#251 |
its just greg
Re: I'm calling her Mia
they were hitting at where the one tube loops around the shaft, and on the front a little bit close to the steering box. i've been told that this issue is fixed with the new style that bolt in which you should have. |
#252 |
I will be getting the new style here shortly...Just wanted to double check...Now I'm trying to think of things that can be taken care now or while I'm deployed so that when I return it all goes smoothly....
#253 |
Did you ever get those coil packs on with those nifty brackets?
#254 |
its just greg
glad you asked. small update for you guys, was busy with house stuff most the weekend, but I got some stuff done and inching closer to being done. coil brackets on and wired, still need to grab some spark plug wires. ![]() got my bed on and the filler neck fabbed up, had some 2 inch exhaust pipe bent up for me, then I welded on the top of the stock filler neck so the cap works, and weled on the small vent hose. Its functional but not done, i'm going to bend up aluminum sheet to make a nice cover for that ugly hole. ![]() ![]() ![]() ![]() I got the core support on but no pics, I need to go make a junkyard run and grab a few things at the parts store, i'll have another update in the next few days. |
#255 |
i would also like to see some pics of them, i am going to have clearance problems there as well.
#256 |
must have been downloading as i was typing that looks good.lol
#257 |
its just greg
it was an easy fix, cut 2 tabs, welded them straight down from the existing holes, and drilled them. also cut off all the tabs I wouldnt need. didn't take more then an houre if that for everything.
#258 |
I'm sorry....but I'm gonna have to try and copy what you did to the ABS unit...nice work...
#259 |
its just greg
#260 |
Registered (Ab) User
The coils look great! Congrats on a great idea!
#261 |
Blue-X
so you are saying the abs cover has a constant thickness through it?
#262 |
Local Tech
beautiful build, man! Glad to see progress.... i hope you plan on having a bed cover with the fuel filler being exposed to rain, etc......
#263 |
its just greg
#264 |
Hmmm..My ABS unit may be a lil different because the cover doesn't come off and is kinda dimpled on the narrow part....
#265 |
Local Tech
[quote=AmericanMuscle;6607234]I will have on, but the filler neck seals just fine.
im just saying, cuz i relate this to the tpi vettes getting water in the tank, because the fuel filler door gasket was defective.... the caps were fine, but water could still get in... just tryin to help |
#266 |
What do you think you'll be doing for wires??? Also, i was rackin my brain trying to figure out how you were going to fill the rear mount tank. I read you used a pipe up the side, adn i'm thinking to myself that you ran a pipe all the way up to the stock filler location... NOPE! i was wrong, haha you're idea is WAY better~! |
#267 |
Hey Greg, what did you get your gas tank from and the lines going all the way to the rear?
a blazer maybe? thanks for your time |
#268 |
its just greg
I made the lines, my tank was from a 2002 2 dr blazer. all 2nd gen blazers are the same 17 gallons, 1st gen blazers(box style) have a smaller tank, I believe 13 gallons. |
#269 |
Moderator
Awesome work and details!
I wouldn't worry so much about rain, it barely rains here anyways. However, prerunner run through desert, sand, dirts, muds with it exposed, as long it's properly sealed, it's all good. However, I'd recommend locking gas cap and wrap around filler neck more(more theft deterrent for lousy thief). If they really wanted gas, it's easier to do it in stock location because gas hose is right there, you cut it and syhpon it out fast with bigger hose. I'm wondering, is there any fuel pump cut off in case of rear-ended? |
#270 |
its just greg
if there was one on the 2001 silverado's there will be one on mine, if not it will cut off when I turn the truck off. |
#271 |
the fuel injected 1st gen blazers had 20 gallon tanks. your engine bay looks like it was out of a magazine. keep up the good work. |
#272 |
its just greg
SHE HAS POWER!!
I was too scared to start her since I dont have any way of connecting my transmission cooler to her and there for have no fluid in the tranny. but I have power! fuel pump comes on, lights, interior, everything! I have a bunch of progress pics and some good info for everyone, but i'll update that this weekend. she will be started this weekend! for real this time! |
#273 |
Hurry up and start it.... it's suffocating in there!!!!
