fuel filter and lines
Old 08-16-2009, 04:57 PM   #1
saskboy's Avatar
parts list:
6 areoquip FCM1012 -6 hose ends
4 russell 640850 adapter fittings
2 russell 640860 adapter fittings
6' russell braided stanless line
1 12" male to male coupling 3/8 hard line
1 GM Part#10299146
Old 08-16-2009, 05:49 PM   #2
Need LSx swap.....
Kampz69's Avatar
Re: fuel filter and lines
nice
Old 08-17-2009, 01:56 AM   #3
01blzxtreme's Avatar
nice, so you used both fuel filters, stock and the flex fuel for regulator...
Old 08-17-2009, 10:23 PM   #4
saskboy's Avatar
yep. i'd rather replace the stock one when it gets dirty
Old 08-18-2009, 11:18 AM   #5
Need LSx swap.....
Kampz69's Avatar
cheaper that way too, ive seen some other guys do the same thing.
Old 08-23-2009, 06:53 AM   #6
so if i use the flex fuel filter i dont need the hard line since it already has the quick disconnect...
Old 08-23-2009, 01:52 PM   #7
saskboy's Avatar
this is the flex fuel filter
Old 08-23-2009, 06:41 PM   #8
yeah thats the filter i got...
Old 08-28-2009, 06:56 PM   #9
ok i ordered all the parts but were can i get that 12'' 3/8 hardline with the quick disconnects on it from
Old 08-28-2009, 11:29 PM   #10
saskboy's Avatar
i got mine from napa, just goto your local parts store and look around or ask some one. thats what i did
Old 08-29-2009, 09:15 AM   #11
thats were i went he told me it was a dealer item < you know how smart some of them are > but i found something i purchased a fittng from summit that has the 3/8 springlock to a -6 male fitting rus -640940 so i can just go from the fuel rail to the filter
Old 08-29-2009, 10:54 AM   #12
saskboy's Avatar
the description sounds right, altho i can't see a pic, i'm sure i,ve seen that fitting in another thread and it worked good.
the next thing u have to do is learn how to cut and install fittings on the braided line. i have descriptive pics if u need them.
Old 08-29-2009, 11:23 AM   #13
yes the pics would probably be helpful on the evap line you have disconnected in the 5th pic what are you going to do with it thanks
Old 08-29-2009, 10:12 PM   #14
saskboy's Avatar
delete it and vent it from the tank
Page generated in 0.57523 seconds with 32 queries
[Output: 84.17 Kb. compressed to 78.20 Kb. by saving 5.98 Kb. (7.10%)]
