
Thanks,
Clapps1775
1994 Chevy S10 2.2 Auto 4X2 LS. Sold.
1995 Chevy S10 4.3W Auto CPI 4X4 LS. Traded off.
2003 Chevy S10 4.3X Auto 4X4 ZR2 LS current.
post #18 of 22 Old 06-05-2015, 02:14 AM
LSX Jimmy
moon509's Avatar
User is: moon509 is offline
Send a message via MSN to moon509
i've driven mine in about 35 degree weather but not often. My trans ever hits 180, but you can cover the front so it heats up in winter. Its a great cooler.
2000 GMC Jimmy 2wd 2 door / LQ9, L92 heads, 224/230 cam and LS3 intake part out in progress
2006 Trailblazer SS
2000 Olds Bravada- SOLD
moon509 is offline
post #19 of 22 Old 06-05-2015, 04:42 AM
Nightmare
Von Rottes's Avatar
User is: Von Rottes is offline
Send a message via MSN to Von Rottes Send a message via Skype™ to Von Rottes
HOLY HELL You could drive that through hell and the trans wouldn't overheat...
Nightmare '92 2wd RCSB with LM7 & 4L60E
~ Thread Here
Photography blog
post #20 of 22 Old 06-05-2015, 04:13 PM
Clapps1775's Avatar
I will price one out.
Thanks,
Clapps1775
post #21 of 22 Old 06-05-2015, 04:16 PM
Clapps1775's Avatar
....for $163 are there other ones like this for less?
Thanks,
Clapps1775
post #22 of 22 Old 06-05-2015, 04:25 PM
Ls1 Bagged
10Droped's Avatar
User is: 10Droped is offline
I have the same cooler, when I talked to Chris at Circle D this is what he recommend. They also sell a part that will tee into the stock radiator to bring the temps up for winter drivers. My truck never sees cold weather anymore so I don't worry about it.
Jim
99 S-10 Ext cab, Bagged, 20&22's Bonspeed Sweeps, 40"x35" Legacy sliding rag top,99 LS1/4L60E,Circle D 278mm 3200 stall,243 heads,PAC 1218 springs, BTR trunion kit, 228r 112Lsa,Ls6 intake,Bosch 36lbs injectors, Eaton Tru Trac, Moser Axles
10Droped is offline
