fuel gauge not working.
Old 06-19-2008, 10:45 PM   #1
sargie26's Avatar
sargie26 is on a distinguished road
just finished 5.3 swap into my 98 sonoma. it had a 2.2 in it. the only guage not working is my fuel gauge. i was reading that that signal goes through the class 2 data port. but I don't know if the pcm is getting a signal. where does the wire go from the tank. then where does it go into the pcm?
Old 06-19-2008, 11:59 PM   #2
Toy Fabricator
v8power's Avatar
v8power is on a distinguished road
Re: fuel gauge not working.
Probably a conflict with the programming. DBW?
Old 06-20-2008, 01:02 PM   #3
Build it Right!
philntx's Avatar
philntx is on a distinguished road
Who did the harness?
Old 06-20-2008, 07:04 PM   #4
LS2Sonoma's Avatar
LS2Sonoma is on a distinguished road
theres a wire that goes from the tank to the pcm, then another that goes to the cluster. if you tell me what year your pcm is i can tell you pin location and colors to trace the wires
Old 06-21-2008, 03:47 AM   #5
sargie26's Avatar
i Did the harness. I must have missed a wire. The truck was a 98 2.2. Motor is an 01 tahoe 5.3
Old 06-22-2008, 02:34 AM   #6
sargie26's Avatar
found the wires. now the damn engine light is on. pardon the french
Old 06-23-2008, 03:24 AM   #7
Bone_s10's Avatar
Bone_s10 is on a distinguished road
get a 60 $ scanner and test it ,
Old 06-28-2008, 03:10 AM   #8
leonpiper69 is on a distinguished road
we have a matco scanner and the fuel gauge works now.
Old 06-28-2008, 10:49 PM   #9
LSx and V8 Mod
SweetS10V8's Avatar
SweetS10V8 is on a distinguished road
This is your first post in the thread, did yours not work also? If so how did you fix it?
I have a Tech2 and EFILive and cant fix mine.
Old 06-29-2008, 02:32 AM   #10
sargie26's Avatar
I found the two wires that send the signal. tapped directly to the pcm. then had to take the pcm programed. I got the pcm out of a 01 tahoe. the sending units are the same Ohms. but the pcm thought it still had a 25 gal fuel tank. the sonoma has a 18 gal tank. just had the parameter changed. if you need the wire's and pin on the computer. let me know.
Page generated in 0.14855 seconds with 12 queries
