Fuel Pump Problem
Old 10-24-2009, 12:03 AM   #1
Registered tire abuser
nastynova62's Avatar
Fuel Pump Problem
i have 86 blazer. when i turn key on i hear the fuel pump prime but it never gets fuel to the regulator at engine. i can hear a gurgling noise at tank. any ideas? pump bad? i put 3 gallons in it so it should have plenty to get to engine.
Old 10-24-2009, 12:22 AM   #2
On da bottle
zx9rgreen's Avatar
Re: Fuel Pump Problem
Is it the stock pump and stock wiring harness to the pump?
Old 10-24-2009, 12:29 AM   #3
yeah. all stock its been siting about 3 years but was running fine last time it ran. im ready to fire up the 5.3 but no fuel!
Old 10-24-2009, 12:39 AM   #4
On da bottle
zx9rgreen's Avatar
I dunno, did you try taking the cap off? Maybe the vent could be clogged or something?
BTW I see in your avatar you are carbed, do you have a return style regulator?
Old 10-24-2009, 03:36 PM   #5
yeah i tried cap off i took the filter at the engine off with no changes. i do have a return style regulator by mallory. it was all on there before the 5.3. i had a 350 in it before with carb.
Old 10-24-2009, 03:53 PM   #6
Sounds like your fuel pump came loose from the sender or the hose connecting them split.
Old 10-24-2009, 04:05 PM   #7
docstoy is probbably right
Old 10-24-2009, 06:23 PM   #8
yeah i had a feeling something was loose inside. thanks guys guess ill be droppin the tank monday!
Old 10-24-2009, 06:37 PM   #9
saskboy's Avatar
put more fuel in the tank, my pump made the same noise when i drained the tank using the pump.
Old 10-24-2009, 11:14 PM   #10
you think it would need more than 3 gallons to prime?
Old 10-26-2009, 11:39 PM   #11
BLAZIN1990's Avatar
Man I agree with above loose sending hose . Hey maybe try venting off air from the fuel rails it might help (that sometime happens on our aircraft then boom fuel spray with a lot of smoke)... lol ill stayed tuned to see what was the culprit.
good luck
Page generated in 0.57388 seconds with 31 queries
[Output: 72.38 Kb. compressed to 67.54 Kb. by saving 4.84 Kb. (6.69%)]
