First gen 5.3 swap.
Old 04-29-2008, 10:21 AM   #151
its just greg
AmericanMuscle's Avatar
AmericanMuscle is on a distinguished road
Re: First gen 5.3 swap.
how does it sit different? do you have any pics of your axle swap intalled without it being shortend. this is the rear end I'm planning on swapping in and I want to see what it will take
Old 04-29-2008, 10:47 AM   #152
s10 newb
horsepwraddict's Avatar
horsepwraddict is on a distinguished road
Quote: Originally Posted by s10-den
hmmm,wonder why they are rubbing?Thats not a good thing to hear....
ya i dont like it either, my motor is all the way back too, if it was further forward it would be even worse. I already trimmed the control arms too. Not to happy about it only because its going to further hold up the project but what can ya do.
Old 04-29-2008, 10:49 AM   #153
s10 newb
This is how the spring perches line up. This pic was taken with the driver side bolted up so all the difference is shown on the passenger side of the vehicle. Lots of people have run it like this but the more i look at it everyday the more it bothers me. Im going to pick up a set of spring perches from currie and just weld them in about 1/4" on ech side.
Old 04-29-2008, 08:54 PM   #154
takes 2 balls in our game
s10-den's Avatar
s10-den is on a distinguished road
addict, I suppose you set the motor as low as it would go too?....
Old 04-30-2008, 01:55 AM   #155
its just greg
thanks for the info, you didn't shorten the rear did you? how much do the tires stick out on the sides with stock rims?(if you have stock or close to stock rims still)
Old 04-30-2008, 09:41 AM   #156
s10 newb
i guess but their really aren't and height adjustments. Just bolted the mounts on, dropped it in and slid it back. Its offset to the passenger side a little to and it JUST clears the booster with the coil packs.
Old 04-30-2008, 07:09 PM   #157
s10-den's Avatar
that just throws a monkey wrench into my game!!......
Old 05-01-2008, 11:03 PM   #158
s10 newb
core support in, radiator in, bumper on, fan installed and wired. Going to get a small 1" carb spacer so i can get the timing controller mounted the right way. Right now the carb fits under the hood, dont think it will with the spacer though...might have to do some trimming on the hood. Hows this for efficient use of space.
Old 05-01-2008, 11:14 PM   #159
S-series Member
lilsonoma's Avatar
lilsonoma is an unknown quantity at this point
Just 1 fan without a shroud?
I'm just keeping a watchful eye on this because a carbureted 5.3L is project number next.
Old 05-01-2008, 11:20 PM   #160
brakenit's Avatar
brakenit is on a distinguished road
What kind of fan is that and what's the CFM?
Old 05-01-2008, 11:29 PM   #161
s10 newb
Its a 16" hayden. It pulls ALOT of air, although i dont really expect it to keep it cool, it kept my 355 cool with a stock 4.3 radiator so it may work. If its not enough....i'll add another.
Old 05-01-2008, 11:46 PM   #162
S-series Member
lilsonoma's Avatar
Good replacement 16" fan with a shroud if yours doesn't pull it's weight.
http://cgi.ebay.com/ebaymotors/MUSTA...QQcmdZViewItem
Old 05-02-2008, 07:38 AM   #163
s10-den's Avatar
you will have to drill a small hole in the hood Addict for the breather stud...lol,just messin with ya....did you get it running yet?Hows it sound with the cam and manifolds?
Old 05-02-2008, 09:21 AM   #164
s10 newb
it hasn't been running since the radiator is in so its only been started for a few seconds. Their will be video soon once it rolls out of the garage.
Old 05-02-2008, 03:38 PM   #165
s10 newb
these came in today.
Old 05-03-2008, 02:17 PM   #166
comgtsom's Avatar
comgtsom
how much did they run ya?
Old 05-03-2008, 02:27 PM   #167
s10 newb
about $50 a piece from speedway motors.
Old 05-03-2008, 05:17 PM   #168
s10 newb
no more rubbing. They fit real nice, called speedway and they said torque the cross shaft bolts to 55 ft. pounds. incase anyone wanted to know.
Old 05-04-2008, 04:14 PM   #169
s10-den's Avatar
now thats good to see!!
Old 05-04-2008, 05:47 PM   #170
s10 newb
sure is, made me happy. They were an easy install too, got to do upper balljoints at the same time, so i killed a few birds with one stone.
Old 05-04-2008, 07:01 PM   #171
NEED4SPEED!
sockjock's Avatar
sockjock is on a distinguished road
Hey horsepoweraddict, I've been readin thru your thread. Pretty cool project and seems to be comin along great. I got a couple questions for ya. I saw the intake from one of your pics. It appears to be a dual plane intake..I was unaware that a dualplane was available for the 5.3. What intake is it and what rpms is it supposed to operate in? Another question I had was about your diff. What is that extra gear on the outside of the ring gear? some kind of sensor ring and if so for what? I've really been wanting to do a V8 swap and would love to do a 5.3 swap but from my research it'll be pretty expensive. I'd love to be able to go carbed and keep it streetable/daily driver/trail worthy. That's why the questions about the intake and your 8.8 diff. Sorry to be longwinded
Old 05-04-2008, 07:17 PM   #172
s10 newb
not a problem man. Its an edelbrock performer RPM intake, it is in fact a dual plane and its good for 1500-6500 RPMS. The ring next to the ring gear is a reluctor wheel for the factory ABS sensor on explorers, im using it for my electronic speedometer.
Old 05-04-2008, 08:15 PM   #173
NEED4SPEED!
sockjock's Avatar
Thumbs up Re: First gen 5.3 swap.
Thanks for the reply. That intake might work for my intents too. Maybe a little high in the RPM's but not by much. Pretty cool use of the reluctor wheel too.
Old 05-05-2008, 08:25 PM   #174
its just greg
link? do they have lowers?
Old 05-07-2008, 03:41 PM   #175
s10 newb
made a battery tray today. Took a universal parts store one and made it fit the truck.
Old 05-07-2008, 03:55 PM   #176
NEED4SPEED!
sockjock's Avatar
Where was the original battery mount location? I'm kinda surprised you didn't opt for a bed mounted battery setup if you planned to race your truck. Sorry for the dumb questions, I'm only familiar with my second gen. Blazers. ps. the battery tray looks great
Old 05-07-2008, 04:10 PM   #177
s10 newb
thats the original location, i just didn't have one so i made one. I thought about putting it in the bed, but enough cable to put it all the way back their would have cost close to $100, plus a cut off switch. Maybe later, this was just cheaper for now.
Old 05-07-2008, 05:48 PM   #178
NEED4SPEED!
sockjock's Avatar
I can understand that. Money talks. How close are you to having it on the road?
Old 05-07-2008, 11:30 PM   #179
s10 newb
its running, hasn't been out of the garage yet though. I dont want to say because if i do i know i wont make it in time. Its down to stuff like getting all the lights back in and working, tuning and just making sure nothing is wrong. Not to long, it will be ready before i can afford to get it registered though.
Old 05-07-2008, 11:42 PM   #180
NEED4SPEED!
sockjock's Avatar
Cool. I'll be watching to see how it turns out. It's looking more and more like there will be a V8 swap in my near future. I'd love to go the 5.3L route but the more I research, it looks like a TBI 5.7L will be alot cheaper. My 95 Blazer is having more and more small problems(none of which are cheap) and I can't see spending all that money on bandaiding my anemic 4.3L back together just to wait for the next problem especially since it already has 117k plus miles on it. Guess I'll just drool over your 5.3L swap.
Old 05-09-2008, 04:14 PM   #181
s10 newb
Old 05-09-2008, 04:58 PM   #182
NEED4SPEED!
sockjock's Avatar
Wow! It sounds like it has a pretty smooth streetable idle. So how much money do you think you have in this swap so far?
Old 05-09-2008, 07:01 PM   #183
JJ's Automotive
SoLowXtreme's Avatar
SoLowXtreme is an unknown quantity at this point
sounds good man
Old 05-10-2008, 12:02 AM
