hack is wack
got some questions about fuel and wiring
My truck is a flex fuel truck that came with no motor or trans. The stock tank looks different than a normal non flex truck so i was wondering if i can put the flex pump in a 'normal' tank? Next question, my wiring harness was all fuked up cause who ever pulled the motor didnt wanna do it right so they cut a bunch of stuff. .So what all does the CP wiring harness replace? Or what do i need to keep i should say. . .It had a weird smog pump and wires i pulled as well. . Can someone tell me what parts of my stock harness i need to hang on to? thanks a million.
Re: got some questions about fuel and wiring
keep your body harnessto all your lights his controls all engine and trans sensors not sure about the pump seems like it should work
s10 newb
Jareds harness completely replaces the engine harness from the fuse/relay box. Its the middle plug on the bottom of the box. The other two plugs and existing harness control all the body controls (lights, horn, wipers, abs ect.)
not sure about the flex fuel stuff, but these guys are right about jarred's harness. replaces the entire engine wiring system from fuse box to computer to trans, to engine.
hack is wack
cool thanks guys, ill just have to try and swap the pump and see if it works, i dont think the flex tank will fit under a bagged truck
cough cough FUEL CELL cough cough.
ew, i think something was in my throat? fuel cell's are cheap on ebay, get them for about 80-100$ |
The flex fuel pump will work to run the ls engine.
hack is wack
hack is wack
