First gen 5.3 swap.
Old 05-20-2008, 08:18 PM   #201
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
Re: First gen 5.3 swap.
well, at least it does to the other half---
Old 05-20-2008, 08:59 PM   #202
its just greg
AmericanMuscle's Avatar
AmericanMuscle is on a distinguished road
thats a nice bench good to see it on the road
Old 05-26-2008, 09:14 AM   #203
s10 newb
horsepwraddict's Avatar
horsepwraddict is on a distinguished road
slight traction issues. I wanted to get video but had nobody around to do it. This was just matting it from a stop, and shifting second about 10 feet out, letting off at the driveway.
Old 05-27-2008, 03:09 PM   #204
JJ's Automotive
SoLowXtreme's Avatar
SoLowXtreme is an unknown quantity at this point
sweet...def try & get a video
Old 05-27-2008, 04:27 PM   #205
Jonce007's Avatar
Jonce007 is on a distinguished road
x2 - It would be cool to get one like v8powers Colorado SS where you drive over it and hear the exhaust then see nothing but smoke from the tires.
Old 05-29-2008, 04:10 PM   #206
JJ's Automotive
x2...that be sweet
Old 06-02-2008, 11:04 PM   #207
s10 newb
I just couldn't stand the leaf springs being pulled apart by the stock explorer spring perches so i pulled the rear end out today, cut them off and welded a new set on. Im replacing the axle seals tomorrow, and putting it back in after taking a leaf out so it doesn't sit so high in the rear.
Old 06-03-2008, 03:17 PM   #208
s10-den's Avatar
speaking of Addict, why does your truck sit so high in the rear?
Old 06-03-2008, 03:37 PM   #209
s10 newb
I really dont know. The only thing i can think of is that they are brand new remanufactured springs and they are VERY stiff. A local spring company made them up, as with any generic (ish) aftermarket part, i dont expect it to be built to stock specs. I just pulled out the middle leaf, taking a quick break and going back out to put the rear in with only two leafs. I will get a picture up later.
Old 06-03-2008, 08:03 PM   #210
generics10 is on a distinguished road
arent your perches on top instead of the bottom? that would lift it the height of your axle tube...
Old 06-03-2008, 09:15 PM   #211
camaro1 is on a distinguished road
look closer, his rear end is up-side-down,, the perch's are on the bottom
Old 06-04-2008, 12:09 AM   #212
s10 newb
yup, put it upside down, measured the angle of the case and old perches with an inclinometer, cut the old ones off, placed the new ones on at the right angle and width, tacked them on, double checked and then finish welded....came out perfect.
Old 06-04-2008, 03:20 PM   #213
s10 newb
it brought the back down considerably. Looks pretty good now but the rear end is pretty mushy. I can forsee wheel hop becoming an issue.
Old 07-23-2008, 03:02 PM   #214
s10 newb
Well i just called a guy that races with us and set up a tenative appointment to get my rear end narrowed. Going to pull it out next week. Hopefully be able to do my motor mounts while the rear end is getting done and get the rear back in the first week of august. Then it 'should' be track ready.
im kind of getting that good feeling back, it had my bummed out for a while but this feels good to have a little money around and make some progress. Who knows maybe I will get motivated and do some other things that the truck needs.
Old 08-07-2008, 01:30 PM   #215
s10 newb
just got my rear back from the shop. Had it straightened, narrowed and welded. Just need to put the gears back in and it should be as good as new.
also picked up these motor mounts to fix my sagging mounts in the truck.
Old 08-07-2008, 05:24 PM   #216
V8 with bags
V8Blaze's Avatar
V8Blaze is on a distinguished road
rear end looks good. And your the first person besides myself ive heard mention the "sagging" mounts, mine do it bad. Where did you get those at
Old 08-07-2008, 06:42 PM   #217
s10 newb
I bought them from a member over on S-seriesforum that goes by the name of Boosted thrills.
Old 08-07-2008, 11:46 PM   #218
Still Mini Truckin' It
95slabside's Avatar
95slabside is on a distinguished road
On your tubular A-Arms from Speedway Motors, which ones did you order? They do not have an s10 listing on their site.
I wonder if they have uppers and lowers for that awesome price! I need to fix my ball joints too and tutbular would be awesome!
The truck looks like a hell of a performer! Hopefully I can get my tail in gear on mine
95S
Old 08-08-2008, 11:02 AM   #219
s10 newb
nope, they are not listed for an s10. They are listed under 'metric chassis' which is '78-'87 g-bodies. When I ordered mine they did not have lowers available but I heard they were working on them.
Old 08-09-2008, 12:32 PM   #220
comgtsom's Avatar
comgtsom
do the motor mount bolt right into the stock location. and how much were they. i need to replace mine. they look real nice too.
Old 08-10-2008, 10:07 AM   #221
s10 newb
yup, they are built off the dimensions of a stock 2.8 mount. They bolt directly inplace of the old 2.8 mounts.
Old 08-10-2008, 10:17 PM   #222
yates is on a distinguished road
I am just curious as to what rear end you used with this set up. I have a 5.3 out of a 99 and want to switch to disc brakes. What would you recommend?
Old 08-11-2008, 11:10 AM   #223
s10 newb
Its a ford 8.8 out of an Explorer. If you want one with disc brakes you need to get one from a 1995 or later. Very strong rear end, they all come with good gear ratios, 31 spline axles and posi's.
Old 08-11-2008, 01:48 PM   #224
simple man
5timedime's Avatar
5timedime is on a distinguished road
dude, i just read through the whole thread, and i've got to say congrats on the awesome project
at my work, we have an '02 and '04 GMC Sierra, both with extended cabs and longbeds, and both have the 5.3 "T" vin code engine. even in the big, long, heavy fullsize trucks, the 5.3 is just a haul-ass engine! i think you're gonna really enjoy that in your s-series.
only question i have that i didn't see an answer to was this: did you buy the new wheels and tires before you decided to swap in the 8.8 rearend or do you have a plan to make the wheels bolt up to the Ford axles somehow? just curious
anyways, keep up the quality work
Old 08-11-2008, 10:14 PM   #225
s10 newb
Wheels weren't a factor when putting the rear end together. After I put it in I had a pair of wheels of my old ford ranger that I mounted my tires on. Later on I plan on getting a set of draglites for the truck, so I will just order the rears with the for pattern and the fronts with a chevy lug pattern.
Old 08-13-2008, 02:13 PM   #226
simple man
5timedime's Avatar
i'm sure you can't wait to get it all done! it'll be a sweet truck!
Old 08-19-2008, 05:51 PM   #227
s10 newb
Mounts went in like cake. I drilled two holes in the passenger side to get at the bolts. I welded 1/4" thick washers in the holes when i was done...probably stronger than it was before LOL.
On the driver side i just used the existing hole from the fuel lines. They went in VERY easy and picked the motor up about 1/4". Ive yet to drive it but so far im very pleased.
Old 10-23-2008, 09:20 PM   #228
s10 newb
rear end is POR-15'd and re-geared with a set of Motive 4.10's.
I put a set of Summit Star wheels on the back too. 15x10's with 5.5" backspacing and 275-50-15's, they fit extremely well with the narrowed 8.8. I put a set of used draglites on the front too. I like how it looks.
Old 10-23-2008, 09:35 PM   #229
s10-den's Avatar
oh man, I like them mounts!! I have been sayin all along about the sagging 2.8 mounts(some here, but alot some where else,lol)I just wonder how bad if any will the vibrations be?Did the motor sit in or about the same location/height?
Old 10-23-2008, 09:44 PM   #230
s10 newb
The motor sits higher than it ever did with the 2.8 mounts i had in their, but it hasn't caused any clearance issues because its higher, if anything it made things that were 'a little close before...but OK' even better.
Old 10-23-2008, 10:35 PM   #231
Have you had that thing to the track yet?? How do you like it compared to the sbc??
Old 10-23-2008, 10:36 PM   #232
s10 newb
no. i drove it once, the motor mount sagged and put the oil pan on the crossmember and i havn't driven it since.
