How about an LS7 uder my hood?
Old 01-18-2007, 06:35 PM   #1
apexracer's Avatar
You think it's possible to put an LS7 in an s-10?
Old 01-18-2007, 06:47 PM   #2
I didn't build it for you
Dogsofjune's Avatar
Re: How about an LS7 uder my hood?
I've seen a 454 and a 502 stuffed into an S-10. Anything is possible. Might try the V8 Discussion area for better results.
Old 01-18-2007, 06:51 PM   #3
LS2OMFG
Ralphie's Avatar
Yup, it can be done. All that matters is the size of your wallet.
Old 01-18-2007, 07:00 PM   #4
<- nose bleed section
Splosion's Avatar
Yeah if you have almost 14G's for a crate motor or get one out of a wrecked corvette.
Old 01-18-2007, 07:31 PM   #5
rat
Got Fuel Rails?
rat's Avatar
The ls7 is the same size as any ls1, ls2, ls6, so yes, it would be a similar swap to those engines.
Old 01-19-2007, 03:46 PM   #6
the ls7 is bigger than ls1 and ls2 its a 427. its not as big as a 427 big block but its bigger and it would be very tight but doable
Old 01-19-2007, 03:56 PM   #7
rat
Got Fuel Rails?
rat's Avatar
No, it is just a bored and stroked ls1/2/6. Same as the 4.8/5.3/5.7/6.0/6.2 are all the same externaly. Or the gen 1 motors, 265, 305, 327, 350, 383, 400, all the same externaly. The cylinder walls are paper thin. This is a different motor than the old 427's.
ls2:
ls7:
They even use the same front end accessories. I bet you could even swap the truck front end stuff on there. Don't forget about the dry sump oiling stuff.
Old 01-19-2007, 03:59 PM   #8
LS2OMFG
Ralphie's Avatar
Took the words outta my mouth rat.
Old 01-19-2007, 04:05 PM   #9
ok my mistake, but i dont think they are the same as an ls1.
Old 01-19-2007, 04:07 PM   #10
that dude with the truck
jwl41085's Avatar
thats already been established it is not an ls1 its an ls7...
Old 01-19-2007, 04:09 PM   #11
see
Old 01-19-2007, 04:12 PM   #12
Molon Labe
BudRacing's Avatar
If the LS2 is the same size as the LS7 and the LS1 is the same size as the LS2, then the external dimensions of the LS1=those of the LS7.
Old 01-19-2007, 04:12 PM   #13
rat
Got Fuel Rails?
rat's Avatar
The ls1 and ls2 are very similar. They moved a couple of things around on the motors, map sensor i think, and a higher resolution crank/cam pos sensors. They are the same size externaly as well.
The only lsx engine that is different is the ls4 in the front wheel drive grand prix gxp/impalla ss. It is shorter by i think 10mm on the back, and a few more on the front. The intake manifold is also installed backwards.
Old 01-19-2007, 04:27 PM   #14
I'll need human lives...
1fast4by's Avatar
Geezz How many times can this be explained and re-explained, its getting old. All LSx series motors are the same externally dimention wise. An LS1 can be swapped into an s series...Then obviously an LS2,LS6,LS7, LM5, LQ9 blah blah blah will work. If you have the money then fine do it. However, it would be way way cheaper to drop in a built turbo LS1 (or better yet LQ9!) than to drop a crate bone stock LS7 in
Old 01-19-2007, 05:35 PM   #15
All about the bolt on's
roughneck427's Avatar
LS7 is a dry sump oiling system make way for lines and a resavoir with your swap and look to spend some money on an LS7 $12,000-$14,000 good luck
Old 01-19-2007, 06:56 PM   #16
Keepin' it Gangsta!
Dr. Steve's Avatar
wouldn't you have issues with the steering shaft being too long? for an LS1 swap that is...
Old 01-19-2007, 07:39 PM   #17
I finally got blown
99xtrm's Avatar
no it wont work ........but i guess ill take it off your hands i could probably make a coffie table out of it or ... something
Old 01-19-2007, 10:07 PM   #18
Keepin' it Gangsta!
Dr. Steve's Avatar
Old 01-19-2007, 10:20 PM   #19
TrailBlazin'
SuperSS27's Avatar
Ehh, Its not worth it. You are better off building an LS2 at half the price. Or like 1fast 4x4 said, an Lq9 from a caddy.
Old 01-20-2007, 12:14 AM   #20
... i dont know?
old_skool_noma's Avatar
if you have the money it can be done, im sure its a hell of a lot easier than a big block swap.
but yes it is dry sump oiling, another idea would be to find another block like an ls1 and bore it and stoke it to match that of a ls7, and also find the cam dimensions.
but as far is it being possible anything is possible with enough time and money
oh yeah heres the LS7 bore/stroke
427 = bore - 4.125" x stroke - 4.00" (2006 Gen.IV, LS7 SBC, titanium rods)
just for reference heres some other gm l series specs
345 = bore - 3.893" x stroke - 3.622" ('97-later, Gen.III, "LS1", 6.098" rod)
364 = bore - 4.000" x stroke - 3.622" ('99-later, Gen.III, "LS2", "LQ4" 6.0 Liter Vortec, 6.098" rod)
376 = bore - 4.065" x stroke - 3.622" (2007-later, Gen. IV, "L92", Cadillac Escalade, GMC Yukon)
for more info go here http://www.mortec.com/borstrok.htm
it has most gm v8 bore and stokes
Old 01-20-2007, 05:08 AM   #21
Keepin' it Gangsta!
Dr. Steve's Avatar
a catera engine would be easy enough to dump in....hmmm...
Old 01-20-2007, 11:53 AM   #22
rat
Got Fuel Rails?
rat's Avatar
What does that have anything to do with this? The catera had a 200hp 3.0L v6, not sure why you would even go to the trouble?
Old 01-20-2007, 12:17 PM   #23
Keepin' it Gangsta!
Dr. Steve's Avatar
I wouldnt go through the trouble, maybe the guy who mentioned cadilac would, its really the only feasable caddy engine considering the length of the s-series steering shaft, another caddy motor just wouldnt fit, at least through all the v8 swaps I have seen my friends try
Old 01-20-2007, 04:46 PM   #24
you can do that but you have to sleeve the block and you really pinch off the water jackets, the
LS7 has humps in the side of the block for extra clearance from the sleeves
Old 01-20-2007, 09:27 PM   #25
1fast4by's Avatar
We were talking about the LQ9 block...Escalade,Denali, 1500HD & 2500. Not some wussified 3.0 pile of shit Catera
Old 01-20-2007, 09:44 PM   #26
Keepin' it Gangsta!
Dr. Steve's Avatar
I see that
Old 01-22-2007, 05:20 PM   #27
Strictly Domestic
PEKO's Avatar
How about one of GM's new LSX blocks. Dont have pricing yet but they say it can handle up to 2,500hp and will be cheaper then people think. Comes out in March. GM and Warren Johnson got together
http://www.gmperformanceparts.com/En...54&engCat =ls
Old 01-22-2007, 05:25 PM   #28
Strictly Domestic
PEKO's Avatar
I can ge the LS7 crate motor for just over 12k, expensive but would be nice to say you have a LS7 in a S10. Cam and program have a nice 600hp NA
Old 01-22-2007, 05:46 PM   #29
Be cheap and get an lq9 block and put $8000 in parts on it and be on par or better than an ls7 easily.
Old 01-22-2007, 05:49 PM   #30
jinusow's Avatar
The price is just too much at this time. Everything will have to be upgraded not just the motor. I don't think you could finish it less than 18-20k. You'd have to install roll cage for the drag strip cause it would be a 10-11sec truck . Someone asked if the t56 can fit to the ls7 and yes one can, but isn't the new vette trans for the ls7 a 6spd auto anyways just get that.
Old 01-22-2007, 05:54 PM   #31
DroppedOnDuece210's Avatar
That LSX is gonna be insane, if you bore and stroke it to its max its 510 cubic inches
Old 01-22-2007, 06:27 PM   #32
rat
Got Fuel Rails?
rat's Avatar
No, the z06 runs the t56 manual only. The rest of the vettes run either the t56, or the new 6l80E.
I like the idea of a 408 with the new kenny bell twin screw in the valley.
Old 01-22-2007, 06:36 PM   #33
Build them right....Mod
philntx's Avatar
I say put a Honeywell LT-101 turbine engine in an S10 or a Viper motor ( )
Page generated in 0.64819 seconds with 31 queries
[Output: 152.96 Kb. compressed to 140.17 Kb. by saving 12.79 Kb. (8.36%)]
